Old 03-04-2012, 09:27 PM
altrocker1 altrocker1 is offline
j20 dana 60 value...
so im contemplating pulling a set of j20 dana 60's off an 85 at a pick and pull...part of me thinks i might want them in case i decide to step up to a 6bt instead of a 4bt...but if i do go with a 4cyl diesel, how much would they be worth? obviously distance and condition are a factor, but i was contemplating going to get them this week...
though im spending quite a bit of time getting the 258 running, so i will definitely not need them for a year or two..
Old 03-04-2012, 09:37 PM
COLOFIREMAN's Avatar
So did someone install a Dana 60 in the front...because they didn't come from the factory with it? Also snag them reguardless because if they are a good price like 200 for the pair that's a deal.
Old 03-04-2012, 09:43 PM
no...my bad...it should actually be a 44 in the front
Old 03-04-2012, 09:44 PM
the last rear axle i pulled i got for 110...so im hoping they would be similar
Old 03-04-2012, 10:31 PM
Only the M715s came with D60 front... and it's closed knuckle!
MOVING SOON! Crusher alert!
Pics of parts for sale stuff: http://tinyurl.com/jimsclads
How to convert Dana 60 GM front axle to coil springs? Subic Jeep Off-Road FSJ Tech 25 01-14-2010 07:26 AM
Does a Ford Dana 60 Axle fit? Narnian General FSJ Tech 2 05-09-2003 11:36 AM
J20 Dana 60, 30 spline??? powerfiend General FSJ Tech 7 01-27-2003 04:58 AM
SOA, 4" Lift, 40" Boggers, Revolver Shackles, Dana 60 Axles, Help me Out!! Rompn General FSJ Tech 51 02-20-2002 02:21 PM
gear ratios available for dana 44 and 60 Lococoin General FSJ Tech 4 04-09-2001 03:30 PM
