02-10-2012, 01:31 PM
I need a good 360 oilpan
I am in need of a good oilpan for a 360. By good I mean straight rails and most importantly good plug. i picked up another Wag a while ago and the PO had stripped the plug threads.
Thanks
Ralph
02-10-2012, 04:44 PM
You know there may be other reasons that you just WANT to pull this pan (fix oil leaks, rear main seal, etc...) however, there are several fixes out there for stripped oil pans.... expanding rubber plugs, oversized self tapping magnetic plugs. They may not be pretty, but I have had some that worked for years. Most good parts guy should be able to lead you to one that will negate your need to drop the pan.
Good luck, either way!
Jesse- Sparta, MO (Near SPfdl MO) J20 4 Door Project, Wag w/ 6" Rusty's, 33x12.5's, 360/727 (for now!), 77 J10, 80 J20, 3 80's Wags, 73 Commando, Lots of AMC Eagles, FSJ parts Rigs and parts
02-11-2012, 05:13 AM
Ralph got a good one just sitting on a shelve.
77 Cherokee 401/400 trans,Holley on edelbrock performer,PT 1339
d44s,detriot rear ,diff guards front and rear
Fabbed front and rear bumpers,Tire carrier
33"BFG KM2's on black spokes
Tadrack
Interior upgraded,Durango console, custom gauge panel,bucket seats
Soa,with 1" shackle up front
Hood vents
02-11-2012, 08:15 AM
Wish you would have said something when you were here...
02-11-2012, 08:19 AM
Looks like Bob can help you Ralph. Too bad you don't need one for a 401 because we have a couple those.
02-11-2012, 12:31 PM
PM Sent Bob
Ralph
02-11-2012, 07:16 PM
Always Broke
I don't know what jeep you are fitting it to but beware if you have a driver drop front axle.
81 Wagoneer - 'WILL E' Retired
82 Cherokee WT - SOA/SF/cross over/high steer/agr box/Borgeson ujoint steering shaft/401/performer/holley TA/HEI/BeCool/727/np208/d44(aussie)/amc20(ARB)/BFG 35X12.5/Corbeau Moab Seats/RCI 6point Harness,Hella Aux lights/tuffy console/killer32 slider bars/awesome Rstep custom bumpers and roll bar/Tad steering brace
02-12-2012, 12:15 PM
Of What Mike?
02-12-2012, 04:01 PM
On the 81 and newer models, there is an indentation in the oil pan for front diff clearance. If you wheel it, you'll want the right one.
02-13-2012, 05:16 AM
this one has the indentation.
Tadrack
Hood vents
