Hi friends....
after being turned on for a bit my headlight switch gets hot. Hot to the touch. Never so hot that it'll burn me...but its definitely beyond just being warm. I can feel it in the shaft of the pull knob but also on the dash board and on the threaded washer that holds it in.
Maybe related or unrelated...but my headlights still flicker sometimes. After say 20 minutes of being on all lights interior and exterior will flicker and go out and on and out, but if I shut the switch off and turn em back on now they are instantly better....for another 20 min.
That being said....I have taken apart the whole nose of the jeep and cleaned all the grounds patched any splits in the wire coating, etc. I have replaced the dimmer and the headlight switch.
I know resistance causes heat....is my next step using some electrical component cleaner on the plug at the switch and the plug at the firewall? Not sure where to go from here.
