Go Back   International Full Size Jeep Association > Classifieds > "Look Here" for Parts, Vehicles and Vendors > Homegrown Vendors: (Members who produce FSJ related items)
Old 05-05-2011, 01:31 PM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
Bolt in Conversion Motor Mounts
I make mounts to bolt in GM Gen III & IV V8s into our FSJ's. You pull out your AMC V8, bolt these mounts to your new GM V8, and bolt it into your FSJ. What is a Gen III GM V8 you ask? The LS1, LS2, LS3, 4.9L, 5.3L, 6.0L, etc. All can be bolted in using these mounts. They come unpainted, use a FSJ 2" rubber bushing, and are supplied with hardware to mount them to the frame horns. $150 + $15 shipping USPS Priority Mail.
I also can make up mounts to bolt in an Isuzu 4BD 3.9L diesel engine. The frame horns have to be removed, then these bolt in (no drilling).
Finally, I've designed a motor mount setup that replaces the factory AMC parts. They do away with the failure prone rubber block. The factory stand off is removed, and these bolt in place. Here is a picture side by side, new vs old. $150 + $15 shipping USPS Priority Mail.
I use 1/4" plate & 1/4" tubing. The V bracket welded to the tubing is formed 1/8". If you break the metal parts, I will replace them. The bushing is an off the shelf FSJ 2" spring bushing, available from rockauto.com for $10. These are made to order, and it usually take me three to four weeks to get a set done.
Pete
Isuzu 6BD1, NV4500, NP241
Old 06-04-2011, 09:22 PM
Eric S. Eric S. is offline
Nice looking work you've got there!
1989 Grand Wagoneer -- FOR SALE
Old 06-09-2011, 02:06 PM
dxpope's Avatar
dxpope dxpope is offline
Cummins 4bt mounts
Can you do mounts for the Cummins 3.9l 4bt? You would need to use a more flexible bushing than the spring eye bushings. I have a 4bt and a Cherokee. Someone needs to make it easier to put these two together for a Cherokee that gets good mileage and has a lot of range.
Old 06-09-2011, 02:38 PM
JeepinPete's Avatar
Can I? Yes. Do I? No. But I do know what bushing to use, and I'd be more than willing to do so, but I don't happen to have a 4BT handy
Pete
Old 07-04-2011, 11:29 AM
thinder's Avatar
thinder thinder is offline
I have the Cad Drawings of the ones i built for my 4bt and had CNC plasma cut. they use the 1st gen Dodge ram cummins pad mounts on the factory frame horns. Maybe we can work something out.
86 Grand Wagoneer
Cummins Ve pumped 4bta
47RH
np241
D44 front and rear
Old 10-12-2011, 03:33 PM
Kansas_Nova Kansas_Nova is offline
How close would these mounts put the motor in relation to the firewall? i would be worried about valve cover to heater clearance as well.
Old 10-12-2011, 06:00 PM
cmelo's Avatar
cmelo cmelo is offline
Have any pictures of the AMC replacement mounts installed?
79' J10 360/T18/D20- Locked & bobbed on 35s
Old 12-16-2011, 05:21 PM
fsj1979's Avatar
fsj1979 fsj1979 is offline
Those look great! Too bad I didn't know about these before I did my swap. I think I like them a little better than the ones from BJ's as far as ease to install. I am very happy with theirs though. They work very well.
1979 Cherokee Chief
2003 GM 5.3 liter Vortec
4L60E/ NP 241c/ Dana 44's/ 33" BFG KM2 muds/ 4" lift
My 5.3 swap: http://www.ifsja.org/forums/vb/showthread.php?t=140105
Makin' her purdy: http://www.ifsja.org/forums/vb/showthread.php?t=140286
Vid: http://www.youtube.com/watch?v=XrqX1ip2KkM
Just keep rubbin' money on it till it shines.
Old 01-02-2012, 09:30 PM
JeepinPete's Avatar
Thanks to Andy (andyjk1), here are a couple pics of the mounts doing their thing...
Pete
Old 01-02-2012, 09:33 PM
JeepinPete's Avatar
Sorry for the long delay Kansas_Nova, been a busy fall for me. There is room between the heater and the valve cover. Very similar to the stock 360. The sending unit for the water temp gauge goes in the right side head, and the port is at the back of the head. It is a bit of a contortionist's act, but you can get your hand in there to change the sender.
Pete
Old 02-02-2012, 08:53 PM
j20owner's Avatar
j20owner j20owner is offline
I sent you a PM, Pete.
Where is my axle?
79 j20/84 GW GM Hybrid
Old 02-02-2012, 09:17 PM
serehill serehill is offline
Gotta give it a shot
what about 5.7 hemi mounts is that possible?
80 Cherokee
360 ci 727 with
Comp cams 270 h
NP208
Edlebrock performer intake
Holley 4180
Msd total multi spark.
4" rusty's springs
Old 02-03-2012, 12:56 PM
JeepinPete's Avatar
Anything is possible, but I don't have a Hemi
Pete
Old 02-03-2012, 04:33 PM
j20owner's Avatar
Check your PMs, Pete?
Tried to reply to your PM, but it says your mailbox is full.
Where is my axle?
Old 02-11-2012, 02:48 AM
Diesel YJ's Avatar
Diesel YJ Diesel YJ is offline
Do you have a set for the 6BT? I may build my other rig with a 6.2 or 6.9 IH. When I did the 6.2 swap in my YJ I used regular SBC mounts. I am not familiar with all the GM specs but are these other GEN I, II, III different from a older small block?
2000 WJ Grocery Getter and RC approved, 4'' Lift.
1983 Wagoneer Limted - Future tow rig
1988 Grand Wagoneer - All stock but super sexy and clean.
1989 6.2L Turbo diesel YJ, 6.5'' lift, 35's D44 F&R, SM465, NP205, Woody's shafts, Christmas tree air freshener.
Old 02-11-2012, 10:22 AM
j20owner's Avatar
I don't know the specs on them either, but the old small blocks and the LS series don't have similar engine mounts. I know you can buy plates to bolt to LS motors to use old style mounts, not sure about the other way around.
Where is my axle?
Old 02-11-2012, 07:31 PM
JeepinPete's Avatar
No, I do not have a set for a 6BT, but that is something I should look into. Seems to be a lot of interest in that motor.
Yes, the Gen III and Gen IV are a different pattern, and in a different location that the Gen I and Gen II SBC. Just so happens the newer location is real close to where AMC had it on the V8s, which makes my conversion mounts possible.
Pete
Old 02-11-2012, 10:49 PM
derf's Avatar
derf derf is offline
What about mounts for an earlier Chevy small block (or even big block)?
Try out my gear ratio calculator (In metric too)
My Jeeps: Truck Norris, Woody (page coming), and CJ
Old 02-12-2012, 04:13 PM
JeepinPete's Avatar
I've looked into it, but it doesn't really work with the factory frame horns. A set of bolt in mounts could be designed, but they would cost more than the AA or Novak mounts, and you would lose the ability to place the engine where you want.
Pete
Old 02-12-2012, 06:07 PM
The PIG Smith's Avatar
King Browless
Pete,
Just a curiosity here...
If you had a rolling chassis and a 6BT to work from, what else would you need to build some 6BT mounts?
Would need a J Truck Cab?
Front Radiator Core Support?
Steering Column?
... inquiring minds want to know! hehehe
Bryan Smith
1982 J10: Replacement engine now sitting in the truck! No Cab Brow! Future DD
Originally Posted by Jayrodoh
Originally Posted by Lindel
because Ristow sez so
When the IFSJA forum has a problem go here:
www.fsjnetwork.com
14 Bolt FF disc brake conversion kit ?'s Tigger4X General FSJ Tech 23 07-24-2012 10:21 AM
8 bolt D44 to 6 bolt D44 biojim General FSJ Tech 6 07-29-2007 06:55 PM
Muncie SM465, GM 10 bolt 8.5, GM 14 bolt 10.5 and NP 208 swap Chris Barry General FSJ Tech 9 02-26-2007 02:25 PM
Changing a Dana 44 bolt pattern Fox Off-Road FSJ Tech 18 09-27-2006 05:54 AM
8bolt J20 hub to 6 bolt 5.5 Conversion? SamoyedSled General FSJ Tech 7 01-13-2004 01:14 AM
