08-09-2011, 07:14 PM
New to the full size Jeeps
I came across this site while trying to find some parts for a Jeep J20, and it appears there are some fans of the full sizes here. I am going to be getting within the next couple weeks. I am new to the full size Jeeps, but have been around the CJ's a bit, but the TJ Wrangler more. I have been trying to find replacement parts, but I am having some troubles. Is there anywhere that I can find OEM replacement parts, or comething comparable? I will need things like the tail light lenses, and the drivers door latch. Do the parts from the Cherokees swap over? Any direction would be helpful.
I am also curios about something--it has the 360 in it, and in troubleshooting an issue with the truck not staying running, they added an electric fuel pump(don't know why). This has to be turned on manually, and I am not fond of that. Would it be smarter to just get rid of that and go back to the mechanical pump?
here are the particulars about the truck, as it sits.
1977 JEEP J20 3/4 ton pick-up
44740 miles
8400# GVW option Camper Special package
4 speed standard transmission
360 CID engine
2 barrel carburator
axel ratio 3.73/1
free wheeling hubs (lock-out)
rear trac-lok differential
power steering
power disc brakes
fuel tank skid plate
heavy duty springs, front
cigar lighter
camper package
950 x 16.5 extra grip tires 856
front wheel hubs
plow lights
Trail.Blazer 20 gallon extra gas tank
WARN winch (electric) (2 way motor)
8000 lbs.
cap
Thanks for the help.
08-09-2011, 07:46 PM
Welcome
Check out Z &M Jeeps and BJ offroad. Tons of FSJ parts there
77 J20
09 Rubicon Unlimited
10 Challenger SRT 8 6 Speed
11 Grand Cherokee Overland
Wisconsin Speed and Performance
08-09-2011, 07:50 PM
Sounds like a nice J-truck you got there. I can't help you with your fuel pump question but it's nice to have you aboard. Welcome form Winder Georgia.
Oh, and this would come sooner or later...
You can teach what you know but you can only reproduce what you are.
It makes sense if you don't think about it.
Brad B.
08-09-2011, 07:53 PM
J- Just
E- Empty
E- Every
P- Pocket
77 J10 honcho with levis interior
AMC 360
4 speed
Warn 8274 winch (8,000 pounds)
Welcome aboard from Michigan
You have a big FSJ parts place right next to you
ZM Jeeps in Maumee,Ohio
We have Meet/Greets there
1990 Grand Wagoneer.. black with sand interior.. 70,000 miles,
Razor grille, Hella H4 headlights, Piaa driving, LED taillights, tinted windows.
custom full length center console with cup holders.
On the road again
08-09-2011, 07:56 PM
x2!!
1983 Jeep Cherokee Laredo - The "SwackMobile"
2005 Jeep Grand Cherokee Limited - The "Buford Bus"
2011 Dodge Ram Outdoorsman (the player to be named later)
08-09-2011, 08:22 PM
Welcome from Ohio!
Pick-n-pulls are going to be your biggest friend for things like tail lights and stuff. Be sure to check the sale section here, or even post up a wanted thread.
BJs is great for some things like door seals, rear slider window, and a bunch of other stuff. Z&M has a ton of stuff too but I've not dealt with them yet.
And yup. We're going to need pics.
08-09-2011, 10:30 PM
Welcome from Arkansas
Glad you are aboard with us here. Big Jeep wave from Aransas.
Sounds like you got a nice rig there so no pics yet  .
Don't be shy.
91 Grand Wagoneer " Final Edition"
DeWooded
6 inch Hellcreek lift.
Rhino Grill
Holley 600cfm
08-09-2011, 11:02 PM
Welcome from North Carolina. I seem to remember seeing that one for sale on jeeptruck.com yesterday. Right about here I think it was http://www.jeeptruck.com/sale/ad212/ad212.html Congratulations.
08-09-2011, 11:03 PM
Welcome from California! Its been said before, but I'll say it again. Pics please!
Andy
'81 Cherokee Laredo W/T 258/Weber 32/36 DGEV/HEI/176/208 AMC 20/Dana 44 3.31 gears
Status: Running strong Miles: Less than 140K (as of the talk with the original/previous owner)  "The Jeffrey"
Build Thread: http://www.ifsja.org/forums/vb/showthread.php?t=151814 New pics: 5/18/12
08-10-2011, 01:12 AM
Welcome and good luck with your project.
08-10-2011, 01:36 AM
Welcome from NY! What are the characteristics of the non-running problem? Sometimes issues with the fuel delivery system result in an electric pump being installed as a fix. It may very well work, though I'm not terribly fond of it, but there's nothing wrong with leaving it if it doesn't leak or anything, might come in handy as a backup one day. I would make sure your mechanical fuel pump is in good shape and that the fuel lines are not rotted or kinked, and that the steel line running from the fuel pump is not lying directly on top of the intake manifold, where it and the fuel filter get rather hot and may cause the fuel to start boiling (vapor lock).
08-10-2011, 06:33 AM
Welcome to the land of empty pockets and unfinished projects...
08-10-2011, 07:26 AM
Welcome from SoCal.
08-10-2011, 10:36 AM
FINALLY another J-truck!  Getting nervous with all these Wags around here.
I would run the electric fuel pump off the ignition so it turns on/off when the key is turned.
Welcome from New Jersey!
JR
1966 mustang fastback
'07 Dodge Charger 3.5
08-10-2011, 10:41 AM
Welcome from Georgia!
You have a 99.847% chance of, at some point, wanting to crush, destroy, vandalize, set on fire, plant a bomb on, or shoot your Jeep. When you feel that way, come here before you do anything. We are here to help  .
08-10-2011, 10:42 AM
Welcome from sunny las vegas!
Originally Posted by FSJunkie
The Mag - The Wag
08-10-2011, 02:45 PM
'Nother welcome from North Carolina.
Jake's junk yard in our Blue Ridge Mtns has tons of old FSJ's ready to be harvested of parts. And, yes, the mountains are cooler this time of year.
There's a link to his site on "Look here," then, "Salvage & parts yard," then "Sticky: a salvage yard section in the forums," then "halftrac." (#9) She has a Photobucket link to their collection plus contact info.
Happy hunting; glad you're here.
Rod Skaggs
'73 J4000 'WOOD GO' 360, 2100 MC, T-18, D-20, 60-2 rear, D-44 closed knuckle front, Eaton E-lockers both, Pertronix module, AC, PS, Hydro-boost, AirLift bags front and rear, 33x15 Summit Mud Dawgs, Pacer 15x8 aluminum Bullet Holes, Summit line lock, 3rd brake light
Why is it that when I try to download upgrades, I upload downgrades?
08-10-2011, 04:00 PM
Welcome from Connecticut!
Ohio eh? IIRC Toledo was one of FSJ's main production sites
1997 Jeep TJ AMC 150 2.5L, AX-5, NV-231 Status: ALIVE
1983 Jeep J-10 AMC 258 4.2L, Holley 2bbl, HEI, T-177, NP-208, 4" Rusty's Spring Lift, CherryBomb haha Status: ALIVE
1976 Jeep J-10 AMC 360 5.9L, TH400, Quadra-Trac Status: SOLD! to The Dude
Durham, CT
Originally Posted by Julep4000
Kudos, sir... I didn't plan on coffee coming out of my nose today.
08-10-2011, 07:10 PM
Originally Posted by Chris_Hoyt
This would be the truck. I do not have onwership at the moment, I am taking the pine tree down in partial trade for it, and won't actually have it for another week or two.
Thanks for all of the feedback and input, the vaporlock sounds like the most likely candidate at the moment. I know that the fuel line leak when the pump is turned on, but I believe that is due to the truck not being running at the time. Once I get it home, I will take a closer look at it.
I live right near the people who are selling the truck, and have been working on them for about 3 years trying to buy it. The body is super solid, one rust hole under the driver's feet, the rocker's(always bad in Ohio), and just the back of the rear wheel openings.
Once I get it home, I will post up some pics.
Thanks again.
