Old 03-27-2011, 07:26 PM
FSJunkie's Avatar
FSJunkie FSJunkie is offline
I'm so happy.
Ever since I got this Jeep I was concered that the suspension was sagging as the left side of the car was 1/2 inch lower than the right, but it was level front to rear. I started to budget for new springs. Well, today I just ran it below 1/2 tank of gas for the first time and the sag went away!! It makes sence because the tank is on the left side. Yay!!! I don't need springs afterall!!!
1972 Custom Wagoneer:
AMC 360 MC2150, THM400, Dana 20, 3.31 gears.
1965 Rambler Ambassador 990:
AMC 327, Borg-Warner Auto.
1973 AMC Ambassador:
AMC 360 MC4300, TC-727.
Old 03-27-2011, 08:04 PM
Dumpy's Avatar
Dumpy Dumpy is offline
Lol
Justin
'72 J2000 360 4bbl T18 D20
'96 ZJ
Old 03-27-2011, 08:17 PM
Dmntxn77's Avatar
Dmntxn77 Dmntxn77 is offline
Hey watch this...
Get you a Trailblazer Aux Tank, ditch the saddle tank, and never worry about that sag again.
Old 03-27-2011, 08:29 PM
Mr.Wagoneer's Avatar
Mr.Wagoneer Mr.Wagoneer is offline
That's awesome! You might not "Need" new springs but it might be a good idea to change'em anyways, Even when full my Wagoneer is level I think I'm below 1/2 half now (Fuel Gauge is not operational) and it's still level, your springs or even shocks might be a little worn. You might even want to check out some adjustable shocks also to keep you level I hear great things about Monroe Air shocks but only if springs are out of the question, Either way you got your self a nice Wagon!
Year: 1983
Make: AMC/Jeep
Model: Wagoneer
Trim: Limited
• AMC 360 5.9 Liter
• MotorCraft 2150 2 BBL Carb
• TF-727 3 Speed Automatic
• NP-229 Select-Trac Full/Part time transfer case
• Dana 44 Front Driver side drop AMC 20 Rear
• 109 in. Wheelbase
• 5975/6200 Lbs GVWR
• Manufactured in Toledo Ohio
Old 03-28-2011, 06:42 AM
710 Burner's Avatar
Just park it with the wheels slightly turned to the left, then it will body roll to the right. Problem solved.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
little things make me happy mklyon General FSJ Discussion 1 09-29-2010 07:23 PM
Happy Happy Joy Joy HD_JEEP General FSJ Discussion 6 03-26-2010 07:57 PM
Happy Birthday!! rustywagoneers_com General FSJ Discussion 9 03-16-2010 08:36 AM
Poor and HAppy... yjkrawler General FSJ Tech 8 08-25-2007 05:42 PM
Happy Independence Day! stratman General FSJ Tech 5 07-03-2006 02:52 PM
