Old 03-02-2012, 08:28 PM
71 waggy's Avatar
71 waggy 71 waggy is offline
Do I need a new drive shaft with a lift?
My 6" lift from hell creek should be here next week. I haveread a number of different posts with conflicting results. Do i need a new drive shaft for my 71 wagoneer with a 6" lift?
71' Wagoneer "TheGeneral"
Old 03-02-2012, 08:38 PM
Blake Blake is offline
I think it depends.
I did SOA/SF on my waggy for about 7" of lift and didn't need a new rear shaft. Pics in my goofy build (link in sig). I later replaced it with an atlas and got 1350 shafts then.
I'm sure others will say you will.
Old 03-02-2012, 08:55 PM
jsice78's Avatar
jsice78 jsice78 is offline
My 72 has about 5in of lift if I had to guess and the driveshaft is pulling apart from the middle.
Old 03-02-2012, 09:05 PM
addicted's Avatar
addicted addicted is offline
That much lift you should get a longer one, even though the stock one will work in a lot of cases, it is just better to be safe than sorry.
Old 03-02-2012, 09:53 PM
billyrb's Avatar
billyrb billyrb is offline
BJ's Off-Road
up to 6", you can use your original dshaft. If you go SOA or more than 6" of suspension lift, you need to lengthen driveshafts.
BJ's Off-Road
ryan@bjsoffroad.com
Old 03-02-2012, 10:25 PM
88MudMangler's Avatar
88MudMangler 88MudMangler is offline
I have 6" lift, no problems with driveshaft.
88' Grand Waggy- 360 ci, 727 tranny, 6" Rustys lift, 35x12.5 MT, Mag Rims, 2.5" Wheel spacers, K/N Air filter,
Edelbrock Intake, Holly Truck Avenger Carb, Yukon 4.11 gears, tons of new parts
82nd Airborne 1/73CAV
More Photos of GW
http://s171.photobucket.com/albums/u...ndy/Jeep%20GW/
Old 03-03-2012, 05:14 AM
71 waggy's Avatar
Thanks everyone... anything else i should be prepared for beyond rusty bolts and a lot of head scratching and cursing?
Old 03-03-2012, 09:30 AM
68glad's Avatar
68glad 68glad is offline
Prepare for it to not drive the same unless you put on a drop pitman arm or something equivelant.
68 gladiator- r.i.p.
78 wagoneer- 401, drw60, drw70, 203/205, 38's, oba, hydroboost, dual p/s pump, bla bla bla
Old 03-03-2012, 12:19 PM
71 waggy's Avatar
I plan on going the drop pittman, new tie rods, steering stabilizer, and of course extended brakelines. Any oth suggestions on what should be changed while I am at it?
Old 03-03-2012, 01:38 PM
Return the 6" springs and trade them in for some new stock springs, then go SOA. That is, of course, if you like a nice smooth ride that flexes well.
Old 03-03-2012, 08:28 PM
71 waggy's Avatar
I do not have the skill nor the welder required for an soa. I thought about route but the local 4x4 shop wanted $750 andcould not guarantee they could get the steering geometry right without extra $
Old 03-03-2012, 09:59 PM
70Wangoneer's Avatar
70Wangoneer 70Wangoneer is offline
Did my 70 with a Hell Creek 6" lift. Ride is a bit stiff, front SUA with drop pitman arm. I have had good luck and havent had to change the stock drivelines. My front driveline is a bit extended, but is still hangin in there. Good luck with the install...You will need to find someone with a hydraulic press, and lots of anti-seize paste to fit the new bushings into the original shackles, mine were wasted. That was the only problem I had during the install.
Old 03-04-2012, 08:16 AM
billyrb's Avatar
BJ's Off-Road
or, instead of paying someone with a press, find a coupon and buy a HF unit or a good used one on craigslist, then you can press them out yourself
BJ's Off-Road
ryan@bjsoffroad.com
Old 03-06-2012, 07:43 AM
duracell's Avatar
duracell duracell is offline
That is a good piece of advice. Ive been trying to decide if I wanted to get one now I have another reason beside wheel studs
Old 03-06-2012, 09:18 AM
MonsterZ's Avatar
MonsterZ MonsterZ is offline
This would be a really good time to swap out u-joints, keep the originals as spare/emergency pairs in the glove box. Especially since you will be changing driveline angles and placing more stress on them. It really sucks to put in a new lift, and be off the road again a few weeks later because you just broke a u joint. Been there before.
'75 Wagoneer, bone stock, about to be a whole garage of parts. Tear down starts 3 March, 2012,
see how long it takes to put it back together....
'91 XJ, 3 in Rough Country lift, 33's, Rattle can paint job, roof rack and cheapo off road lights. Diffs and winch next
Old 03-06-2012, 05:04 PM
billyrb's Avatar
BJ's Off-Road
the only real downside to the HF press is the plates. There have been a couple reports of them breaking under pressure and shooting parts, but who knows what they were doing and if the plates were perfect when they were using them, or if it was user error. I have one in the garage and like it, but also make sure not to over-extend it's capabilities, and I use it as intended (mostly for u-joints, pressing in lug studs, etc.).
BJ's Off-Road
ryan@bjsoffroad.com
Drive Shaft Length Q Keanu151515 Off-Road FSJ Tech 4 09-13-2011 10:30 PM
Need help with front drive shaft fast! Dion General FSJ Tech 7 08-03-2011 09:02 PM
Front drive shaft with 9" lift + D60 ncjeepers Off-Road FSJ Tech 4 04-23-2008 02:41 PM
front drive shaft length with 6" lift and T18a. Stuka Off-Road FSJ Tech 21 09-27-2003 02:50 PM
Front Drive Shaft and Rough Country Lift igd General FSJ Tech 16 10-15-2001 11:38 AM
