05-22-2012, 03:25 PM
Front Wheel Bearings and Locknut ?
I am putting my front wheel bearing back in after a brake job. I placed the large ring that isn't a full circle (sorry don't know what it is called) inside the hub and tapped in in with a punch and a hammer so that it was fully seated in the hub. Then I packed the bearing and placed it inside the hub with the tapered in first. Next I need to screw on the first of two lock nuts. When I took it off, it was only hand tight, maybe a little less. Is that how I should re-install it? Then the washer thing with the holes in it. I know that the inner lock nut has a little stud that needs to fit inside one of the holes on the washer. Then put the outter lock nut on (again, how tight). This one seemed to be a lot tighter than the inner lock nut. Then the gear thing (I had to tap it in with a hammer too). The lock ring thing, and then the dust cap.
Is that it?
I shouldn't have to replace the inner seal or anything if I didn't remove it right?
I know yall like pics!
1988 GW
05-22-2012, 03:33 PM
A set of instructions with pictures:
http://www.grimmjeeper.com/J-Truck/rotor.html
Short answer: Neither of the locknuts should be hand tight but it's more complicated than just torquing them down. Follow the instructions on that page and you'll have no problems.
05-22-2012, 03:54 PM
Awesome write-up thanks!!!
1988 GW
05-23-2012, 09:58 AM
tighten the first one till you feel slight drage whenturning the rotor,then backit off to set the locking ring.the outer nut goes to 50ft/lbs iirc
85 gw 215k and still going
89 gw,free,almost legal
05-23-2012, 10:34 AM
Not even close. If you don't properly torque the inner lock nut your bearings will be loose and that can lead to catastrophic failure in a hurry.
You need to torque the inner locknut to properly seat the bearing. The inner gets torqued to 50 ft-lb (while the rotor is being spun) and then backed off 1/8 turn. Then the lock ring goes on. Then the outer lock nut gets torqued to 50 ft-lb.
05-24-2012, 08:51 AM
thats real close.50 ft/lbs will give ya just a slight drag.have done it this way at least 50 times without any problems at all.
05-25-2012, 11:20 AM
Does anyone know the part # for the seal that goes on the hub to hold the inner bearing in place? I know the outter bearing is held in place with the locknuts. I found several on advanceautoparts.com, I just don't know which one I need.
Axle Spindle Seal?
Spindle Hub Seal?
Wheel Seal?
1988 GW
