Old 05-01-2012, 05:48 AM
TAWL_BOY TAWL_BOY is offline
About to Piece Together Hydro Assist
I've got a 79 Cherokee that will be running HMMWV 37" Radials and will be a weekend cruiser, mild trail and camping rig.
Before I tore into it, the steering pump was squealing up a storm, so I definitely plan to replace it.
I'd like to go ahead and go with hydro assist from the start. I had a setup on a Chevy on one tons and loved it.
I've been searching around, but I haven't found exactly what I'm looking for.
I've got a low mileage steering box off an 85 CJ10(same as Waggy, J10) that I could drill and tap. Or should I go ahead and get a J20 box and drill and tap it?
Should I just go with a stock J20 steering pump?
And should I get newer O-ring pump and box, or stay with the older style on both?
Old 05-01-2012, 06:33 AM
j20brett's Avatar
j20brett j20brett is offline
New style j20 box is my vote. Get a stock pump and see how it does. If its not up to par, do the west texas mods to the piston. If that still isnt enough, psc pump and call it a day. I dont think you will have any problems with the stock pump though.
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-d44hd front aussie/d60 rear welded - CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy, hp60, 14-bolt, NWF Black Box/NP205, 5.13's, SOA, 42's
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 05-01-2012, 08:13 PM
Is a J20 pump better than J10/Cherokee pump?
Old 05-01-2012, 08:18 PM
j20owner's Avatar
j20owner j20owner is offline
It is bigger.
Post with a picture by Tad:
Boxes
Where is my axle?
79 j20/84 GW GM Hybrid
Old 05-01-2012, 08:23 PM
I know about the boxes.
I'm talking about the pumps.
Old 05-01-2012, 08:45 PM
austinaubinoe's Avatar
Pretty sure all the pumps were the same. Maybe bigger valve or something.
Old 05-01-2012, 10:51 PM
Blake Blake is offline
I think the PS pumps for FSJ's are all the same, minus the fittings.
I'm running a '78 J20 box on my wagggy and J10. Both are tapped, but I'm running plugs in the waggy (plans for future assist). The J10 has a 1.5" x 8" PSC ram. Work great. Could use a little better pump, but it's fine.
Here are some good pics I took of where to properly tap the boxes.
Drilled and tapped the J20 box with a 7/16th drill bit and a 1/4" NPT tap.
Old 05-02-2012, 05:28 AM
Is there any benefit of picking up a post 79 pump and gear box?
Or should I just go with the older style?
Old 05-02-2012, 06:01 AM
j20owner's Avatar
Duh, what I get for late night posting.
Where is my axle?
Old 05-02-2012, 08:37 AM
j20brett's Avatar
Only difference is new boxes are o-ring fittings while old are flare fittings. Personal preference really.
Build Thread
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Removed the Hydro assist steering Blake Off-Road FSJ Tech 20 09-29-2012 10:41 AM
Hydro assist advice required. Mex in the city Off-Road FSJ Tech 19 04-22-2011 06:50 AM
Hydroboost w/ hydro assist steering? 81jseries Off-Road FSJ Tech 3 03-16-2009 07:03 PM
Hydro Assist problem... BRUTUS Off-Road FSJ Tech 21 09-11-2008 02:05 AM
Full Hydro vs. Hydro Assist Will Morris Off-Road FSJ Tech 20 11-27-2003 12:33 AM
