Old 10-03-2011, 08:38 AM
[]V[]AXX's Avatar
[]V[]AXX []V[]AXX is offline
Cherokee Chief vs J10 seats
I still need to work out a pair of seats for my 79 J10. I recently found a small salvage yard that has a badly rusted '83 Widetrack Chief with decent front bucket seats. My question is, will Chief or Wagoneer seats fit in a J10 without drilling new holes?
I want to pull the seats and some door parts. Specifically the inside latch handles and spindles. If there is anything that someone on here needs, I can check this truck for it. If nothing else, I can probably take pics with my phone and provide the address of the yard. Thank you for your time.
Old 10-03-2011, 09:06 AM
halftrac's Avatar
halftrac halftrac is offline
What years are the Cherokee and the J10? I believe that mid 79 and below the floor pan is the same. The later 79 and up, the floor pan will be different. A friend tried to take manual seat bases from a 76 or 77 and tried to put them in a 82. Don't remember exactly what the difference was, but the bases didn't line up right.
JJ
Jackie Jacob
1977 J20, 360 4bbl, 4 spd, utility bed
1978 J 10 258, 4 spd, 3" liftDD,
1988 Wagoneer Limited XJ
and a junkyard full of FSJ parts
Jake's Full Size Jeep Junkyard
www.militaryjeepers.com
Carolina Full Size Jeep Club
http://s255.photobucket.com/albums/h...eeps%20Galore/
Old 10-03-2011, 09:17 AM
[]V[]AXX's Avatar
My truck is a 79. It came with the bench seat originally. The Chief in the salvage yard is an 83 model. I know they went from passenger drop front axle to driver's drop. I wasn't sure if it changed the floor pan that much.
Old 10-03-2011, 09:37 AM
halftrac's Avatar
Is your truck pass or driver drop? If the drop is the same, then, the brackets are the same. Hope this helps out.
JJ
Jackie Jacob
Old 10-03-2011, 09:47 AM
[]V[]AXX's Avatar
No, my truck is passenger drop. The other is drivers. That's why I needed input. I guess the holes and brackets are different, then. Thanks.
Old 10-03-2011, 10:32 AM
If the seats are nice, I'd risk it. They may not bolt up exactly, but I expect you can make them work.
If I get a chance later, I'll compare my '77 and '82 and see if I can find an obvious different.
Old 10-03-2011, 11:18 AM
halftrac's Avatar
Just get a set of brackets from a 77 SJ and use the seats from the 83. I don't think that the seat mounting holes changed where as the floor mount holes and floor contours did some.
Jackie Jacob
Old 10-03-2011, 08:31 PM
[]V[]AXX's Avatar
Well, they are in decent shape. The driver's side is power, so I'd have to rig that up as well. The back seat looks decent too. It's a shame the body is so bad. I was gonna buy that set of brackets from you, Halftrac, but everything came up at once, and I went away for awhile. I appreciate the input. I'm still staggering around trying to put everything back together at this point.
Old 10-04-2011, 04:03 AM
Now Wagon seats set back (lean) causing them to hit the rear window. Ive had two sets of Wag seats in my J10 and they dont fit well.
Old 10-04-2011, 07:29 AM
[]V[]AXX's Avatar
I was afraid of that. The seat I have in it now is one of those cheap, high back buckets from the parts house. It's on a home made bracket. It make the truck uncomfortable for anything more than a quick trip, because it's up against the back window, and can't move.
Old 10-04-2011, 05:49 PM
The ones I have are for an '85 which may not fit w/o modifications. Do you want pictures?
Old 10-10-2011, 01:55 PM
AXX, I need you zip to get a shipping quote.
Old 10-10-2011, 06:14 PM
[]V[]AXX's Avatar
No need to ship. I can come get them on a weekend if that's ok with you.
Old 10-10-2011, 11:47 PM
HOOT's Avatar
HOOT HOOT is offline
The difference is in the mounting brackets only. The center hump changed slightly and when you use the later year style on a 79 and down truck it will cause the seat to sit crooked a bit.
Like mentioned before . Just get a set of earlier brackets and bolt your newer seats to them.
Tom Gibson
1981 J-20 "RED" 360/727/208,R.I.P. Undergoing major retrofit to be a 1980 Utility truck.
Old 10-11-2011, 12:01 AM
cmelo's Avatar
cmelo cmelo is offline
Wagoneer seats in my 79 j10 with the 79 brackets bolted to the seats.
Maybe this helps
79' J10 360/T18/D20- Locked & bobbed on 35s
Old 10-11-2011, 08:02 AM
[]V[]AXX's Avatar
Maybe this helps
Thanks for the pic. Do you have problems getting them to slide back far enough, since they're taller than the stock J10 seats?
Old 10-11-2011, 09:41 AM
cmelo's Avatar
They're all the way back in the pic. I'm 6' and it's OK.
Here's another pic from "my view", the passenger seat is forward in this pic.
Old 10-11-2011, 11:51 AM
I'm available--where are you located?
Old 10-11-2011, 10:14 PM
[]V[]AXX's Avatar
I'm in Orlando, pm me a price and address, and I'll roll down there on Saturday. I have to go to Cleremont anyway, so I'll go to Lakeland and come back to Cleremont.
Old 10-12-2011, 08:46 AM
Sent you PM with price and meeting place.
bucket seats for j10 trucks!! Trey_bo General FSJ Discussion 31 04-04-2010 11:09 AM
TJ seats in a J10 Long&Low General FSJ Tech 4 03-31-2009 05:49 AM
Puttting xj seats in a J10 crow223 General FSJ Tech 2 01-10-2008 05:39 PM
1978 Cherokee & 1978 Cherokee Chief? Indycherokee General FSJ Tech 0 12-03-2006 11:51 PM
78 jeep cherokee chief Nugget General FSJ Tech 7 06-21-2006 09:18 AM
