Old 04-09-2012, 07:34 PM
Dumpy's Avatar
Dumpy Dumpy is offline
Trying to do the rag joint deleTe
But can't get the stupid rag joint off!
Justin
'72 J2000 360 4bbl T18 D20
'96 ZJ
Old 04-09-2012, 07:50 PM
shaggywaggy88's Avatar
shaggywaggy88 shaggywaggy88 is offline
I had the grille, radiator condenser and trans cooler off when I removed my rag joint. I had to pound it out with a 4lb mini sledge.
Then it took just as much hammering to get the XJ shaft installed.
Everything went together and has been working much better than the sloppy rag joint.
88 Grand Wag:
Razor Grille
Rusty's 4" spring lift
BJs HD 1" shackles
31" M/Ts
Holley 4160, 600cfm
T.F.I.
Warn Hubs
SOLID Diff cover
999 X-member/T-case Skid
Rag joint delete
Old 04-09-2012, 07:52 PM
jwalton23's Avatar
jwalton23 jwalton23 is offline
I did it too. Soak the joints in penetrating oil overnight then get to banging! Lol
91 Grand Wagoneer
AMC 360 / Torqueflight 727 / NPM 229
Dana 44 front and rear
6" Rustys Offroad suspension lift
BJ's quick disconnects
BJ's PreRunner front bumper with winch plate
fenders trimmed
35x12.50x15's Maxxis Bighorn mudders
Rhino grill
http://www.tnjeeps.com/
Old 04-09-2012, 08:24 PM
Dumpy's Avatar
I got it! I'm dumb. Didn't realize I needed the bolt all the way out. Pretty much popped off! I cannot get the XJ shaft on, though. It actually seems a tad bit smaller did you guys run into that problem? Now this should prolly go to tech.
Justin
'96 ZJ
Old 04-09-2012, 08:32 PM
jwalton23's Avatar
If you're doing it to the rig in your signature then I'm not sure if it's the same as the GW. I know some years were different but I'm not sure which years were different. It may not work with the gearbox on your truck. I know it sucks to be that far into a job to find out it doesn't work. Then again I could be wrong and it does work just gotta get the splines lines up correctly and check it. If you can get some pics up it might help.
91 Grand Wagoneer
fenders trimmed
Rhino grill
Old 04-09-2012, 08:36 PM
Dumpy's Avatar
I checked and it is def different than the GW shaft. I think the gear box shaft dealie is bigger. Sucks. I almost got out the grinder because the flat spot and the bolt should in theory hold everything together, but might cause trouble down the road. Not worth it. My 40 year old rag joint is actually in great shape. It'll take me 15 minutes to get it back together. Anyone want an XJ shaft?
Justin
'96 ZJ
Old 04-09-2012, 09:44 PM
Dumpy's Avatar
Well, the old stuff is back in *sigh* oh well, I guess my truck is just to awwwshummm for all these new fangled contraptions.
Justin
'96 ZJ
Old 04-09-2012, 11:36 PM
austinaubinoe's Avatar
You can get new rag joint assembly's for less then 20 bucks. They worked for a long time so may not be worth the hassle. Got mine from rock auto.
Old 04-10-2012, 09:58 AM
I think you missed the goal of the poster.
Title is rag joint delete, as in get rid of it.
Old 04-10-2012, 10:35 AM
orangecherokee's Avatar
I spent a decent amount of coin on a Flaming River u-joint and it's definitely take nthe abuse. Not saying you'll need anything that beef but it'll definitely get rid of the rag.
Old 04-10-2012, 10:02 PM
There is one fat spline you have to line up on some of these to get them to work.
MOVING SOON! Crusher alert!
Pics of parts for sale stuff: http://tinyurl.com/jimsclads
Old 04-12-2012, 05:54 AM
Dumpy's Avatar
Yeah, the whole splined shaft was bigger. There was no getting it on. I'm gonna keep a lookout for another donor for the earlier rigs. I wonder if a ZJ shaft would work. Some look different.
Justin
'96 ZJ
Old 04-12-2012, 08:52 PM
Stuka's Avatar
Stuka Stuka is offline
I am curious why you are getting rid of the rag joint? It is there for a reason, and is not prone to having any issues when in good condition.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 04-13-2012, 07:54 PM
ferox's Avatar
ferox ferox is offline
I recently had the opposite problem while trying to do the rag joint delete. I found a steering shaft (pictured) off a '76 wag with manual steering. The spline count at the gear box shaft was different than my '82 wag with power steering, so I ordered a new coupler from a vendor that will not be named. The coupler I received was for a splined shaft that was bigger than the one on my wag.
After suffering through condescension and ignorance from said vendor that did not know more than what the parts catalog listed, I did some research. Most Wagoneers and J10s came with a Saginaw box with a 3/4" input shaft while the J20s came with a 13/16" input shaft. Of course those rules are not set in stone. It sounds like you have the 13/16" version.
I decided it was not worth my time to continue to wrangle with the vendor and kicked down the cash for the Borgeson. So I have a steering shaft set-up that I think would work for you. I am into it for $65, so I'd let it go for that price plus shipping if you want. Since this isn't a for sale thread I'll post up some details in a separate thread.
"The Bruiser" '82 Wag, 258, T176, NP208, D44, AMC20
http://www.arkive.org/fossa/cryptoprocta-ferox/
Old 04-13-2012, 10:13 PM
Dumpy's Avatar
It works fine, but a solid ujoint style seems like it would last longer. I wanted to see what the hype is was about. Guess I'll never know. I'm also wondering if I have the larger (j20) box in mine already, being that the splined shaft was too big. Being that 72 was a kinda weird (let's try this) year, I wouldn't doubt it a bit, even thought I have a 1/2 ton.
Justin
'96 ZJ
Old 04-14-2012, 11:46 AM
Not being the OEM owner means it could've been swapped in too. You should be able to measure the bottom cap on your box. Yours has the steel adapter/lowering plate between the frame and box?
Old 05-05-2012, 09:55 AM
jamesdart
Posts: n/a
i wish i would have seen this thread. this morning i went to the junkyard for some stuff and kept striking out. i figured id grab an xj steering joint and get rid of the rag joint. liek ive read about a few times on here. i start pounding to get the old shaft out of my 78 wag and it doesnt really want to come out so i figured before i beat the snot out of this thing and let me make sure the xj joint fits my box. nope. not happening.that was a waste of a morning and 20 bucks. not to mention the rag joint came apart when i took it apart. now im pissed.
Rag joint questions chazer General FSJ Tech 8 04-14-2012 12:26 PM
Ball Joint Issue Suddendeath General FSJ Tech 9 04-01-2012 01:01 PM
Steering Rag Joint Delete The Colonel Suspension and Steering 36 09-09-2011 09:57 PM
Loose U joint djmac General FSJ Tech 1 09-26-2007 09:20 AM
SOA and driveshafts Woody Long Off-Road FSJ Tech 20 04-12-2006 04:13 AM
