04-26-2011, 11:30 AM
help with part id....
After overheating at a stoplight today I found my problem. It's where the hose from the heater core connects to the engine in back. The nipple has corroded out and cut the hose. when I stopped she blew. Anyway what is that thing called? It looks to be aluminum. Thanks
1987 grand waggy, 3" springs in front. Blocks and add a leaf in rear. with 285/75/16 shoes.
04-26-2011, 11:58 AM
I've got one off the stock 2brl intake, if you need it.
Joey
Jeep-Less
CFSJC Vice President
04-26-2011, 01:47 PM
Easy access
You Can get these @ Napa just take it off & take it uo there. I bought a steel one.
04-26-2011, 02:59 PM
It's called an water inlet/outlet nipple.
1976 jeep Cherokee........Buick 350, turbo 400 with air, Rough Country 3" all spring and powr-loks front and rear.
You really are judged by the dogs you have!
04-26-2011, 10:56 PM
Murphy's Law Poster Child
X2. Alot of the big name auto parts places will have one or two types on the shelf near all of the chrome stuff, usually $15-$20. Definately cheaper at Napa.
04-27-2011, 02:34 PM
yep
I looked at the cheaper ones. I just wanted the good one no use replacing a cheap one again they not cheap like that.
Cheap & Chrome won't get you home.
04-27-2011, 11:37 PM
I went to the local parts place.... not the chain store, but I forgot the the exact size of the thread, may be 3/8 npt.... for a 5/8 heater hose, $5. They did not have the curved version for the older wag, but have an 87 the straight version is fine... you only have to deal with the thermal switch if you still have it.
Michel
74 wag, 349Kmiles on original ticker/trany, except for the rust. Will it make it to Moab without a rebuilt? Status: debugging a few electricals.
85 Gwag, 210 Kmiles. $250 FSJ test lab since 02, that refuses to give up but still leaks.
my jeep aid images
http://picasaweb.google.com/jeepmr/FSJ
