Old 03-11-2011, 02:25 PM
Blake Blake is offline
The "Goofy" build thread
I bought Goofy from Goofy here on the board in late February 2011. I was looking for a nice waggy body for my highly modified J10 (specs in my sig).
After towing Goofy home and putting a radiator in, he started right up and drove fine. I really like Goofy and decided that you can never have too many FSJ's. Plus, my girlfriend needs something to 'wheel.
Build plans are as follows:
Ford High Pinion D44 8 lug front locked with 4:10's direct bolt-in SOA
Dodge Full Float 8 lug rear open with 4:10's direct bolt-in SOA
Custom made bumpers front and rear
full high steer with hydro assist.
Atlas 2 speed 3.8 low
Stock (rebuilt) AMC 360
Stock TF 727
1350 CV drive shafts front and rear
35's or 37's MTR Kevlars on H2 rims
Full exo cage
So in other words, a light duty 'wheeler that is capable of pulling out the big J10.
We've dubed it the "J10 recovery vehicle"
Here it is as I bought it. The hood was previously primered black, so we took the primer off with some rags and water.
Looks better now
I power washed the wood grain off with a 4000 psi pressure washer
1978 Ford 3/4ton Hp Dana 44 purchased from the yard with 4:10's for $200 plus the front drive shaft
1983 Dodge W300 Dana 60 rear purchased from the junk yard for $130 with 4:10's
Rear axle all cleaned up
I made some spring hangers for the rear shackle flip out of 1/4" thick angle iron and some 1/4" thick flat bar
Old 03-11-2011, 03:03 PM
I've already bolted in the front axle (it is indeed a direct bolt-in for SOA). No pics of that just yet.
Already ordered the Atlas 2speed 3.8
Already have the passenger side flat top knuckle milled and drilled.
Picking up some H2 wheel tonight.
Old 03-14-2011, 09:30 AM
Got a lot done on Goofy this weekend.
Installed the rear Dana 60
The custom shackles lifted the rear 11"
the front has bent leaf springs, so I have it on jackstands
Planning to use stock LX450 front coils, which are Old Man Emu's
Old 03-14-2011, 09:58 AM
cajun_lad's Avatar
cajun_lad cajun_lad is offline
Almost exact same setup on my 88. 'cept I did discs on the rear. And LR's in both. H2's look awsome on FSJ's! 'bout to pick up a set of 37" Boggers to put on my H2's, the BFG's almost have no tread pattern left, lol.
Joey
Jeep-Less
CFSJC Vice President
Old 03-14-2011, 06:44 PM
Stuka's Avatar
Stuka Stuka is offline
Coming along nicely. I too like the look of H2 wheels on an FSJ.
Full Size Jeep Network
1975 Cherokee *Sold*
1989 XJ Limited *Sold*
Old 03-14-2011, 10:25 PM
What's the spring rate on the LX450 coils?
Old 03-14-2011, 11:03 PM
Pretty Stiff
I'm on the mud site and have read the stats before. I figure they will be great coils on the front of a waggy, but that is just my guess. I know they work GREAT on the LX450, which tips the scales at 6160lbs. I'm not sure anyone's ever put them on a waggy before...
Although after talking with the guys at spidertrax (they are here in town), I'm leaning against coils on goofy. Leaves will be great. The thought is crossing my mind to take the 2" leaves out of my J10 and putting them on goofy. But then I have to do coilovers on the J10...
Pics in a few minutes...
Old 03-14-2011, 11:42 PM
Just because I know people like pics!!!
My real love!
Where can I get a ubolt for a '78 ford high pinion dana 44?
my girlfriend cleaned the frame for me!!
driver side stock rear leaf spring is bent
None of these welds have been cleaned
Old 03-14-2011, 11:48 PM
sorry for the bad pic, but a waggy was on the dukes of hazzard while I was posting on here
Old 03-15-2011, 01:24 AM
76FSChief's Avatar
76FSChief 76FSChief is offline
Looks good! did you have to machine the H2s to fit? Like the look alot.
Old 03-15-2011, 01:45 AM
Goofy's Avatar
Goofy Goofy is offline
that was something i all ways wonted to do for Goofy but never had the time or cash to get it done im glad hes treating you well he allways ran when you wonted him to sept in the morenings lol . he looks way differnt without the wood grain on him but still looks awsome
1977 Mustang 2 limited edtion T-Tops (Orange Juice)
Old 03-15-2011, 09:35 AM
The H2's were machined by the previous owner, so I only had to bolt them on
Old 03-15-2011, 05:20 PM
Wagn Man's Avatar
Wagn Man Wagn Man is offline
Awesome build you have going there.
78 Chero NT..... nickname "Crash"
84 GW 401, Rhino Grille
03 Chevy Silverado 2500HD My DD/Tow Rig
Old 03-16-2011, 12:41 AM
Goofy's Avatar
so blake when are we gona do that to my cheif????
Old 03-17-2011, 11:03 PM
Well I've had all kinds of problems ordering parts, but some have arrived and are installed.
My girlfriend ground down the front dana 44.
She removed some of the webbing on the diff so the u-bolts fit a little better and removed the factory shock tab.
New Chinese aluminum radiator arrived today! Bolted right in the factory bolt holes. No leaks!
Got it installed.
Got the driver side calipers and pads installed. Napa gave me two driver sides, so I must order a passenger side
The stock 13" brake line comes up short. Currently searching for new lines that mate to a waggy/ford d44 and are at least 20" long.
Old 03-18-2011, 09:48 PM
Stuka's Avatar
Coming along nice!
And, as I recall, a ford line should work fine (for say a lifted 78-79 F250). I believe the frame side of the line is a standard fitting.
Old 03-20-2011, 11:16 PM
jMedia's Avatar
jMedia jMedia is offline
Awesome build so far, keep it up!
If you're not gonna use that woodgrain trim I know someone who may want it.....
Joshua
Cosntantly changing, never done
Originally Posted by joe
Point #1. Do this for love. Get any crazy ideas like I'll sell it when done out of your head right now.
Old 03-22-2011, 10:03 AM
cable97526's Avatar
cable97526 cable97526 is offline
Ford E250 van brake lines from 86-2000 are 32" long and will bolt up without any modification of your stock line since they kept american fittings. FYI
There are no stupid questions, but there are a lot of inquisitive idiots.
1974 J10 Levi's edition 401/th400/np205 60/14 soon to be 8.1/4L85E/205!
1968 J20 SBC350/sm465/np205 60/14
1972 Cherokee Chief (stock)
2003 TJ Rubicon Tomb Raider turbo/40's/D44F/9inchR
Old 03-22-2011, 10:15 AM
Napa's website shows those brake hoses are like 14" long.
Do you have a part number?
Old 03-22-2011, 11:02 AM
cable97526's Avatar
Sorry I screwed up lol, the lines I used were from a 95 dodge 250 diesel 2wd, no part number as I got them used.
1987 GW Build Thread rawdave General FSJ Tech 72 07-24-2012 07:48 AM
J300 build up thread (motor is here) KaiserMan General FSJ Tech 96 10-27-2011 08:49 PM
WHY NO BUILD THREAD????? CONTINUED!!!!!! BlackrockMotorSports General FSJ Discussion 110 12-03-2009 10:39 PM
Question - WHY NO BUILD THREAD? msh227 General FSJ Discussion 38 12-01-2009 06:36 PM
J-20 Build JoshDes Off-Road FSJ Tech 10 11-11-2009 01:18 AM
