Old 03-08-2012, 03:40 PM
greenear123's Avatar
greenear123 greenear123 is offline
A case for Rihnolining the inside of your FSJ
So, it is a gorgeous Spring day here in Boise and my son and I decided to take the dogs for a run and a short drive in the GW. After letting the hounds run and bouncing around on some dirt roads we were heading home when we heard a sloshing noise from the back seat. I looked back to see our "Australian Boxer Hound" depositing about a gallon of puke on the back seat and floor.
My EDC bag, a pair of gloves, a hat and a note book all were plastered with it.
I pulled over and covered it with an old blanket, to keep the dogs from spreading it more, and then boogied home. Kicked the dogs out and got to the car wash to carpet clean everything.
Seriously considering lining the floors. Could have sloshed a gallon of water on it and gotten 90% of the mess out right there.
Anyone know of a good neoprene seat cover set for the Waggy?
Jack: '89 G-W. Rusty's 4" Lift, TFI
Old 03-08-2012, 03:53 PM
Logans Run's Avatar
Logans Run Logans Run is offline
LOL Fun!
I took the back seats out of my rig and I am going to use Durabak in my cargo area
The Falcon ... 73, 360, TH400, D20, D44 3.54 (F&R), 6" BJ's spring lift, 35"
"I've fought tougher men, but I really can't remember when."
P.S. those are some beeftastic bumpers!
My Build Thread:
http://www.ifsja.org/forums/vb/showthread.php?t=151753
Old 03-08-2012, 04:33 PM
MonsterZ's Avatar
MonsterZ MonsterZ is offline
Same here, it is cheap enough that I am also using it to coat the under side of my floor boards and fire wall since they will be clear for awhile to come....should reduce the road noise quite a bit as well. As for neoprene seat covers, check out rugged ridge seat covers. Kinda spendy but worth it.
'75 Wagoneer, bone stock, about to be a whole garage of parts. Tear down starts 3 March, 2012,
see how long it takes to put it back together....
'91 XJ, 3 in Rough Country lift, 33's, Rattle can paint job, roof rack and cheapo off road lights. Diffs and winch next
Old 03-08-2012, 04:56 PM
PAluke's Avatar
PAluke PAluke is offline
I'm in the process of taking the carpet out of mine and plan on lining the floor pans. I'm looking for some advice/pics of what was done with the wires running back the floor on the driver and passenger sides.
Old 03-08-2012, 05:05 PM
brushawg's Avatar
brushawg brushawg is offline
I don't know if wet okle make rear seat covers, especially for a fsj but I would check it out.
Just
Expect
Every
Problem
Got to love them
Old 03-08-2012, 05:10 PM
Why not just lose the carpet. Scratched up factory paint is easy to clean/hose off and looks better than bed liner goop. Heck sans smell doggie barf looks better than bed liner goop.
-Geoff Hill
Old 03-08-2012, 05:36 PM
will e's Avatar
will e will e is offline
Always Broke
I am carpet free in the back
No seat either.
Vinyl in the front.
81 Wagoneer - 'WILL E' Retired
82 Cherokee WT - SOA/SF/cross over/high steer/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/awesome Rstep custom bumpers and roll bar/Tad steering brace
Old 03-08-2012, 06:07 PM
xGROMx's Avatar
xGROMx xGROMx is offline
Just got done ripping out all the carpet, front and back. It was holding moisture causing some rust. Plan on painting it black, keeping the smooth surface, easier to clean than a rough surface. Looking for set covers also.....
Old 03-08-2012, 06:20 PM
jamesdart
Posts: n/a
i have a brand new carpet, but im not goign to use it, i plan on sprying the whole floor with monstaliner.
Old 03-08-2012, 06:56 PM
FSJ Guy FSJ Guy is offline
Don't drive like a lunatic and your doggies won't get sick!
Ethan Brady
www.bigscaryjeep.com
Old 03-08-2012, 07:40 PM
FSJ Guy, Is there any other way to drive?
What kind of road noise would you get sans carpet?
here is the culprit:
looks innocent, don't she.
Old 03-08-2012, 09:20 PM
Herk's Avatar
Herk Herk is offline
The auto body supply place on Overland sells U-Pol Raptor liner. I plan to do the inside of my cab and bed with this stuff:
http://www.rubiconownersforum.com/ph...p?f=39&t=63375
Old 03-08-2012, 11:21 PM
COLORADOCRAWLER's Avatar
COLORADOCRAWLER COLORADOCRAWLER is offline
Talking
I haven't tried it yet but a friend has had really good things to say about Lizard Skin lining. It supposed to be really good at noise dampening, is tintable, and has ceramic stuff in the mix to block out heat (enough so that he had trouble welding to the undersidebecause it was dissipating the heat too quickly to get a good weld without stripping the stuff of of the other side!) Anyway, figured I'd give it a try soon. I'll report back when the job is done.
87' GW 360/727/229, 31's for now, sweet faux wood paneling, and a Big Foot gas pedal!
90' YJ, TNT Customs coil suspension, 5" stretched wheel base, D44s, ARBs, 35's
Old 03-08-2012, 11:29 PM
robert_hollis's Avatar
robert_hollis robert_hollis is offline
I vote for Monsta Liner. They give a discount to Jeepforum members, and since it can be rolled on (or sprayed on), it can go on thicker than Raptor liner. You can also get it in a few different colors.
360/TH400/D20
3"SL/3"BL/35s
Old 03-09-2012, 01:45 AM
Heep80's Avatar
Heep80 Heep80 is offline
I need to do this also, have some floor rust pan repair to do. Maybe some good line x or something. Just sweep it out and hose it off. lol
80 J-10 with 3in RC lift,1 in. shackles, buckshot M/T 33's. dual glasspack exhaust,eldobrock intake/carb/valve covers/aircleaner k&n, autometer tach, spare tire mount w/ fullsize spare,tool box, 40gal spare tank, grant steering wheel, rhino grill,DPA (Not installed Doug T's Headers, Hi lift jack, cobra cb,tie rods, & dual timing chain
Old 03-09-2012, 06:29 AM
Billygoat's Avatar
Cabela's has some inexpensive PVC seat covers - universal fit
I have them in Gozo that I use for duck hunting, 2 wet muddy dogs can coat and interior pretty fast, just let the mud dry and brush it off.
I throw a seat towel on then when I am in good clothes.
I went with a rubber mat and bedlined panels in the rear, have not got to the front yet.
I had 1 dog loose it after eating a gut pile from a deer - then I about lost it, but the PVC seat cover kept it from soaking in, so after removing the pile a damp sponge and some lysol and all was good.
"Thumper" - 1981 J-20 Extended Cab/sportside, HB, Muscle Grill/round lights, Audiovox Cruise Ctrl, XCR-8000 winch/stk bumper
Extended Cab Build thread {click}
401-4L80E-242 conversion {click}
"Gonzo" - 1983 Cherokee WT 360/727/229 - DYI TBI w/TFI dizzy, HB, 3" SR/SF lift, Muscle Grill/round headlights
Build Thread {click}
Old 03-09-2012, 10:05 AM
kiharaikido kiharaikido is offline
Durabak makes a grit free bedliner product. If I were to do the inside of my truck, I would use that. Grit free will make cleaning up puke and mud easier. My whole rig is done in this stuff. Cleaning it is a bit of a challenge.
http://www.durabakcompany.com/automotive.htm
Old 03-09-2012, 12:18 PM
Logans Run's Avatar
the lizard skin is nice ... but it aint cheap either.
My Build Thread:
Old 03-09-2012, 12:50 PM
MonsterZ's Avatar
I'm running mine up the dash, and hidden behind the headliner.
Old 03-11-2012, 10:02 PM
Mr Carts Mr Carts is offline
I did mine I used a gallon for the floor area and firewall. Took out the seats and poured it on the roller it out.
The PO had removed all of the carpets so it was noisy and the floor got hot. Much quieter now and the floor isnt getting hot.
I am going to put another gallon on the in the back as my Cherokee is my supply hauler our place on the mountian and I took out the rear seat.
Where can i buy a formed rubber floor mat? As I drive on dirt roads then tromp around in the dirt carpet won't work.
Thanks
transfer case shifter in J-20 soxcloud General FSJ Tech 5 04-21-2008 10:53 AM
229 Transfer Case Removal-help/questions chr1s General FSJ Tech 3 10-05-2005 12:53 PM
Tranny or Transfer Case Bad???-long Marshmountain General FSJ Tech 4 09-23-2003 03:30 AM
My case don't fit and I can't aquit! MuddyWag General FSJ Tech 5 05-03-2002 12:45 AM
