Old 04-08-2012, 12:29 PM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
BJ's Offroad Underhood Insulation--which side up?
I received the three underhood insulation panels from BJ's in timely fashion, and they are looking good. They have a sort of "rind" side that is much harder and smoother than the other side, which is merely the fiber itself. Which side goes to the sheet metal under the hood?
Part of me says leave the smoother side toward the engine, as it is less apt to snag and tear on things than the other side. The other part of me says put it up toward the sheet metal, as it provides a better substrate for the adhesive, making the panels less apt to tear off the underside entirely.
Which way? I didn't find any instructions packed with this material...
Old 04-08-2012, 12:33 PM
REDONE's Avatar
REDONE REDONE is offline
Fab/Tech Moderator
The factory type was wooly side to the metal and hard side to the engine. I only know this because I've never found an easy way to remove the remains of the stuff from the metal. It stays hairy until I break out the sander and remove it all including the paint.
79 J-10 - The Money Badger!
304/T18/D20/D44s
What's been did:
Holley 4160/Ede' S.P.2.P.
MSD Streetfire based TFI
Custom-hack gauge cluster
Razor swap
2 knob tape deck!
3" homebuilt lift
Half a hillbilly paint job
Old 04-08-2012, 04:06 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
correct, shiny side down
BJ's Off-Road
ryan@bjsoffroad.com
Old 04-09-2012, 07:07 AM
drlocke's Avatar
Roadside Mechanic
Thanks! I propose using an aerosol-type contact cement with which I've had great luck with before in making flexible patches that remain tough under adverse conditions. I hope to be able to provide enough saturation of the woolly surface that the adhesive doesn't simply absorb back away from the interface where it needs to be present to do its job.
I'll go with whatever is advised, but--FYI-- I must say this contact cement spray I've used for 30 years, and had admirable results.
Replacing Side panel boards and Floor ? silvercert General FSJ Tech 3 04-04-2009 01:05 PM
FSJ Window track ID Left or Right Side??? FSJ Guy General FSJ Tech 8 01-22-2009 10:27 PM
Passenger Side Motor Mount -HELP chr1s General FSJ Tech 2 11-15-2003 03:31 AM
Changed passenger side exhaust manifold gasket jeepthing General FSJ Tech 2 06-20-2003 12:50 PM
Leaning to Passenger SIde Gary Holmes General FSJ Tech 12 07-10-2002 04:59 AM
