Old 06-30-2011, 07:39 AM
Greenfish Greenfish is offline
Brake upgrades Front and rear GW
Ive been sifting through old post trying to make some sense out of brake up grades for grand wagoneer with D44 (6 lug). Aside from the HB upgrade, I would also like a rear disk upgrade and if it's easy and cheap larger calipers for the front.
Is there a parts list for rear disk brake conversion that I can scrounge the junk yards for parts?
My understanding is also that a 3/4 ton chevy truck caliper will work for a caliper swap on the front. Which year truck do I pull from? Do I need a caliper mount as well? Does that work with the Chevy or Jeep rotors?
what else do I need to know before I get going?
Baltimore
1991 Grand Wagoneer, Rebuilt 360, Eddy Perf Manifold, Razor Grill
1970 Plymouth 'Cuda (my baby)
Old 06-30-2011, 07:55 AM
Just a thought, there is this kit from SSBC its is crazy expensive and its for a 5 lug. Here is my thoughts. This kit looks like it uses a caliper off of something else that you could find in a junk yard. I doubt they engineered a brand new single piston caliper for a D44. If I could figure out what caliper that is I could probably order the parts without the caliper. The 6 lug rotors could probably be sourced from the local auto parts store as well if I knew which ones to grab. same goes with the backing plate. The rest is all brackets, bolts and hoses. I could probably even order the brackets and take them down to my buddy who has a machine shop and he could make them for me. I could then send back the ones from SSBC.
So.. can anyone figure out what parts they are using?
http://www.ssbrakes.com/commerce/search/
Baltimore
Old 06-30-2011, 08:03 AM
Thoughts on this?
http://cgi.ebay.com/ebaymotors/ws/eB...m=250508366128
Baltimore
Old 06-30-2011, 08:23 AM
Topgun2mo Topgun2mo is offline
You lose emergency brake capability with that setup.
Mike Morgan
Slidell, LA
'90 Grand Wagoneer
SOA, CUCV 14 bolt rear, 4.56 and Detroit, Looking for HP Dana 60 for front, 1" Body lift, 44044 Rancho Springs up front, Dodge 4x4 Rear leafs and shackles, BJs 1" lift shackles in front.
Old 06-30-2011, 08:26 AM
Not sure ive ever used my E-brake anyhow. With an auto trans do you really need it?
Baltimore
Old 06-30-2011, 08:29 AM
addicted's Avatar
addicted addicted is offline
Big Meanie
I used the front calipers for an '82 Chevy/GMC 2500 along with the bigger pads. The set I got had to have the casting ground down around the banjo bolt hole to clear the factory front hoses on my '89. I got a set of 2wd calipers when I ordered the 4x4 calipers that are supposed to have the proper clearance. Apparently the remanufacturers of the calipers don't see them as being different for 2wd or 4wd.
Those ebay weld on brackets will be the cheapest way to go if you can weld or know somebody that will do it cheap. You can use the cheap front chevy calipers for no parking brake or the much more expensive Cadillac Eldorado rear calipers to retain the parking brake. I believe the front rotors from a late 80's to late 90's Chevy/GMC 1/2 ton 4x4 truck will work with that bracket and caliper set up but I might not be remembering correctly on that part.
Originally posted by Ristow
i bet it was Simon....
Old 06-30-2011, 09:08 AM
jeeping1974's Avatar
Not if you use calipers with the built in e-brake.
I heard that you can swap over a 3/4 ton caliper to the D44 but I thought they were the same. If the 3/4 ton rotor is larger than the standard D44 set is, you can run that. Yes it's 8 lug and won't match the rear but i've got a 44/60 hybrid rear axle that you could swap your rear 44 gears into and install a D60 disc brake setup on.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 06-30-2011, 09:16 AM
I know that BJ's sells a rear disc conversion setup that you can swap in on the rear.
Another thing to look into is a ZJ with a rear D44. If the brake mounting bolt pattern is the same, you may be able to run that with a 6 lug rotor. You may have to source some parts though.
Old 06-30-2011, 10:10 AM
$600 is kinda steep. I think I can do better with salvage yard parts/
Baltimore
Old 06-30-2011, 10:56 AM
InfiniteWisdumb's Avatar
InfiniteWisdumb InfiniteWisdumb is offline
If I understand correctly, if you do a rear disc conversion with hydroboost, there may be some reservoir issues? I seem to remember reading that you will have a pressure change and you need to adjust your HB accordingly? Maybe Elliott can chime in on this.
FSJless for now
Looking for an M715
Old 06-30-2011, 11:34 AM
Suddendeath's Avatar
Suddendeath Suddendeath is offline
From what I've read and heard, if you HB with a rear disc setup you're going to need to adjust your proportioning (spellcheck?) valve. With all of that brake power going to those nice rear discs, you'll lock up the rear brakes and skid.
IMHO you should install an adjustable proportioning valve after doing HB OR rear discs anyway, and deffinitely with both. Gotta dial the rear/front power braking power for the new setups.
1990 GW:
Mopar 440/727/229/D44F&R
10:1, XE250H, DIY TBI. 4.10 locked f/r, SOA/SF, high steer, all the other fancy goodies. Check out my build on FSJNETWORK.
Old 06-30-2011, 12:10 PM
I would imagine doing any rear disk conversion would require a proportioning valve. I would like to do the whole thing at once, HB and disk upgrade. that way I only have to bleed everything once and can go through the entire braking system.
Baltimore
Old 06-30-2011, 07:27 PM
Dirt Wag's Avatar
Dirt Wag Dirt Wag is offline
Parts needed for rear disc conversion (with parking brake) >>>>>
calipers ($165 a pair new) are rear 1979 to 1985 Cadillac Eldorado.
One inch thick standard duty 1990 Chevy K1500 front rotors ($62 a pair new) redrilled with smaller lug holes or make spacers
AA-113A brackets ($20 pair) from http://www.aa-mfg.com/pdshop/shop/item.aspx?itemid=20
will need some creative fabrication to hook up brake cables
PART NUMBERS: brackets - AA-113A === calipers - 18-4138 and 18-4139 === rotors - YH141454 === hoses - H380280
1985 GW, 360, 727, NP229, D44, AMC20, HEI, SOA/shackle flip 7" lift, Quick Lok locker rear, Aussie Locker front, 4.10 gears, 37 X 13.5 Interco SS-M16's, Warn Premium hubs, Tuff Stuff 12,000 LB winch, rear disc brakes === stripped down street legal off road toy
Old 06-30-2011, 08:17 PM
scorge30's Avatar
scorge30 scorge30 is offline
A rear disc conversion is something I have been considering later as something that might be worthwhile.
I too want to do the HB & disc swap all at once so I only have to bleed the brakes once.
This is the kit I have been considering for my '83 Chero:
http://www.tsmmfg.com/2460.htm
'83 Cherokee Pioneer status: it's alive!! (with a horrid exhaust leak!)
Rebuilt AMC 360
Rebuilt TF 727 with HP parts (again)
Old 06-30-2011, 09:11 PM
crazydog's Avatar
crazydog crazydog is offline
Front -- Calipers from a 1985 3/4 ton Chevrolet with JB7 brakes. You will most likely need to grind the ridge around where the banjo fitting bolts to the caliper or need to use a different brake line. Get some EBC pads to go with the calipers. Use your Jeep calipers for your core and you will be out about $30.00 for the pair of calipers at O'Reilly's.
Rear -- Steel Tech Solutions for your brackets and rotors and get your calipers either from them, or at your local parts store. I used some stainless hoses from TSM.
1967 J3500 - Making plans
Old 07-01-2011, 04:16 AM
Talk to some people that are running the HB system. I remember someone saying that they could lock up the brakes easy on their rig with 37s. I would imagine that once you adjust to the added braking power, you can get the vehicle to slow down much better with just that.
If you do go with disc in the rear, you will need to change out the proportioning valve and maybe the master cylinder (I know some people don't andhave no issues though).
Old 07-01-2011, 05:44 AM
Thanks Ill check them out!
Baltimore
Old 07-01-2011, 05:57 AM
shakari's Avatar
shakari shakari is offline
I don't pretend to know much about it but are you guys sure you need to do the upgrade?
The reason I say that is I wasn't very happy with the brakes on my 1980 Cherokee about a year ago and to cut a long story short, I changed the servo (think you guys call it a booster) and the master cylinder and changed the front pads and rear shoes and the car now stops as well as pretty much anything else on the road.
Steve Robinson AKA Shakari
Old 07-01-2011, 06:54 AM
Need to, no. But I hate doing drum brakes.
Baltimore
Old 07-01-2011, 11:53 AM
crazydog's Avatar
While I did not do it all at once, I did later add a disc/disc proportioning valve and the stainless brake line kit from BJ's. Like you mentioned earlier, do it all at once and you only have to bleed the system once.
Electric Tailgate Window Troubleshooting jbentley General FSJ Tech 56 08-18-2020 12:52 PM
Swap out the Auburn LSD from rear D44 to front D44? Robb Kiker General FSJ Tech 2 04-09-2007 08:02 PM
Rear disc brake, problems Rick78J10 Off-Road FSJ Tech 12 09-22-2005 06:35 AM
Front Shackle To Rear Mount? Rompn General FSJ Tech 4 01-21-2002 02:15 PM
