Old 01-17-2012, 05:25 PM
e_digg's Avatar
e_digg e_digg is offline
Leaking Fuel Pump?
I was underneath the car tightening some transmission lines and noticed a gas leak. It appears to be coming from where I have indicated in the circle. Is there supposed to be a bolt or something in the hole?
Thanks
Ed
1991 Grand Wagoneer
My 91 Phoenix Build Thread
Old 01-17-2012, 06:03 PM
Rich88's Avatar
Rich88 Rich88 is offline
No...but it appears the crimp-flange (or whatever its called) may have rusted through or something. OR there may be a weep hole which purpose is to give you early warning the diaphragm is cracked. Don't recall. Regardless, the fix is obvious: time for a new one.
88 GW 360-.030 over/2150/727/229/Posi, e-pump, AC (broke), tow package, Monroe Air Shocks, dizzy manifold vacuum, CTO-Free, AIR-free, oil & tranny coolers, dried knuckle blood all over, GM 350 TBI in a box, waiting...
Old 01-17-2012, 06:22 PM
austinaubinoe's Avatar
are there any US made mechanical fuel pumps available? Was disappointed to find the carter one was made in Korea.
Old 01-18-2012, 07:08 AM
710 Burner's Avatar
Rust? Are we looking at the same picture Rich?
Hard to say from the picture, I think that is the weep hole. No matter. If it is leaking, time for a new pump.
Austin, good luck finding a pump made here. If it was made in Korea, its probably fine. I would expect China or Hecho en Mexico.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 01-18-2012, 07:09 AM
e_digg's Avatar
Thanks for the info! I think this is the correct part.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?A=NFPM6736_0199752966&An=59 9001+101990+50038+2038016+26558&Ar=AND(P_RecType%3 aA)
I'll get it installed tonight along with a new pvc valve. Getting a lot of oil in the air cleaner.
Thanks
Ed
1991 Grand Wagoneer
Old 01-18-2012, 07:27 AM
Rich88's Avatar
Thought he circled the edge of the pump where the two halves of the diaphragm pump are crimped together. I just threw that in there (rust) because it was impossible to tell from the picture where the gas is really coming from. BUt yes, weep hole more likely.
Old 01-18-2012, 01:27 PM
Jayrodoh's Avatar
Jayrodoh Jayrodoh is offline
Nearly lost a car in high school to something like that! Fan blowing all those gas fumes around, not good. Thank god Taco Bell had a fire extinguisher
Might want to change your oil too, when the diaphragm ruptures it will usually leak into the crankcase where the pump arm comes in.
Honey?? What happened to the savings account? You bought a Jeep what??
86 Grand Wag Stock with Bulltear HEI
Old 01-18-2012, 07:38 PM
710 Burner's Avatar
Jay! your'e still alive!
Mark B. Jones
'76 401 Wagoneer
Old 01-19-2012, 07:13 AM
e_digg's Avatar
Got it all done last night. Took under 2 hours with interruptions and such. I would suggest to use a ratchet boxed end wrench to remove and reinstall the fuel line from the top of the fuel pump. The open end of the wrench was starting to strip the nut and I could not get it back on tight enought to keep it from leaking. I removed the filter and slipped the wrench all the way down to the nut without any issues.
Thanks
Ed
1991 Grand Wagoneer
Old 01-19-2012, 10:35 AM
Jayrodoh's Avatar
Yessir, still troll around but don't get much time to log in anymore. Glad someone still remembers me!
Weird Fuel Issue Mr.Wagoneer General FSJ Tech 13 06-21-2011 04:07 AM
Electric Fuel Pump Installation w/ relay leostevo General FSJ Tech 0 03-21-2011 06:07 PM
Fuel pump, pump arm too long? palexand General FSJ Tech 10 10-01-2009 06:19 PM
fuel pump stalling issues westcoastflea General FSJ Tech 8 07-21-2009 08:40 AM
fuel pump for Carberated 360 newtojeeps General FSJ Tech 4 10-12-2006 01:57 PM
