04-03-2011, 06:22 PM
Shoulder belts in a J Truck
Anyone got pics of shoulder belts in a J Truck? Wanna make it baby seat friendly.
Justin
'72 J2000 360 4bbl T18 D20
'96 ZJ
"It's all about the fun-per-gallon vs the miles-per-gallon"-- Gamber68
04-03-2011, 07:03 PM
mine has shoulder belts i'll take some pics this week when i go to work on it.
J- Just
E- Empty
E- Every
P- Pocket
77 J10 honcho with levis interior
AMC 360
4 speed
Warn 8274 winch (8,000 pounds)
04-03-2011, 07:09 PM
Awesome...thanks  if you could, snap some of the brackets, etc. That would be awesome
Justin
'96 ZJ
04-04-2011, 05:07 AM
I think what you are looking for is the upper anchor mounting. The upper mount structure is hidden behind the inner panel inside the B-pillar.
I blow my horn before it happens, not after.
A good mechanic can fix their own mistakes.
Waste not war not.
Ignorant is blist.
When you're in a hurry... slow down.
Measure once... cut twice.
04-04-2011, 06:14 AM
Roadside Mechanic
Just what I was gonna say. If you have any trim on the rear pillars remove it and you may find a threaded hole. My '69 International truck has these holes.
04-04-2011, 07:08 AM
hmmm....that would be pretty cool. I would hate to hack up the pillar, but a measurement from the floor to the place where the threaded hole should be might lead me in the right direction.
Justin
'96 ZJ
04-04-2011, 07:11 AM
Dexron Impaired
I can get some pic's for you later today.
04-04-2011, 07:35 AM
If its like my 76 j-20, the hole will be there but no threaded insert.
04-04-2011, 09:05 AM
Whatcha gonna do with yer lap belts??? I may be interested
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
04-04-2011, 09:23 AM
They are yours if you want 'em when the swap is complete. Hopefully it won't be too much of a PITA.
Justin
'96 ZJ
04-04-2011, 03:09 PM
Dexron Impaired
Hope this helps.
04-04-2011, 03:41 PM
Thanks!
Justin
'96 ZJ
04-04-2011, 03:50 PM
I put shoulder belts in my 71 J4000 when I competitive mud bogged it.
Here is how, the lower pocket is open, so I welded a nut on back of a flat bar, drilled a hole in the upper panel and slid the bar up and maneuvered it around until it lined up. Then I shot a couple self drillers in the lower part of the bar to keep it quiet.
It was a royal pain, but you only have to do 2, it would save cutting and welding, and the bar acts as a nice double plate too.
04-04-2011, 04:06 PM
I was starting to think along those lines. Seems easy enough
Justin
'96 ZJ
04-04-2011, 05:19 PM
this is VERY helpful, I'm getting ready to do this!
______________________
rp
1967 Jeep Gladiator 2500
Kaiser 327 Carb
44's/Automatic
04-05-2011, 12:10 AM
I got a set of out of a couple parts trucks I would part with...set of blue ones outta a 76 and tan ones from a 79....
Formally known as "oilfieldtrash354"
"Grandpas" 1979 J-10 resto/mod-on hold for now
Preparing for Ouray 2013!!!!
04-05-2011, 04:54 AM
If you want this belt to actually do something rather that just look pretty you should consider the size of the nut plate that you install. I'm not sure what the structure looks like in a J truck but I would probably make a plate as large as I could reasonably fit in that area. Standard thread size for foregin and domestic seat belt anchors is 7/16-20. If you like, I can give the two reference measurements you will need to locate the hole.
Waste not war not.
Ignorant is blist.
