Old 05-19-2011, 09:45 AM
brushawg's Avatar
brushawg brushawg is offline
Lightbulb Propane Conversions
Ok, I know some one out there is running a propane system.
1) What system are you using?
2) Difficulty of the install?
3) What kind,size tank are you using?
4) Lastly what type of mileage are you getting. Also the type of rig it is?
Pictures would be nice also of the set up. With gas at $3.95 a gallon and diesel at $4.39 thinking this maybe a better option.
Need input, please.
Old 05-19-2011, 10:36 AM
1) Cobbled together from parts bought on e-bay, stuff sourced locally, and parts Craig had.
2) Not hard something Craig and his dad had done before.
3) 42 gallon
4) Unknown since speedometer is off due to 37 tall tires. According to the experts you loose 10% so be sure that the difference in cost be worth it. If you have a home tank it might be worth it. I haven't checked in a while at one time it wasn't here in Colorado in 2005 it cost me more for propane per gallon as road fuel than gasoline did. Hmm I may need to check with my propane people. Oh one of the problems I ran into in Colorado was they not only charged road tax, they also added sales tax on top. According to my propane guy what happened was when they started selling BBQ bottles the sate found they could get sales tax on propane. Also according to my informant the state also sets the price on propane.
Old 05-19-2011, 09:56 PM
18cherokee's Avatar
18cherokee 18cherokee is offline
impco 300 mixer sits on top of the carb - dual fuel.
70L tank where the spare tyre used to be.
mileage? i do a heap of stop start peak hour driving so not sure if that helps.
i have found that any cost savings made by running LPG / propane have then usually been gobbled up by LPG system maintenance costs & unreliability.
i have other remark that our rigs just dont like LPG, but im sure thats not always the case.
here's a good write up where a guy detailed the conversion on his 77 chero SJ - lots of pics & helpful info.
http://www.fiodh.com/cherokee/propane.html
Black Cherry 1989 Grand Wagoneer
S&J rebuilt AMC360
IMPCO Propane
Old 05-20-2011, 01:43 PM
brushawg's Avatar
Thanks for that link and information. Gives me an idea as to what is needed.
Old 05-20-2011, 02:52 PM
orangecherokee's Avatar
that's not true. mine loves it.
I've heard that you lose a few horses but I can't tell the difference. I run an Impco 425 on a throttle plate I got from Summit for around $105. I use a Model E vaporizer and a vacuum lock-out. I run 2, 40lbs tanks (forkilft). I can run all day on 1 tank (~8 gallons). I trail ride and hammer it pretty hard. If you tune them right I'd say you could get some pretty decent mileage.
Old 05-20-2011, 05:37 PM
Crom has a dual fuel hat sitting on top of a stock jeep 2 barrel carb. On the highway we can run around 80 MPH, and have enough low end grunt to tear two front drive shafts in half
Old 05-20-2011, 07:04 PM
brushawg's Avatar
Now that's what I'm talking about!
Still being able to have power and torque for fun at a lower cost per smile.
Old 05-20-2011, 11:47 PM
getbentfab's Avatar
getbentfab getbentfab is offline
In my opinion dual fuel is a poor compromise. You won't see optimum performance or efficiency on either fuel unless you have a fully electronic controlled set up.
With my dedicated propane conversion I get the same 11 mpg I got on gas but it starts and runs great no matter how cold it gets or how long since it last ran. I've never used the priming feature even at 5 degrees last winter. There's a reason they call it "Poor man's EFI"
Get a copy of this...
http://www.scribd.com/doc/17379058/I...raining-Manual
Another one of the very best sources of information out there is...
http://franzh.home.texas.net/
Franz charges for his trouble shooting guide but it's worth it. I'd got mine years ago when they were free but I'd recommend it even if it was $40!
I got my major propane parts from..
http://www.helmarparts.com/
Prices at helmar were the best I could find when I did my conversion. Go with silicone diaphragm in the mixer for durability.
Here's a link to the CARB approved propane kits and accepted modifications. This should help if you have to get smog tested.
http://www.arb.ca.gov/msprog/aftermk...s93_022607.pdf
The Very Best info anywhere is here...but you have to register to use the site and you're not allowed to copy the info unless you pay. If you want to be street legal you'll have to follow these instructions. If you want to be safe you'll want follow them even if it'll be a trail only rig.
http://www.nfpa.org/index.asp
Search for "nfpa 58"
Click on the first link..."NFPA 58: Liquefied Petroleum Gas Code"
Down about 3/4 you'll see..."Additional Information about this document:"
Click on..."View the 2008 edition of this document."
Like I said, you'll have to register and you can't download the file but just about everything you'll need to know is here.
Propane Conversion of Cars, Trucks & RV'S. If you can find one buy it. They come up on eBay once and a while. It has just about everything you need to know in one place and will save you tons of research. It was published in the early eighties when converting to propane was popular. Some of the market data listed is obviously out dated but the actual conversion information is still good. Not much changes with traditional propane systems. The newer 425 mixers are factory set and have tamper resistant adjusting screws to meet federal regulations but everything else is the same as the book describes.
I went to Amerigas for most of the small parts I needed. They even got me a fuel level sending unit that works with the original Jeep fuel gauge on the dash. they had all the hose, fitting and threaded adapters I needed in stock. They even had a silicone diaphragm repair kit on the shelf for the 450 mixer.
Here's basically what I did.
I used...
Impco 450 mixer with silicone diaphragm,
Model E converter,
ffv-30 lockoff,
Edelbrock Performer intake manifold,
Holley throttle plate,
Mallory HEI dist. with one standard spring and one of the lighter springs to advance the timing a little sooner,
Initial timing at 12 degrees btdc,
Disconnected the vacuum advance to prevent over advancing.
I didn't block the exhaust crossover in the intake manifold as recommended but I eliminated the valve in the exhaust to prevent manifold heating.
My tanks are under frame mounted and hold 23 gallons. (250 mile range) I put my fill connection where the gas filler was originally.
Closed loop computer controlled feedback system.
I mounted the mixer, converter and control solinoid on a custom plate on the firewall just behind the engine where the charcoal canister used to be. You'll see converters mounted in all sort of positions but you'll find that black gunk separates from the propane and will cause problems eventually if not mounted correctly. The discharge port is supposed to be pointed down to allow drainage of the "Gunk". The outlet of the converter should be higher than the inlet of the mixer but I couldn't make that work so I disconnect the hose at the converter outlet every couple of months to let it drain out.
Here's what my set up looks like from the top.
The small black box that is nearly cropped out of the picture just to the right of the converter is the Autotronics Dual Curve controller. It uses a standard O2 sensor to adjust the mixture by putting a vacuum to the atmosphere port on the converter. I had the bung welded in just behind the y.
We mounted my tanks on a hinged skid plate so I can pull a couple of pins and drop the tanks down to service the valves.
Mark at Amerigas found the sending unit calibrated for the Jeep's original factory fuel gauge so my old gas gauge is now my propane gauge.
72 Wagoneer on Propane w/Family cage and 3" spring drops.
Propane Conversion ibkukin General FSJ Tech 14 10-04-2009 01:25 AM
No more propane conversions??? Dmntxn77 General FSJ Discussion 35 11-25-2007 02:03 PM
propane + boost?? golddigger79 Off-Road FSJ Tech 25 11-02-2007 01:43 PM
Slightly diffrent propane question JeepsAndGuns General FSJ Tech 4 09-02-2007 09:01 PM
Propane Conversion Ole' Mud & Guts General FSJ Discussion 49 07-29-2007 01:26 PM
