Old 03-24-2011, 06:29 PM
thinder's Avatar
thinder thinder is offline
That 6 is a HUGE engine! I had to get a body lift just to get close to closing my hood.
86 Grand Wagoneer
Cummins Ve pumped 4bta
47RH
np241
D44 front and rear
Old 03-24-2011, 06:36 PM
lobie's Avatar
lobie lobie is offline
It's really not that bad. It's a little longer but not as wide. I think it's a perfect match. It's all in the finess.
You got pics of yours or a link to it?
77 Wagoneer | 6.0 | TH400 | NP205 | Sterling 10.5 | Dana 60
07 6.7 Cummins 2500 4wd
lobie4x4.com
CFSJC
Old 03-24-2011, 08:57 PM
lobie's Avatar
Found this exhaust manifold while surfing around. Should be able to move the turbo closer to the front away from the heater box. Would have to flip it upside down. Sure they make one that points down. Otherwise I could hack to stock one up and modify it.
lobie4x4.com
CFSJC
Old 03-25-2011, 09:24 AM
thinder's Avatar
http://www.4btswaps.com/forum/showth...d-Wagoneer-4bt
86 Grand Wagoneer
47RH
np241
D44 front and rear
Old 03-25-2011, 09:49 AM
JeepinPete's Avatar
JeepinPete JeepinPete is offline
Originally Posted by lobie
The thing that got me to get them was the price and the factory locker. They are the 419 axles with a ratio of 6.5.
What size tire do you plan to use with these? Even with 40's, 70mph would be top speed with the 6BT screaming. Maybe an overdrive box after the NV4500
Pete
Isuzu 6BD1, NV4500, NP241
Old 03-25-2011, 09:52 AM
lobie's Avatar
Why would I want to go over 70? 60-65 is plenty. 40-42 tire. Haven't decided.
lobie4x4.com
CFSJC
Old 03-26-2011, 01:29 PM
lobie's Avatar
Got the engine set down pretty much where it will sit. Need to get the tranny on before I can make the mounts and lock it in. Had to remove the heater box and a few other things to get it to fit. Will work on final placement this week. Here are some shots of the engine.
lobie4x4.com
CFSJC
Old 03-26-2011, 01:37 PM
lobie's Avatar
Red face
While I was taking the heater box out decided to go ahead and rip the carpet out. No surprise I knew it was there. Will need some replacement floor pans. Anyone know the best place to get them?
lobie4x4.com
CFSJC
Old 03-26-2011, 04:40 PM
Dos Jeepos's Avatar
Dos Jeepos Dos Jeepos is offline
You can get replacement floor pans fro bj's offroad http://www.bjsoffroad.com/cartgenie/...st.asp?scat=12.
76' J10 360
77' Cherokee 401 SOA
Old 03-26-2011, 06:51 PM
Eugene 1's Avatar
Eugene 1 Eugene 1 is offline
what is that manifold from ?
1970 Charger Daytona
2005 Ram 1500 Hemi
1979 Cherokee Dodge CTD with running Gear Build thread
MoPaR
Old 03-26-2011, 07:06 PM
lobie's Avatar
Not completely sure but I think it is from the 5.9 common rail. 2002+ models.
lobie4x4.com
CFSJC
Old 03-26-2011, 07:09 PM
lobie's Avatar
They like their sheet metal. May just make my own and roll some bead it it for strength.
lobie4x4.com
CFSJC
Old 03-26-2011, 07:18 PM
Eugene 1's Avatar
2005 Ram 1500 Hemi
MoPaR
Old 03-27-2011, 11:29 AM
taylorjones's Avatar
taylorjones taylorjones is offline
Transmissions
I've been loosely thinking of doing a 6bt swap in my 83 cherokee. you got rid of your tf 727, but i want to keep mine. Do the bolt patterns match? Or does the nv4500 just completely make it worth it.
Old 03-27-2011, 11:36 AM
lobie's Avatar
727 hasno overdrive. I have a 5 speed getrag. The nv4500 is good but I think (from searching and reading) the getrag is just as good. I got a good deal locally too.
lobie4x4.com
CFSJC
Old 03-27-2011, 11:39 AM
lobie's Avatar
The diesel bellhousing is different bolt pattern. Not sure about input, output shafts, or internals
lobie4x4.com
CFSJC
Old 03-27-2011, 01:18 PM
Eugene 1's Avatar
you can get a 727 in a diesel np208 bolts up ,but it i will be in a Dodge truck from 89-91.5 after that they became Od transmission Rh model rear drive hydraulic control
2005 Ram 1500 Hemi
MoPaR
Old 03-27-2011, 09:03 PM
VonBoomenstien VonBoomenstien is offline
DUDE!!! thats awesome.
Wreckoning Day build page
Old 03-27-2011, 09:53 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
I read your entire thread all the way thru first too see what all you had done, but when I first saw this pic it hit me. IF for some reason you needed the engine higher up you could use a hood with a high rise in the middle to give a few inches of clearance. I made my decision to go with a 4BTA instead of a 6BT because I didnt want to deal with clearance issues, but it doesnt look like you had any. I also intend to use an underdash HVAC set up.
Originally Posted by will e
Old 04-01-2011, 02:47 PM
Dos Jeepos's Avatar
Portal axles
I want to know how those axles are going to work. I want to put them on my J10.
76' J10 360
interested in a Cherokee Chief. MisterKeith General FSJ Discussion 11 11-12-2009 06:18 AM
Cherokee Chief and Cherokee 'S' Decals billyrb General FSJ Discussion 6 10-12-2009 03:26 AM
The Cherokee Chief myth threepiece General FSJ Discussion 44 06-02-2007 06:01 AM
1979 Cherokee Chief - Pater Matusov Dome Cherokees 0 08-21-2005 12:19 PM
Resurrecting my 79 Cherokee Chief W/T 2MUD-IN General FSJ Tech 9 09-15-2004 02:41 AM
