Old 09-08-2011, 07:12 PM
Castrol ATF+4 or???
Has somebody use it? Because I need to change it and I found it for a really good price...
Old 09-08-2011, 07:15 PM
serehill serehill is offline
in my book
It's good stuff
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 09-08-2011, 07:17 PM
Great! Thanks!
Old 09-08-2011, 08:36 PM
But I notice now that is synthetic, and the one I have in the tranny is not. I can mix them? Or better use another ATF?
Old 09-08-2011, 09:44 PM
robscj robscj is offline
There is no more atf-3 atf +4 took its place no mater which brand you buy it has to be aproved by chrysler
Old 09-09-2011, 08:24 AM
I understand that, but the Castrol ATF+4 now is fully synthetic. I need only change the oil no overhaul the transmission. So I need something that mix with the oil inside.
Old 09-09-2011, 08:47 AM
save your money. put good old dexron III in it. you don't need synthetic in that old school automatic.
Old 09-09-2011, 09:34 AM
Don't mix it!!!!
Even at a good price. I thought you were changing the TF. Get Dexron III be done.
Although I'm running synthetic I would never mix. My tranny was completely rebuilt & started its new life on synthetic. Between the Magnefine filter & the synthetic I expect a long life out of it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-09-2011, 09:58 AM
I can mix Dexron III with ATF? If so it is good, because Dexron III it's cheaper...
I have a 727 tranny, and on the manual it say only Dexron II or ATF, ATF Plus, Type 7176...
Old 09-09-2011, 10:37 AM
III is good
I've done it.
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Holley 4180
4" rusty's springs
Old 09-09-2011, 10:42 AM
710 Burner's Avatar
Yes D3 and ATF together will be fine.
I am using Valvoline ATF+ in my Cummins/A518 to help dissapate heat generated by pulling the boat.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 09-09-2011, 11:19 AM
Ok thanks! But now I have another issue to fight...
http://www.ifsja.org/forums/vb/showthread.php?t=145813
Old 09-09-2011, 11:42 AM
austinaubinoe's Avatar
I toped mine off with a gallon on Valvoline dex/merc when I did my filter and deep pan. No issues.
Castrol Synthetic on sale @ O'Reilley's 12-11-2010 in CO FSJ Guy General FSJ Discussion 7 12-12-2010 09:48 AM
What type/brand of oil in new engine ????? 380tom General FSJ Tech 17 07-30-2009 09:31 PM
Where can I get castrol syntorque? JeepsAndGuns General FSJ Tech 10 12-04-2004 04:29 AM
castrol syntec blend 15w-40 THEWOODY General FSJ Tech 7 03-17-2003 11:19 AM
Marvel Mystery Oil - silly question leila General FSJ Tech 43 07-12-2002 04:18 AM
