Old 08-07-2011, 08:52 PM
Myke Honcho's Avatar
Myke Honcho Myke Honcho is offline
Question My J4000 and the debacle begins
Ok let me start by filling u in on where I am. I recently bought a 72 J4000. For those who don't know its a 2bbl points ignition setup. The debacle comes in that the motor is missing all of the ignition as well as a few other parts. The wiring is chopped and missing connectors.
Now on to the questions. Would it b better to just locate the replacement parts or to upgrade to an electronic system or just do a GM TBI swap?
Once again let me say there is nothing left of the original ignition. Some help here would be great.
Btw, the truck is going to b a play toy only and I fully intend to make a truggy out of it eventually. Just need to get it running so I can move it around but don't want to redo small projects. However, making it move is my top priority and making it cheep.
Thanx guys
72 J4500, 360 th400, d20, d44s
Old 08-07-2011, 08:59 PM
W/O a core dizzy to turn in it may be a bit expensive but the distributor and ign ition is nothing exotic. It's a Delco brand points distributor avail at Napa and prolly other parts houses. It is AMC specific though.
-Geoff Hill
Old 08-07-2011, 09:05 PM
jpcoutts's Avatar
jpcoutts jpcoutts is offline
If the engine harness has been hacked-up you'll need to have a wiring diagram handy to do much of anything. They're available on-line at a member's site. Do a search for FSJ wiring diagrams. Maybe somebody else will chime in with the addy.
Jim C
'67 J3000 Dually
'86 J20
'79 CJ5(in pieces)
Old 08-07-2011, 09:06 PM
That's what I was leaning toward but keep in mind I have to completely rebuild my harness also. I'm just not familiar with amc engines
Old 08-07-2011, 09:09 PM
I have some diagrams np. Just trying to find a starting point.
Do u think it would be better to upgrade it while it's pretty much not there?
Old 08-07-2011, 09:20 PM
http://oljeep.com/gw/elec/GW_wiring.html
edit: If it were me I run the stock points stuff. But I'm prolly the odd soul on this forum that likes points. Solid, reliable, easy to service etc etc. Yeah ya don't get the super pooper mega magazine spark the advertisers tell us we must have but they work well unless you're racing for money and 1/100's of a second counts. I kept the Delco in both my 72 and 73 trucks and never saw a need to go electronic.
-Geoff Hill
Old 08-07-2011, 09:30 PM
The PIG Smith's Avatar
King Browless
Zack at ZM Jeeps can set you up with an awesome wiring harness.
Bryan Smith
1982 J10: Replacement engine now sitting in the truck! No Cab Brow! Future DD
Originally Posted by Jayrodoh
Originally Posted by Lindel
because Ristow sez so
When the IFSJA forum has a problem go here:
www.fsjnetwork.com
Old 08-07-2011, 09:51 PM
twisted frame twisted frame is offline
If you're planning on upgrading then it I'd say now is the time to do it. I have the stock distributor in my 73 J4000 and it's fine for me. Upgrading to a quality HEI setup won't be cheap though and you did mention cheap.
Maybe post up in the wanted section that you need a wiring harness, or at least a harness that will cover everything in the engine bay. There's always a few 70s rigs being parted in the Parts and Pieces section on here and I'll bet you could get a distributor and underhood wiring pretty quick from someone. The only difference is that you might find the mid-late 70s Duraspark distributors more common. Maybe/maybe not...but worth a look.
Mike
1973 J4000, 360 2bbl, T18, Model 20,
44, 60-2, 32x11.5x15" on 15x8" CJ wagon wheels.
Now in black primer.
Old 08-08-2011, 05:40 AM
Thanx guys for the replys
Old 08-08-2011, 05:50 AM
I'd stick with a stock points set up myself. All of the vehicles my father and I have around where with electronic ignition have had some sort of EI related problem at one point or the other.
Can't remember ever having trouble with a points distributor that a little sand paper didn't take care of.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
1970 Gladiator J3000 3407Z Camper Truck
1963 Gladiator J300 Thriftside
Visit the Land of Off Topic!
http://gwamp.com/offtopic/index.php
