Old 03-28-2012, 02:29 PM
Suddendeath's Avatar
Suddendeath Suddendeath is offline
Ball Joint Issue
So I'm swapping out the ball joints on the driver side. Swapping knuckles too, going for full high steer. I had the guys who machined the knuckle press in the ball joints while they were at it. The ball joints are from summit racing, and I just confirmed with summit that they are indeed the correct joints.
Mevotech 8195T & 8194T
http://www.summitracing.com/parts/MEV-MK8194T/
http://www.summitracing.com/parts/MEV-MK8195T/
Here is my issue. It doesn't seem like the top ball joint is properly seating in the axle C. It's leaving a gap of about 1/2" between the top of the dust boot on the joint and the C. I have zonked the snot out of this thing trying to pull it up into place, and the only result has been a busted ratchet. I've adjusted the little threaded thing that goes into the C up top, and that didn't help either.
What could possibly be going on here? At first I thought that it was maybe a slight difference in ball joint design, but upon putting the spindle back on the 1/2" gap is sufficient to cause the axle shaft U joint to bind on the lower ball joint's nut. The whole setup looks like the knuckle needs to move "up" about 1/2".
Could they have been pressed in wrong? I'm not sure what the deal is...my passenger side was done the same way, with the same joints, about 8 months ago and it went together no issues.
I'll post pictures when I can.
Thanks for the help guys.
1990 GW:
360/727/229/D44F&R
Performer Intake/Holley TA 670/Hedmans/3" Exhaust.
SOA/SF New Springs. 4.10's, Locked Rear. Swingout Rear Bumper, Front Winch Bumper w/ 12k Winch. OBA, Cobra CB, and a bunch of other stuff that doesn't work quite right.
My Build Thread
Old 03-28-2012, 02:47 PM
altrocker1 altrocker1 is offline
did you use a flat ball going press or one with an angle in it. i know the kunckles on my dana 30 need an angled ball joint press or they may not seat all the way
Old 03-28-2012, 03:04 PM
On my passenger side I pressed them in personally and they went straight in no issues, no hesitations. That's the side that has been trouble free for months now.
Perhaps the pressing of the ball joints is the issue? I don't know how, but tomorrow I'll drop the knuckle and 2x check to make sure they're properly seated.
1990 GW:
360/727/229/D44F&R
My Build Thread
Old 03-28-2012, 03:08 PM
Chevelleguy's Avatar
I'm not sure if it is possible, but my bet is that the guy got the upper and lower joints switched. The 8195 is the lower joint, and it has a shorter shank than the 8194.
Old 03-28-2012, 03:27 PM
No, upper and lowers are correct. I am sure of that one at least. The upper is the one with the hole for the pin to go through, and it's in it's place.
I'm also pretty sure that they were pressed in properly. If they were pressed in wrong, the issue would be between the ball joint and the knuckle. It's not. The issue is between the C and the ball joint. It's almost as if the tapered part of the ball joint is...too wide? for the adjusting collar. I'm going to try removing the adjusting collar again and setting it up x2. Who knows what I goofed this time.
1990 GW:
360/727/229/D44F&R
My Build Thread
Old 03-28-2012, 03:28 PM
Blake Blake is offline
Got any pics?
I've pressed in tons of D44 ball joints...
Old 03-28-2012, 07:21 PM
Stupified's Avatar
Stupified Stupified is offline
did you put the caster shims back in the top ?
should look like this.... http://www.ebay.com/itm/170777015554
73 Wagoneer 360 400/20 D40/D30 3.31
285/70R17 DuraGrapplers
post flipped rear, rough country 6110 chevy front AAL
Camo green Zombie Response Vehicle
Old 03-28-2012, 10:34 PM
Romanov's Avatar
Romanov Romanov is offline
Might seem dumb, but did they check the old part against the new? I have gotten the wrong part in the right box. If the install looks right then I would think the taper of the ball joint is wrong.
Old 03-29-2012, 06:06 AM
jeepfan93's Avatar
jeepfan93 jeepfan93 is offline
Easiest way to tell if they're pressed in right is are the C-clips in place? If not they're in wrong. Other than that, you may have wrong parts boxed up. Look at the joints themselves and see if you can part numbers stamped on them.
Jeeps are Jeeps, keep Jeepin
>It's not about the ten hour drive to get the rust bucket jeep, it's about where your your going when it's done
91GW Promar 360 .030.9.5:1 MTA1 cam MSD Edelbrock 2131 Skip White HEI Holley4160 RC 2 in lift 31's Cobra CB custom bumper and 10k winch
1994 F150 for haulin stuff
Old 04-01-2012, 01:01 PM
Tourettes's Avatar
Tourettes Tourettes is offline
I had a similar difficulty with inferior ball joints. At first I purchaced ones that were in the middle of the cost spectrum. I ended up returning those and bought MOOG balljoints.
The photo shows the the one removed and the mid priced balljoints.
http://www.facebook.com/photo.php?fb...type=3&theater
I wish I had gone with the MOOGs to begin with! a lesson learned!
Tourettes 1983 Wagoneer Limited
360-727-228 - MSD 6a - TFI - MSD 8.5mm - 880CCA Diehard Plat - 31x10.5x15 - LEDs in every socket
Ball joint fix? tazzerzz General FSJ Tech 8 09-18-2010 05:19 PM
Ball Joint Replacement 101 - lots of pics gte901m Suspension and Steering 16 04-12-2009 04:33 PM
Dana 44 Ball joint boot? toyotajeep Off-Road FSJ Tech 5 08-30-2006 01:28 PM
Ball joint torque coach-frank General FSJ Tech 3 03-05-2003 03:33 PM
Ball Joint Update Iron Horse General FSJ Tech 11 10-03-2002 11:09 AM
