Old 08-09-2011, 07:18 AM
shaggywaggy88's Avatar
shaggywaggy88 shaggywaggy88 is offline
Holley 4160 DIY Truck Avenger
While ive been looking for the right carb to throw on my stock 360 ive done alot of hoping and dreaming about a holley truck avenger. Everywhere i look they are out of my price range so I stopped looking for a TA and started looking for a carb that shared the characteristics that make the TA good offroad. Side hung float bowls is the first and formost feature because that is one feature that cant be changed on a carb. I chose 600cfm because I hear alot of guys say that they run the 470cfm on mostly stock 360s off road but complain about the top end power being simular to a 2bbl. But everyone running a 650cfm offroad wants the low end grunt back. 600cfm seems to be a healthy compromise for a good mix of street driving and trail. Adding a fuel bowl vent whistle and connecting the vent tubes with a copper tube will keep fuel in the bowls in off camber situations. the 4160 i picked up is a single feed carb with vacume secondarys just like the TA. this carb seems to be as close as I can find to having all the goodies of a TA. the ONE big difference and i know its a big one, The annular boosters in the TA still give it the advantage over my DIY idea. But if anyone else is looking for a carb to run on the trail the holley 4160 is a good place to look if you cant afford a truck avenger. thanks for reading and I hope some good info can be gleaned from this post
88 Grand Wag:
Razor Grille
Rusty's 4" spring lift
BJs HD 1" shackles
31" M/Ts
Holley 4160, 600cfm
T.F.I.
Warn Hubs
SOLID Diff cover
999 X-member/T-case Skid
Rag joint delete
Old 08-09-2011, 11:18 AM
How about a Motorcraft 4100? It's an old carb, but it should have similar off-pavement characteristics to the 2100. It was used on big black Fords back in the 60s.
Or the perennial favorite - a Rochester Quadrajet, adapted to the manifold.
Old 08-09-2011, 03:08 PM
Nothing against the motorcraft 4100 but the 2100 on my jeep now sucks. Ive rebuilt it and it still wont start in the morning. offroad it does pretty good. Im sticking with the holley, Ive heard of alot of tuning issued with the Qjets and id rather stay away from them for now. Holleys have tons of parts to fine tune your carb and there is alot of tuning info readily available. Pluss the truck avenger is the only carb i know of designed for off road applications. so I figure if I mirror the principles used for the TA on the most similar carb to the TA that in the end ill come out pretty close to the performance of the all mighty Truck Avenger (with $200 left over to blow as i please).
88 Grand Wag:
Razor Grille
BJs HD 1" shackles
31" M/Ts
Holley 4160, 600cfm
T.F.I.
Warn Hubs
SOLID Diff cover
Rag joint delete
Old 08-09-2011, 03:33 PM
thatguy
Posts: n/a
Im curious to see how it works out for ya, since you are local and all!
holley truck avenger vs edelbrock? thomastenn General FSJ Tech 7 10-24-2008 03:15 PM
Holley Truck Avenger Carb. trail mule Off-Road FSJ Tech 9 09-27-2007 05:14 PM
Holley Truck Avenger Carb: Need Linkage Part Numbers & Ideas Rompn General FSJ Tech 19 03-18-2007 11:10 PM
holley truck avenger decision once again rusty401 General FSJ Tech 3 01-26-2005 05:17 AM
Holley Truck Avenger Carb timmirvin General FSJ Tech 4 01-30-2003 11:45 PM
