Cutting D44 Ends Off
I need to cut mine off and re-weld so the caster is correct (pinion rotated due to lift). Does anyone have a link to a video that shows how - and tip on what to do and not to do. I've never tried this before.
Thanks!
'78 Chief S W/T 360cid +.030 & RV cam, AGR steering gear, '80's Astro Van hydroboost, '84 GW steering pump, Edel elec fuel pump, TFI, MSD 6A, MSD eCore 48Kv coil, 8.5mm Spiral, TH400 w/ TCI +2qt pan & shift kit, BW1339, open D44's w/ 3.54's, EDL1406 w/ off-road, 4" spring lift, Rancho, 15x10 MT Classic Locks w/ 33x12.5 Goodyear MT/R's
