Old 01-21-2011, 01:08 PM
Dumpy's Avatar
Dumpy Dumpy is offline
What did you replace the back carpet of your wag with?
I was thinking about taking out the carpet in the wag and using some thick rubber or even some of those cheap gym floor puzzle piece mats as a liner so I can easily remove it and access my tank/sending unit. Anybody do this or something similar? I figure the puzzle pieces will provide some decent insulation.
Justin
'72 J2000 360 4bbl T18 D20
'96 ZJ
Old 01-21-2011, 01:44 PM
Karvin Karvin is offline
Going to Monstaliner mine. I do not have the access port to the top of the fuel tank, so I will cut that myself before I line it. And of course line it afterward and in separate pieces so as not to "lock" myself out of my own mod.
Noise isn't an issue, only because there is already so much of it... trying to use sound deadening items would be a waste of time in my situation.
1977 Cherokee Chief Levi's Edition: specs to follow investigation.
2002 TJ Wrangler "APEX" Edition 4.7 Stroker, 4" RC Lift, 33" Toyo MT's, SmittyBuilt Front Bumper. More to follow
1974 J-10 258, T18/D20, D44 F/R 4.10 gears and LSD (No... not that type of LSD)
Old 01-21-2011, 08:30 PM
Wayne's Avatar
Wayne Wayne is offline
Took mine out, and left the rubber mat that was under the carpet.
78 Wagoneer 401/T400/bw/44F&R DD 4in lift
Old 01-21-2011, 09:04 PM
Dumpy's Avatar
I pulled the carpet to look today and it looks like I'll be fabricating an access hole as well. The rubber mat in mine actually looks great! Did you notice a noise difference when you pulled the carpet? My carpet is dry rotted on the tailgate end. I figure the puzzle floor will provide extra noise dampening and insulation, as well as a good base for car camping.
Justin
'96 ZJ
Carpet install help -- flag QT shifter rmorit01 General FSJ Tech 7 12-03-2010 06:16 PM
vinal floor or carpet noise and moisture questions dusty General FSJ Discussion 4 02-20-2009 03:06 PM
Back for more of the headaches! Mud Menace General FSJ Discussion 4 01-21-2009 07:35 AM
back to square one chaos General FSJ Tech 4 06-04-2006 05:51 AM
Different types of carpet 65-f100 General FSJ Tech 2 05-25-2006 09:25 PM
