Old 01-31-2012, 10:29 PM
blakeusa's Avatar
blakeusa blakeusa is offline
dual-diaghpram brake booster" from '78 J10 truck
Know this has been discussed, but cant find the details.
i,e, Upgrade booster from a newer J10. This is for a 71 J truck w/ 4 w drums.
Was told by Kaiserman that a moderate upgrade to my 4 wheel drum brakes would be to install a 78 J10/ J20 booster in that this unit has DUAL diaphrams and produces more vac power which would help with stopping.
Want to keep the stock look for now, but would prefer to go to front disc set-up but again this is expensive and I don't want to deal with this now.
Anyone do this and was it worth it, Yes I know hydroboost would be better but want to keep the stock look. If I can get a 20 percent improvement that would work for now.
Last what exactly do I need to do this (*parts/ part number or source)- just the booster or booster and master.
All my brake lines are new SS, new prop valve, and all new drums and brakes and cylinders all around. But as we all know they don't stop heavy moving metal very well.
Ok one last to the last, someone else mentioned drilling out the drums? Never heard this one before... any value or or are they just gonna get filled with dirt and wear out.
1971 J4000 Gladiator w/AMC 401 Restoration Project
Old 01-31-2012, 10:38 PM
Stuka's Avatar
Stuka Stuka is offline
I am pretty sure the dual diaphragm boosters started in '83. I know my '81 has a single diaphragm.
But a dual diaphragm certainly makes a noticeable difference. Do you have power brakes now, or non-power brakes? Power brakes were optional until '75.
Drilling drums dates back to probably the 40's for racing. Similar to drilling rotors for better cooling. However, they will warp easier if they get to hot.
But if I was you, with a truck as nice as yours, and with that much power, I would be going disc asap. It doesn't cost that much. And could mean the difference between rear ending somebody and stoping short of doing so.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 01-31-2012, 10:45 PM
blakeusa's Avatar
I just found this on drilled drums. Cost is 30- bucks or so per drum
http://www.chtopping.com/CustomRod4/
I also guess I need to read up on a disc brake conversion and what is a good way to go without replacing the axels
Want to keep my 5 lug rims.
Old 02-01-2012, 01:15 AM
mathman's Avatar
mathman mathman is online now
The '78 J-20 had the dual diaphragm, the J-10 had the single.
David
'78 J-10; '78 J-20 8400GVW
'79 Cherokee
'50 Willys (not Willy's) 4WD Pickup
Old 02-01-2012, 08:22 AM
lkmarsh's Avatar
lkmarsh lkmarsh is offline
What front axle do you have now? Ford and Dodge used five lug hubs and rotors. The Ford parts are supposed to bolt up to a D44 open knuckle. Don't have one so I don't know for sure. I do know they don't fit a closed knuckle.
Lyle
68 Chevelle wagon 350/BWT50
68 Impala wagon 327/400
04 Impala LS - Wife's DD
http://s726.photobucket.com/albums/ww267/lkmarsh/
Old 02-01-2012, 10:36 AM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
You want a booster from a J20 to get the dual daiphram. J10's didn't come with them. The dual is physically larger, you can tell by looking at them.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 02-01-2012, 10:44 AM
late model GW boosters are dual diaphragm, and way smaller than the 70's J20 booster.
I installed a '79 J20 booster in my '73, and it Great Googley MoogleyGreat Googley MoogleyGreat Googley MoogleyGreat Googley Moogley near hit the valve cover.
I'd go late model if I was to do the swap again.
Old 02-01-2012, 03:07 PM
Ditto that, you need one from a later J20 or from a Grand Wagoneer.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
1970 Gladiator J3000 3407Z Camper Truck
1963 Gladiator J300 Thriftside
Visit the Land of Off Topic!
http://gwamp.com/offtopic/index.php
Old 02-01-2012, 05:47 PM
donniesoup donniesoup is offline
I did this swap two years ago. Very easy to do. I have 32's and it stops so much better. I got it from autozone. Threw old one in box and got core back
80 chief wt
94 cherokee
11 liberty
Old 02-01-2012, 07:23 PM
Rod2's Avatar
Rod2 Rod2 is offline
I've posted several times about my J4000 brakes, but this is a new point that has come up. Mine came without power brakes, and the manuals were 12" drums. Over the years, I sourced at least 4 vacuum units from late '60's to '80's in preparation to power upgrade. None of them were direct bolt-ins: the firewall bolt pattern didn't match, the push rod was the wrong length, and most frequently, the push rod hole wouldn't fit the post on the brake pedal lever. I don't know what the '71 mounts are like, but they might be more like the '73 than late '70's.
I went with a hydro boost set-up from Elliot that did require redrilling mount holes, kept my drums all around, and my truck brakes are the best power brakes I've ever used.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, Hydro-boost, AirLift bags front and rear, 33x15 Summit Mud Dawgs, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light
Why is it that when I try to download upgrades, I upload downgrades?
Old 02-01-2012, 07:36 PM
Stuka's Avatar
When converting from non-power brakes you basically have to swap out everything. Including the pedal rod, master cylinder, and drill holes in the firewall depending on year. I know my '75 that came with non-power brakes did NOT have the proper bolt pattern for a power booster. Never did do the swap before I sold it, but I had most of the parts for it.
Old 02-01-2012, 09:18 PM
Kenall's Avatar
Kenall Kenall is offline
i have a dual booster from a 78 J20. If your rebuilding your 4000, i bet you cood find a 5 lug rotor, (bronco) slide that over you wheel hub, and fab a caliper mount
Ken's:
1966 Super Wagoneer
350SBC. 2BBl. Th700R4. NP-208. Detroits. 4.27s. 4core. 4Discs. PS,PB,AC,CC,Cassette.
(Soon to be TBI)
1975 Custom Wagoneer
350SBC. TBI. Th400 FT-QT. Opens. 3.54s. 3core. PS,PB,AC,CC,CD.
(Soon to be TH700R4)
dual brake booster for a 75? pb General FSJ Tech 2 10-31-2005 02:55 AM
j10 brake upgrade djmac General FSJ Tech 2 06-02-2005 01:28 AM
79 J10 brake pad squeal? premiumgashog General FSJ Tech 4 12-02-2004 01:29 AM
Power Brake booster..single or dual diaphragm Super Chief General FSJ Tech 7 04-10-2002 07:48 AM
Dual Brake Booster in 87 Wag? reddog General FSJ Tech 3 02-06-2002 09:05 AM
