Old 09-12-2005, 12:27 PM
malodin's Avatar
malodin malodin is offline
ive got a jeep th400 mated to a dana(?) im not sure exactly what it is, its gear driven looks to be twin stickable
here are the part numbers i found on it.
on the tag is 300596 - 75
994537
on the body of the case is c18-15-24with a sideways 5
on the rear output shaft is c18-19-44
and on a weired little tag that looks to be bolted onto the body but also looks like it is cast on the body is 2x29
any help would be appreciated, i will try and get pix tomorow
Old 09-12-2005, 12:44 PM
brent's Avatar
brent brent is offline
try this: http://www.ifsja.org/tech/figures/db.shtml
or the Novak links--they deal with the stamped case numbers you have and the physical diffs:
http://www.novak-adapt.com/knowledge/model_20.htm
http://www.novak-adapt.com/knowledge/model_18.htm
Brent
79 J10 360-T18-D20 D44's 31X10.5 Edel 1406 w/R4B, speed
-despite thousands invested, 360 in putrid death dance-
"Buy the Ticket, Take the Ride."
Old 09-12-2005, 12:45 PM
brent's Avatar
Brent
Old 09-12-2005, 12:49 PM
malodin's Avatar
thanks that will be handy reading tonight
Old 09-13-2005, 12:17 AM
bvibert bvibert is offline
AFAIK The D20 has a center rear output (behind the input) and the D18 has the rear output on the passenger side (behind the front output). Also I don't think the D18 ever came in a FSJ.
Brian
78 Cherokee S, 360, TH400/QT, 61K orig miles
Old 09-13-2005, 12:52 AM
Green Giant's Avatar
Green Giant Green Giant is offline
Dana 18
Dana 20
Todd Moon
78 Cherokee Chief
78 Chief
66 J-3600
69 J-3500
67 CJ-5
67 J-100 w/BARN DOORS
48 CJ2-A
Proud member of Carolina Full Size Jeep Club
cfsjc.com
No part of this post, written or pictured, may be re-used by any individual or organization or publication without my express written permission.
(Thanks, Flint!)
Old 09-13-2005, 04:13 AM
malodin's Avatar
yup its a dana 20, so now my other question would be, is it possible to take the strength in gears and guts of a d300 and swap them into the d20 so that i can mate it up to my th400?
Old 09-13-2005, 11:39 PM
scotty's Avatar
scotty scotty is offline
no,the d300 case is dimensionally different. even if you could fit the gears into the d20 hosuing,youd need to find a d20-style "bull gear" that would be compatible with the other inner gears. this gear does not exist that will fit the th400 factory d20 tailsahft(15 internal splines)
the spicer 18 wont fit for the same reason(unless you rebuild it with the d20 gears) and you even have to be careful mix-n-matching d20s,as there are 2 different pitches of the cut on the angle cut teeth.
more info:
http://www.novak-adapt.com/knowledge...gears_grid.htm
[ September 16, 2005, 04:18 AM: Message edited by: scotty ]
scotty
85 grand wagoneer
258/t18/d20/10 bolt/14 bolt
38" TSL SXs
chopped,bobbed and caged
Old 09-15-2005, 03:41 AM
malodin's Avatar
thanks scotty, looks like for ease of use ill be looking for a 727 tranny...or find a part time kit for the qt(though id much rather have the gear driven case) and bolt my 300 to my baby xj.
