Old 02-23-2011, 08:29 PM
44BZ's Avatar
44BZ 44BZ is offline
What kind of engine paint?
I've seen a lot of pretty engines on the site and I'm working toward adding some color to mine. I've been using DupliColor Engine Enamel rated to 500 degrees, which should be fine for most everything under the hood I think. Will this be good enough for the block as well? I painted my exhaust mainfolds awhile back with the same type of paint and some of it burned (turned black). Probably need to use header paint for that, but will the 500 degree paint work on the block?
Zack - 68 J2000, AMC 327 w/ Rambler 4bbl and Pertronix upgrade, Holley TA470, T18 4spd, dana 20 (twin sticked), 3" body lift and 38s ~ running AND driving!
Old 02-23-2011, 08:37 PM
jeepjerry's Avatar
500 degree paint should be fine. The only part you may see problems with is around the exhaust manifold ports on the head. Otherwise the engine itself shouldnt get to much more temperature than your temp guage says it is which should be around 220-230 degrees at most. Ive painted valve covers with regular spray paint before and its been fine.
1977 J-20, 4bbl 360/t-18, 33"s.
1976 CJ-5 mild 360/t-18, 6" lift, 35"s.
1972 Javelin SST, full roller Indy head AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 02-23-2011, 08:41 PM
44BZ's Avatar
good to know
Old 02-23-2011, 09:07 PM
Showngo's Avatar
Showngo Showngo is offline
Another good paint is One shot sign paint.I've painted engine blocks frames,springs,I even touched up a chrome hedder at the collector to keep it from rusting.Comes in many colors,stays glossy,fluid resistant,Brush it(levels out pretty good) on and no need to tape off,or thin it down and spray it.I've had much better luck with it than dupli-color hi heat paint.
90 Wagoneer w/65 Wag.grille,Cj7 lights,360 AMC w/edelbrock perf.cam,lifters,timing chain,intake,carb,and,headers,custom SS exhaust w/magnaflow muffler,Black cherry pearl w/cordovan interior.Rusty's 4" lift w/KMC revolver bronze 17 x 9 wheels ,&Kumho 285-70-17 tires(33").http://s220.photobucket.com/albums/d...nd%20Wagoneer/
Old 02-23-2011, 09:27 PM
44BZ's Avatar
Any specific issues with the dupli-color? So far I've only used it on the valve covers, alternator brackets, and pulleys...
Old 02-23-2011, 09:51 PM
Dr. Marneaus's Avatar
painted my greasy old motor with duplicolor...fast and dirty, we'll see how it holds up.
Looks purdy on the stand....dunno how long it'll last once its in...but i'll concentrate my painting efforts on the engine that actualy gets rebuilt.
Originally Posted by FSJunkie
The Mag - The Wag
Old 02-23-2011, 10:49 PM
44BZ's Avatar
Looks good Doc. Same thing for me, the motor looks pretty gnarly and figured some paint would go along way to spruce it up but it doesn't need anything super fancy...
Old 02-23-2011, 11:04 PM
68_Gladiator's Avatar
68_Gladiator 68_Gladiator is offline
I used the duplicolor stuff when i did my 327. just be sure to make sure parts are nice and clean. And i used VHT (very high temp) brand paint on the exhaust manifolds
"Go Brow or go home"
67' Gladiator, 383/SM465/NP205, Open Dual Exhaust, Dana 60 Front, 14 bolt rear(disc brakes), 52/56 spring swap, hydro boost, 4" lift, AKA "Dr. Pepper"
Build thread: http://www.ifsja.org/forums/vb/showthread.php?t=122737
Old 02-24-2011, 07:43 AM
Showngo's Avatar
It just looses is glossyness pretty fast and dosen't hold up well to engine fluids and cleanerson the block and heads.
Timing Chain Cover and Engine Painting ??? The PIG Smith General FSJ Discussion 5 07-22-2009 12:44 PM
engine paint moparman21 General FSJ Discussion 4 05-05-2009 09:09 PM
Engine Paint Scheme The PIG Smith General FSJ Discussion 45 07-11-2007 05:52 AM
engine paint scheme: AMC-style GED General FSJ Tech 21 09-11-2005 03:41 AM
correct engine paint for 77 401 antonellomopar General FSJ Tech 3 08-09-2004 06:23 PM
