Old 07-27-2011, 05:44 PM
Crist Clapper's Avatar
GW: What is this? (#1)
What is this? What does it do? And where does it go? Thanks!
http://i873.photobucket.com/albums/a...apperc/TH1.jpg
1990 Grand Wagoneer:
1987 XJ Wagoneer XJ Limited:
Desiree - def: “Much Desired” [orig: French] Desirable Charcoal Gray façade, Wood-grain vêneers,and Tan Leather éssentials"
2007 Liberty
2007 Commander
2008 SRT
Old 07-27-2011, 05:47 PM
whowey whowey is offline
That is a vent. Follow the hose attached to it, to find where it goes. Its for letting air in and out of whatever is on the other end of it.
1990 GW cruiser/tow rig
CS-130 coversion
Old 07-27-2011, 05:51 PM
probably the front axle vent
Old 07-27-2011, 06:24 PM
serehill serehill is offline
yup
Bolt it up any where they usually go on the inside left fenderwell.
Old 07-27-2011, 06:26 PM
mdill's Avatar
mdill mdill is offline
The stock location was the left side top radiator mounting bolt, tube should go to the front axle.
Home of ADHD project list
1977 J-10 Honcho 360-T15-D20
Old 07-27-2011, 06:27 PM
Chevelleguy's Avatar
Front axle vent, bolt to the upper drivers side of the radiator mount.
mdill beat me to it.
Old 07-27-2011, 06:37 PM
Here?
http://i873.photobucket.com/albums/a...rc/bracket.jpg
2007 Liberty
2007 Commander
2008 SRT
Old 07-27-2011, 06:46 PM
Danbert's Avatar
Danbert Danbert is offline
No. it should be on the side bolts that hold the radiator to the core support.
At least that is where mine is at.
'83 Wagoneer LTD.
Vacuum elimated Dana front axle
Building stereo, window tint, roof rack, light bar, and other projects currently underway
Old 07-27-2011, 06:49 PM
I'll look tomorrow... Thanks!
BTW: Do you know what goes into the photo'd bracket?
2007 Liberty
2007 Commander
2008 SRT
Old 07-27-2011, 07:19 PM
The Colonel's Avatar
Nothing is there on my '89.
Old 07-27-2011, 08:49 PM
Mark Wilde's Avatar
Mark Wilde Mark Wilde is offline
Correct. That's inside the engine compartment. If it's routed to the area between the grille and radiator, it shouldn't be.
90 Grand Wagoneer, 401/727/229, TFI upgrade, MC4350 4V, Edelbrock Performer cam, All-Aluminum Radiator, Razor Conversion, 4" Rusty's all-spring, 31x10.50 BFG TA/KO's...much planned, little time/money, thus she's a PipeDream!
Status: Up and running, but needs attention....
Old 07-28-2011, 11:33 AM
1jeep4me's Avatar
1jeep4me 1jeep4me is offline
bingo
Jenny SOLD
1982 Cherokee Chief Wide Track
4 inch lift
360 ci Edelbrock carb and intake
115K
Daisy
1970 Wagoneer by Kaiser
350 Buick/Turbo 400
3.73:1 Limited slip
41K original miles
Lilly
SOLD your a good girl LILLY!
1973 Commando by Jeep
304 2V 3:73 Limited Slip
3 Speed
93K original miles
