Old 02-20-2011, 02:57 PM
slewfoot73 slewfoot73 is offline
Noob!
Cool axle swap advice
I have a 77 J-10 havent looked yet but was told the rear end was blown, so he threw in a axle out of a mid 70s waggie, How do I tell if the the gear ratio's are the same before i do the swap? would it be easier to swap out the ring and pinion or would it be best to just swap out the entire rear end?
Old 02-20-2011, 03:36 PM
I don't think you are going to get a waggy rear axle into the J10, much too narrow and the perches are not even close for a swap over.
Should be a tag attached to the diff cover giving you the gear ratios.
Since you have not seen it (don't have it apart) it may not be the ring and pinion, could be a busted shaft, could be a number of things.
I wouldn't get to worked up over it until you know what's really going on, swapping ring and pinion will mean resetting the gears.
axle swap thing2 General FSJ Tech 9 04-16-2010 03:01 PM
Recommended front axle swap for a 73 J2000? farinspace General FSJ Tech 11 01-26-2010 06:16 PM
chevy dana44 axle swap questions and general axle swap questions malodin Off-Road FSJ Tech 8 08-10-2007 07:12 PM
Front axle swap (SOA) JeepinMatt General FSJ Tech 4 02-17-2004 08:50 AM
Axle swap and brake system idoc General FSJ Tech 8 10-14-2003 10:47 PM
