View Poll Results: What size and type exhaust?
2" single (stock) 4 7.55%
2.5" single 25 47.17%
3" single 24 45.28%
Voters: 53. You may not vote on this poll
Old 06-08-2011, 07:53 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
What size exhaust?
The stock 2" single is too restrictive. Tailpipe size is an issue because I don't want to be bottoming out on a large pipe offroad.
1972 Custom Wagoneer:
AMC 360 MC2150, THM400, Dana 20, 3.31 gears.
1965 Rambler Ambassador 990:
AMC 327, Borg-Warner Auto.
1973 AMC Ambassador:
AMC 360 MC4300, TC-727.
Old 06-08-2011, 08:02 PM
austinaubinoe's Avatar
I think I would go 3" all the way out, or 2.5" if your going true duel.
Old 06-08-2011, 08:20 PM
derf's Avatar
derf derf is offline
Why fight? Go 2.5" dual exhaust.
Try out my gear ratio calculator (In metric too)
My Jeeps: Truck Norris, Woody (page coming), and CJ
Old 06-08-2011, 08:52 PM
csuengr's Avatar
csuengr csuengr is offline
Dual 2 inch. Greater cross sectional area than a single 2.5, but less than a single 3 inch. 2 inch is easier to route. Dual 2.5 is just too much unless you have a hopped up 401.
If at first you don't succeed, use a bigger hammer.
Old 06-08-2011, 09:18 PM
258Chief's Avatar
258Chief 258Chief is offline
If you have to keep it single and you're stone stock 3" is the max. You won't feel much of a difference between single 2.5 and 3.
I'm a big fan of going with dual 2.5 and anticipating future mods too.
1979 Cherokee Chief
3" RC suspension lift
3" Body lift (going away ASAP)
35x12.50 BFG MT (dry as heck!)
4.30 gears, lunchbox locker with hardened pin
All emissions equipment intact!
Passed the 4000 mile mark and 1 "major" issue.
Old 06-08-2011, 09:27 PM
The Colonel's Avatar
Unless you are going to run headers you may not notice a difference at all and likely wouldn't be worth it.
If I were going to do it I'd run headers with 2.25 or 2.5 duals.
Old 06-08-2011, 09:28 PM
Jeepguy77's Avatar
Jeepguy77 Jeepguy77 is offline
2.5 duals are fine on a 360, I'm running them and it's fine, I would either go 2.25" or 2.5" duals, or a single 3". The single is gonna be easier to route than duals.
Pierce,
77 J10 360 4bbl, T18, D20, HEI, Holley carb, Performer intake, Thumpr Cam, Hedman headers, dual exhaust, Auburn limited slip, hydroboost.
http://www.youtube.com/watch?v=z-vRy...&feature=g-upl
Old 06-08-2011, 09:38 PM
phisohex's Avatar
phisohex phisohex is offline
headers and 2.5 true duals.. it sounds real mean.
Patryk M.
1990 GW
360. edlebrock intake,cam,timing set, 650 cfm Thunder AVS carb, heddman headers. HEI
Bjs 6in Lift, 1in shackles, 2in body lift, B&m FloorShifter, 33"xterrains,33gal bronco Tank,Flowmaster 40 Dual pipes,
bjs aluminum rad. Electric Fan, sweet new paint job
Old 06-09-2011, 08:10 AM
Kind of a dumb question, when you say true duals does that include a crossover pipe?
George
'74 Cherokee, 401
'76 J-20, 401
M725, future project
Old 06-09-2011, 09:31 AM
Serious Johnson's Avatar
It should, or you'll be giving up some torque across the rev range, and probably end up with about the same or less power than with the stock setup. With a 90-degree V8 with a 18436572 firing order, the only other way to acheive even exhaust pulses is with 180-degree headers that route two primaries from each bank into each collector, and there's just no room for that. Dual exhaust on a rig with Jeep-ish operating parameters and available space are merely cosmetic.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 06-09-2011, 11:49 AM
csuengr's Avatar
Then their are those of us who have to live with emissions standards. I have to have a single exhaust, but I can have dual ends. And I only have to buy one muffler and one cat.
Old 06-09-2011, 01:20 PM
Josh D's Avatar
Josh D Josh D is offline
I run a dual 2.25" in/single 3" out muffler with headers. Sounds good. Runs good.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 06-09-2011, 02:51 PM
mattmopar440's Avatar
I would say 2.5 duals but 3" if your going single
91' Grand Wagoneer
401/727/229, HEI, Edel 2131 Intake,8600, Holley Truck Avenger, Dual Exhaust, Flowmaster 70. Edelbrock shorty headers.4" BJS 31 BFG Mud-Terrains
Currently:Down for Body Work
80's J10 258/T-5/208
90' Jeep GrandWagoneer
SOLD
Inferior Chevy
Old 06-10-2011, 05:36 AM
drlocke's Avatar
drlocke drlocke is offline
Roadside Mechanic
If offroading involves the need for WOT at high rpms then I can see an oversize exhaust applied. Otherwise it's mere ear candy.
Old 06-10-2011, 05:10 PM
Rich88's Avatar
Rich88 Rich88 is offline
Really. You read my mind. Last I knew headers don't do a thing until 3500-4000 RPM...except make more noise.
88 GW 360-.030 over/2150/727/229/Posi, e-pump, AC (broke), tow package, Monroe Air Shocks, dizzy manifold vacuum, CTO-Free, AIR-free, oil & tranny coolers, dried knuckle blood all over, GM 350 TBI in a box, waiting...
Old 06-10-2011, 06:13 PM
Well, then there are those of us who want it all. I have a gigantic muffler (some Mitsubishi junkyard thing) on my Wagoneer that's Lexus quiet, and the 3" system sort of makes up for the backpressure imposed by all that silence. I like not scaring the elk when I drive up because it helps me eat better, but don't much like giving up power if I don't have to.
A 3" single pipe, by the way, has about the same cross-section area as 2-1/4" duals, and it's easier to do a single pipe system on these rigs without making goofy compromises. The tailpipe on mine has gone a little bit oval on rocks, so clearance is probably now about the same as stock.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 06-10-2011, 08:32 PM
Rich88's Avatar
Originally Posted by Serious Johnson
I have a gigantic muffler (some Mitsubishi junkyard thing) on my Wagoneer that's Lexus quiet...
Really?!...I wish you knew what model/year it came from. I'd want to know.
Old 06-10-2011, 09:16 PM
I have no idea. I assume that it was from some sort of commercial diesel, since I can't think of any Mitsubishi road car or truck that would have a 3" muffler. It surely is quiet -- have to glance at the tach now and then to be sure the thing is running. And 20 bucks seemed pretty good for such a big hunk of stainless. It does hang down a bit -- almost as long and deeper than a stock Wagoneer gas tank.
S.J.
"Carpe Mañana".
'83 Wagoneer
Old 06-10-2011, 11:11 PM
lunchbox1671's Avatar
lunchbox1671 lunchbox1671 is offline
3" single or ANY size duals.
I run true duals, they sound good. Engine runs good. I'll be switching from 2.5 sidepipes to 2" duals straight out the back.
1979 Jeep Cherokee Chief Sport 4 door N/T.
-AMC 360 with RV cam
-T-15A, Dana 20
-Dana 44's, 3.54's,
-32x11.50r16's
Old 06-11-2011, 12:46 AM
78J-10's Avatar
78J-10 78J-10 is offline
I currently am running side pipes i think there 2.5 into some flowmaster 40s. sounds really really nice.
i want to redo the exhaust so my pipes arnt rock targets anymore and ill prolly run 2.5 y pipe off headers into a single 3in all the way back under the bed. with a flowmaster 40 or 50. hoping to keep a simulator sound as i love way it sounds now just not all the leaks
78 J-10: 258 w/2100,D20,HD44,14 Bolt,36's (SOLD )
79 J20: 360 T18 D20 33s 36k: current state: FOR SALE
Tow Rig: Turning into one unlovable money pit
03 F250
6.0
4in turbo back
4x4
6 spd
If you were to convert to diesel getlost4x4 Diesel Swaps 56 08-25-2012 05:33 PM
newbie with exhaust ??'s GotMeAwoodie General FSJ Discussion 12 12-20-2010 05:31 PM
Early model exhaust manifolds on late model head The PIG Smith General FSJ Tech 10 10-05-2010 09:21 PM
headers/pipe size/how cum's fasteddy General FSJ Tech 2 03-08-2010 03:47 PM
Size of exhaust manifold bolts DanHS General FSJ Tech 11 06-16-2007 05:39 AM
