Old 07-11-2011, 06:57 PM
Eric S. Eric S. is offline
refreshing old rubber part (not FSJ related)
I need a little advice from the collective mind at FSJ. I'm fixing some air valves on my inflatable kayak. They all have slow leaks. I think it has to do with the spring tension, but I noticed that the rubber gaskets are also a little stiff. Not brittle, but not as soft as I'd like them to be. I went to Napa, Lowe's, and Tractor supply and no one carries similar gaskets (they look like black garden hose washers, but a slightly wider/thicker dimension). So I'm going to try and give them a little spa treatment to see if I can make them feel younger again. My plan was to scrub them with a toothbrush in soapy water. Is there anything I can soak them in to get the rubber spongier again?
Thanks!
Eric
1989 Grand Wagoneer -- FOR SALE
Old 07-11-2011, 11:39 PM
So the answer to tonight's trivia question is (drumroll please...) an hour-long soak in WD40. The gaskets are soaking right now, and they're coming back to life. I will probably leave them in for another hour.
I also read that transmission stopleak has a nice way of making old rubber swell up again.
Old 07-11-2011, 11:54 PM
jeeper54's Avatar
jeeper54 jeeper54 is offline
I've heard about brake fluid making rubber swell but have never tried it myself.
Currently without
Formerly
1986 G.W. 360
1986 Eagle Wag
1985 G.W. 360
1984 Eagle Wag
1981 Wag 360
1978 Wag 401
1981 Cherk W/T 258
1966 Wag Super 327
Not counying XJs'.
Now have the FSJ blues!
Old 07-12-2011, 12:47 PM
the WD40 definitely gave it some life/fexibility back. There's probably a better way to do it (never thought of brake fluid), but I reccommend this if you don't have access to anything else.
Old 07-12-2011, 03:11 PM
FSJ Guy FSJ Guy is offline
If anything, WD-40 will make them smell nice.
I wouldn't recommend brake fluid. It eats away paint. Although you could argue that it doesn't eat away rubber brake seals in the pistons.
Ethan Brady
www.bigscaryjeep.com
Old 07-12-2011, 05:53 PM
autoarcheologist's Avatar
autoarcheologist autoarcheologist is offline
Silicone? There's a product that BMW recommends called "Gummi Pflege" which looks like it should translate to "snot" but is close to "Rubber Care". It's recommended to keep rubber door seals flexible, but I've never tried it. I'll have to try WD40, the petroleum distillates must soak into the rubber. Wonder how they'll hold up?
Looking for Jeep enthusiasts to check out Jeeps and other classic cars and trucks for potential buyers. Learn more at www.jewelorjalopy.com
1973 Jeep Wagoneer Custom - 360 4V
1974 Alfa Romeo Berlina
1966 Shasta Compact - 13'
1966 Streamline Countess 26'
Old 07-12-2011, 05:54 PM
TexTJ209's Avatar
TexTJ209 TexTJ209 is offline
I've heard soaking in that 303 Rubber Protectant stuff works well.
'05 Chevy Silverado CC Duramax - The DD.
Texas A&M Offroad
QT Post of the Day: Part Time kit and other questions... shiner2001 General FSJ Tech 18 11-01-2009 02:48 PM
Part number cross over cdlongjr General FSJ Discussion 1 10-24-2009 08:39 AM
What part is this / Help diagnose por favor!? JonesinForAWaggy General FSJ Tech 16 10-04-2009 09:26 AM
1310 - 1350 u-joint part number Blake Off-Road FSJ Tech 13 08-27-2009 09:14 PM
Help with a broken 727-just found a loose part in the pan No_Ecm General FSJ Tech 7 08-07-2003 01:24 AM
