Old 07-10-2011, 12:21 PM
JeepsnCellos's Avatar
JeepsnCellos JeepsnCellos is offline
NP 229 - Does it have a Differential or Not
The question is - Does an NP 229 have a differential?
Obviously, a differential is anything that allows differential motion between the 2 outputs, so in a way the VC is a differential. But I'm talking about a real gear-to-gear differential.
Looking at the exploded view here http://www.bjsoffroad.com/CartGenie/image.asp?pid=1121 has not helped me much. I can't seem to follow the flow of power through the dissected views.
And reading the last few comments in this old thread
http://www.ifsja.org/forums/vb/showthread.php?t=73356&highlight=NP+229+differenti al has piqued my interest.
I've read that the difference between the NP228 and NP229 is that the VC replaces the differential in a NP229. However, if that is true, then I agree with GWChris' argument as follows.
"Without a mechanical diff, you would have to drive one axle directly (like some of the cheap 4WD systems), and then the viscous coupling would send a little tourque to the other axle if there was a speed difference between them.
That's not how this works. It has an open diff with a viscous coupler in addition. If you drain out the secet fluid, then you just have an open diff left and it works like a NP228."
My NP 229 does not operate as if there is simply a VC in the front shaft. I do not have to have slippage in the rear wheels to get torque at the front.
Is the VC more complicated than just a set of parrellel plates in silicone fluid? Does it also have a mechanical differential function with the plates making it a limited-slip?
Can someone please shed some light on this? It's driving me crazy (and that's a short trip).
Thanks
Old 07-10-2011, 12:37 PM
serehill serehill is offline
Gone,Never Forgotten.
well
Google NP229 operation
The NP228/229 transfer cases were Jeeps first transfer cases to receive the "Selec Trac" name, the later Selec Trac transfer case being the NP242. Both the NP228 and NP229 offer 2 wheel drive, Full Time 4 wheel drive in High range and Part Time 4 wheel drive in Low range. The NP228 uses an open differential for its front/rear power split in 4WD Fulltime High, the NP229 uses viscous coupling for its front/rear split in 4WD Fulltime High. Both lock the front/rear output shafts in 4 wheel drive in Low range. Both lack a 4 wheel drive Part Time High range mode.
Old 07-10-2011, 05:55 PM
Thank you for the reply Serehill.
However, I understand the basic function of the NP229 (how to shift, not to use low range on hard surfaces, etc). What I'm curious about is the exact function of the viscous coupling in the drive train. I believe it acts the same as a clutch pack in a limited-slip differential. But then there are some who swear the NP229 doesn't have a differential.
So I guess I'm looking for more gritty details from someone who has had one apart.
I searched on Google and this forum and just couldn't come up with the explanation I'm looking for.
Thanks again.
Old 07-10-2011, 06:06 PM
yes. there is a diff. the VC prevents it from free-wheeling. the VC does not REPLACE the diff in the case.
Old 07-10-2011, 06:30 PM
Chevelleguy's Avatar
There is NO differential in a 229, the viscous coupling is IT.
The 228 DOES have a differential and no viscous coupling.
Old 07-10-2011, 07:39 PM
FSJ Guy FSJ Guy is offline
I've seen the guts of my 229 that was destroyed by a tow truck driver. (But hey, I'm not bitter!) It looks like a differential to me.
Ethan Brady
www.bigscaryjeep.com
Old 07-10-2011, 07:43 PM
Look at this break down. http://www.bjsoffroad.com/CartGenie/image.asp?pid=1121
There is no diff in there. And I'm not just going by the pic, I have had mine apart too.
Old 07-10-2011, 08:08 PM
it's been a long while since i was into one that deep. but as my fuzzy memory serves,in the VC case,were spider gears engaged by stubs #2 and #6.
Old 07-10-2011, 08:24 PM
No, the only thing in the coupling is shear plates and silicone fluid. That is what you take apart and 'pin' in my 10$ fix.
Old 07-11-2011, 09:37 AM
Ristow Quote - "it's been a long while since i was into one that deep. but as my fuzzy memory serves,in the VC case,were spider gears engaged by stubs #2 and #6."
That explanation would make sense and fits with the way the 229 behaves in my opinion.
Chevelleguy,
I've never had one apart so I'm willing to believe you when you say the VC assembly doesn't have spider gears in it. But can you explain the flow of torque here? It looks to me like the VC is actually connected to the rear output. It is not possible that all of the power delivered to the rear wheels is transferred via the plates of the viscous coupling. Can you give any details as to the exact role the VC plays?
Anyone else want to weigh in?
Old 07-11-2011, 10:25 AM
Billygoat's Avatar
Here is what I know about VC's for industrial applications they are used to REPLACE a differential. The "fluid" is heavy enough, that if there is no torque difference there is not slip, so you have 50/50 split, but when you get a difference the VC allows for different speeds of the 2 shafts (slip).
A differential transfer torque, a VC allows different speeds between objects with a common driver, a limited slip in a differential tries to keep the torque close to 50/50 split even with unequal load on outputs, where an open differential will transfer 100% torque to the output with the least load.
Now, based on that a 229 can have the VC "burn out", and not turn the front drive shaft, you can then pin the VC and have 50/50 split like other part time cases.
Based on that the 229 DOES NOT have a true differential, it just uses a VC to allow for variance in drive shaft speed.
Old 07-11-2011, 12:38 PM
That is the down side of the 229, in 4HI only, all power does go throughout the coupling. The coupling is locked out in 2WD and 4LO. With a bad coupling, the truck will not hold 'park' in 4HI.
Old 07-11-2011, 03:35 PM
well,my fuzzy brain was insisting it remembered digging those rollers out of the differential in the VC.
so i did the only thing i could think of to be sure. i opened up an old 229 i had laying around.
the VC.
and upon removal we see.....
if that aint' a differential......you can slap me silly and call me Shirley.
Old 07-11-2011, 03:49 PM
Wonder what would happen if you welded that up?
(just wondering, don't actually own one)
Old 07-11-2011, 04:24 PM
Rich88's Avatar
Rich88 Rich88 is offline
Sigh...I'm probably one of the 934+ people that are now confused beyond redemption. Let's try to get this answered for idiots like me with a simple question that hopefully addresses end results that matter to the driver.
With a 229 and no other mods:
1) When I'm running up or down a slippery road in 4WD High, whether its due to rain, mud, sand, snow, or ice, am I correct in that I can rely on at least one tire in the front and one tire in the rear will always have power to it? Yes/No?
I say "one tire" front or rear because we also have the front and rear differentials doing their thing too. And in this case we really have "2WD" because we're not locked. Yes/No?
2) But wait: If one has Limited Slip Differential in the rear (which I do), then I really have 3WD because both the rears will provide drive, but only one in the front will provide drive. Yes/No?
Old 07-11-2011, 05:03 PM
Well, I guess my brain was fuzzier than yours Ristow. RISTOW WAS RIGHT, AGAIN!!!
I don't remember seeing that part when I had mine apart. See how the side gears engage the clutch plates? It has to have the friction of the silicone fluid and the shear plates to transfer power. When all the fluid leaks out, you will have slippage or , if it is burnt real good, no forward movement in 4hi. That is why I tore into mine, it made a mechanical whine and had slippage, reduced forward motion, in 4hi.
I have had to go into one that wouldn't hold park and had no movement in 4hi. Replace with a good used coupling and it was fixed. Mine, I just pinned the coupling so now there is no differential action.
Old 07-11-2011, 05:05 PM
No need to, you can just pin the plates in the coupling.
Mike, go ahead and pop the cover off the coupling so everyone can see the shear plates inside. Please.
Old 07-11-2011, 05:09 PM
i have a very persistent,fuzzy brain......LOL!
Old 07-11-2011, 05:16 PM
chef chef is offline
the VC.
You are definitely not Shirley, you are a good man for actually proving your point.
See build here
http://www.ifsja.org/forums/vb/showthread.php?t=125460
Old 07-11-2011, 05:17 PM
no pressure or spring in there to surprise me?
Transfer case swap : NP 229 out, NP208 in? wickedwagon767 General FSJ Tech 15 10-31-2015 10:21 PM
np 229 and np 228 matt vannucci General FSJ Tech 6 01-03-2009 03:30 AM
NP 229 and Lockout Question, Just Confirming 80wag General FSJ Tech 7 08-26-2008 03:36 PM
HELP grenaded another NP 229! Jonathan M. General FSJ Tech 4 06-06-2008 11:11 AM
