Old 01-26-2012, 06:38 PM
Tin Medic's Avatar
Tin Medic Tin Medic is offline
401 heads
Is this a good deal? Are they even worth buying?
http://cosprings.craigslist.org/pts/2794053284.html
Hussy - 89 GW 360/727/229, 30x9.5x15 Destination M/Ts, Warn Lock Out Hubs, Razor Grill
Tramp - 85 CJ-7 Renegade FI 258/T5/D300, D30 w/ARB Air Locker, AMC 20 w/Posi Unit, 33x12.5x15 Goodyear MT-R's, Hella E-Code lights, VIAIR OBA System, Warn 8000lb Winch
Old 01-26-2012, 06:42 PM
The Colonel's Avatar
If they are '74 heads they aren't anything special.....same as 360 heads.
You may want to ask for casting numbers just in case they aren't '74's. The '70 & early '71 heads had the smaller chambers.
Old 01-26-2012, 06:47 PM
Tin Medic's Avatar
Thanks, thats what I needed to know.
Old 01-26-2012, 07:39 PM
FSJ Guy FSJ Guy is offline
Still, it's not a bad price if you need them. X2 on casting #'s to make sure they're not the small chamber ones. Otherwise, they're pretty much the same, AFAIK.
Ethan Brady
www.bigscaryjeep.com
Old 01-26-2012, 09:12 PM
Woodchomper's Avatar
Woodchomper Woodchomper is offline
While it is true that 360 and 401s share the same heads, I thought the 74 casting number xxx502 bridged rocker heads were supposed to be a good head that was better than some of the other later bridged heads. Either case, $50.00 for a spare set heads is not a bad price.
1991 GW 401 /727TF/NP229 /4" Skyjacker /EBL TBI /CS-144
1981 J10 401 /727TF/NP208 /6" Superlift /CS-144
Old 01-27-2012, 12:11 PM
FYI...Flow numbers for AMC heads. http://theamcforum.com/forum/cylinde..._topic159.html
Old 01-27-2012, 12:34 PM
3rdelement's Avatar
3rdelement 3rdelement is offline
i have a free set of heads off a 360, just gotta come to castle rock and get them. i'll even throw in 2 pairs of valve covers.
Richard Ricketts
build thread: click HERE
1985 Jeep Grand Wagoneer {woodless}-Edelbrock 1406 carb, Edelbrock Sp2p Intake, Hella ecode headlights, bixenon HID 5000k headlights, mb quart 6.5" component speakers f&r, alpine cde-100 deck, final edition grill, Hella 550 fog lights, 1991 window regulators, cs144, aluminum coolant&washer tanks
Old 01-27-2012, 08:30 PM
Tin Medic's Avatar
Richard, thanks for the parts.
Old 01-29-2012, 09:14 PM
3rdelement's Avatar
Np, nice to meet you.
Richard Ricketts
Old 01-29-2012, 09:21 PM
SC/397's Avatar
SC/397 SC/397 is offline
$50.00 for a set of heads? C'mon guys, those are good heads. Where are they, I will buy them!
Any gotchas AMC heads 401 - 360 1971 up ? badaboom General FSJ Tech 1 01-05-2009 10:20 PM
401 heads on a 360 AngryCromag General FSJ Tech 12 01-09-2006 02:53 AM
a few questions swapping out 360 in 401 roadgrime General FSJ Tech 3 04-03-2004 04:49 AM
casting #'s 401 heads greenchero General FSJ Tech 1 04-27-2002 01:53 PM
