Old 03-06-2011, 09:04 PM
Keanu151515's Avatar
Keanu151515 Keanu151515 is offline
78 J10 long bed swap to stepside
Call me crazy but im looking to swap my long bed out to a early short bed stepside. Always loved the stepside look better. well, the bed itself is from a newer j series and the fenders are from an early gladiator
Doing some measurements the only thing that i can tell from my infinite knowledge is that the mounts are all the same except for the distance between the center two mounts which is 1ft shorter on the stepside than the long bed.
My plan is to cut the new bed in half and weld in a 1ft section to extend the bed to the correct distance for the mounts.
Has anyone ever done this or know of someone who did it?
1978 Jeep J10 360 4bbl, T18A 4spd, D44 axles
1971 AMC Javelin SST 401 4bbl, 727, Drag car
1967 Pontiac Bonneville Convertible 400 4bbl, T400, newest project
My other vehicle is a U.S. Navy Hovercraft (LCAC)
Paved Roads: Another Fine Example of Unnecessary Government Spending
Old 03-06-2011, 10:06 PM
247pia's Avatar
247pia 247pia is offline
I would shorten the frame and put the mounts where you need them. It will look better and be much easier.
79 Cherokee 360, T-18, Dana 20, Locked tons. I give up.
08 Liberty, 97 Z71
Old 03-06-2011, 11:13 PM
M715 bed is long bed. Just saying.
Old 03-07-2011, 07:36 AM
If a '78 is like my '77 (I'm sure it is), the same frame rails are used for the short and long beds. If you look under the truck, you'll see the holes that mount the springs further forward. The extra length is cut off the ends of the frame rails. All the extra length comes off the rear of the frame rails. Take a close look at the frame and you'll see how they did it.
So, if you change to the '78 short bed length, the frame mods will be fairly easy.
Old 03-07-2011, 05:48 PM
WHSII's Avatar
WHSII WHSII is offline
Hack-Priss
1890 short bed and long bed frame specs
Above are 1980 Jeep J10 long and short bed frame specs.
If the picture is not readable, go to the link below and you
can enlarge the pictures and print.
Someone correct me if I am wrong, but I believe these specs hold true from early 70's to 86.
Hope this helps.
https://picasaweb.google.com/BBQ.WartHog/IFSJA#
WH
Herbina 1987 Grand Wagoneer
Old 06-15-2018, 10:47 AM
robvolz robvolz is offline
I could sure use a clear pic of the frame dimensions for the long bed frame.
help me out??
Axle Swap?? J10 to XJ jeepforever_05 General FSJ Discussion 4 12-01-2008 07:06 PM
'88 J10 360/TF727 swap into '89 Wranger with 258/auto xjh3 General FSJ Tech 24 08-28-2007 09:07 AM
What to swap for j10 styleside bed fivepack General FSJ Tech 4 08-21-2007 12:36 PM
Howdy and 79 J10 4.0 engine swap ?s DaveBork General FSJ Tech 1 03-31-2004 03:41 AM
