Old 12-12-2010, 11:32 PM
CJ the noisemaker's Avatar
CJ the noisemaker CJ the noisemaker is offline
Definity Dakota A/T: good, or bad?
what do you think? does it look like it would be a good offroad tire?
CJ
[/color][/size] -1985 Ford LTD Country Squire "Rarity" - 302/AOD
Old 12-13-2010, 02:11 AM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
manufacturer rep, compound rating, how many K miles rating, and price will help. Never heard of 'em personally.
Originally Posted by will e
Old 12-13-2010, 04:29 AM
jeeping1974's Avatar
If you are doing class VI roads they looks like they should do fine. I'd go with something a little more aggressive myself though.
03 GMC 2500HD - DD/toy hauler
06 Street Glide - Cruiser
Old 12-13-2010, 10:00 AM
Josh D's Avatar
Josh D Josh D is offline
CJ, knowing how you like to go out into the desert with your buddys, you should be looking at a tire with a strong sidewall like a BFG A/T. That tire you are showing is a two ply at best, and a pretty thin two ply I'd imagine.
'71 J2000 Gladiator
'95 YJ on Waggy axles
'80 911 Super Carrera
Old 12-13-2010, 11:08 AM
kymtnman's Avatar
kymtnman kymtnman is offline
i got these a few weeks ago, i like them so far. deep tread and they also have the bead protector. i got my local small time tire guy to order them from his supplier to avoid the pricy internet shipping charges.
http://www.4x4groupbuy.com/store/fed...16-p-9899.html
82 scrambler 360 widetrack 44's t-18 & 36" swampers
97xj 3" lift 31" trxus
59' gmc stepside 496 stroker, 4-speed "fun fun fun"
& new project., 79 cherokee 360 q-trac
Old 12-13-2010, 07:27 PM
billyj7175's Avatar
I ran a set of those on a Samurai years ago. They worked pretty good for an all-terrain type tire. If I remember correctly they were a pretty inexpensive tire.
X2 on the sidewalls. I ruined one on the rocks, but that was honestly my fault at the time. If I had been paying attention it probably wouldn't have happened. But again, that was on a 2,000 lb vehicle.
Not sure what size you're wanting, but IIRC, they offered a hd version on the 235/75's (more like an LT).
83 J-10 Jeep "Oscar"
360/727/229
Old 12-13-2010, 08:50 PM
jeepjerry's Avatar
I think those are the same as the old Futura Dakotas. My dad put a set of those on his old '80 j-10 a few years back and they were nice tires. They shouldnt be too bad off road for an all-terrain. Looks just about the same as pro-comp all terrains....or any other all terrain for that matter...
1977 J-20, 4bbl AMC 360/t-18,33"s.
1976 CJ-5, Healthy AMC 360/t-18, 6" lift, 35"s.
1972 Javelin SST, mild AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Old 12-13-2010, 10:45 PM
Gambler68's Avatar
Rabble Rouser
MT's or stay on the pavement
Those tires you're looking are lacking direct channels to clean the lugs of anything goopy on the sides of the tread contact patch. Water maybe.. and considering all the sharp jabby things in the desert sticking up outta the sand..you want more sidewall plys as people said.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 12-13-2010, 11:52 PM
I have been using highway tires on my wheeling expeditions...
Ask anyone I have been wheeling with.
CJ
Old 12-14-2010, 12:13 AM
Gambler68's Avatar
Rabble Rouser
You get a real off road tire on there and you'll be amazed. There are good Mud Terrain tires out there that ride nice on the road. But if you do a lot of pavement driving, a quality AT should do you fine..I understand it's 95 percent dry dirt and sand with some rock down there compared to what we wheel up here. AT's just don't cut it in powder snow and mud here.
Take a look at my pic..you can see every couple lugs are clean. With AT's, they all clog up, and then you get a layer of good that sticks to THAT..in 10 feet, you have a skin of crap about 2" thick that sticks to the tire. With good self cleaning lugs that pretty much only MT's deliver, this doesn't happen if you can get enough wheelspin to clean em out.
Now on slickrock, you actually do better with more rubber contact with AT's and (gasp) highway tires, but you still need to get something better than 2 ply unless you actually like changing them on the trail..and with stronger tires you can air down with less risk of really tearing them up. (airing down gives you even more contact surface).
Old 12-14-2010, 09:40 PM
AlsChopShop's Avatar
if you need cheap off-road tires, find a shop that carries Summit brand tires (usually small independent shops). i picked up a set of LT265/75/16 tires for $400 mounted and balanced that are identical as the maxxis bighorns. they have served me well for 5 years, and just now are finally wearing out. they do fantastic offroad, especially in the wet sticky stuff.
Al
Old 12-18-2010, 08:46 AM
81cherokee laredo's Avatar
81cherokee laredo 81cherokee laredo is offline
Just picked up a set of the street version of those for the wifes truck. They're manufactured by Cooper, just dont carry the Cooper name. They do have same warranty and road hazard as the Coopers.
Dan
81 Cherokee Laredo- 360 727 NP219 SOA/SF 35 Coopers 4.56 Gears
83 Cherokee - Katy- long term project
89 Grand Wagoneer- 360 727 NP229 31x10.50's on slot rims
4350 kits - what brand and how good? rreed General FSJ Tech 11 03-13-2007 12:16 PM
Dakota Digital or Z&M gauges asdrsd Customer Corner: (Vendor product discussions) 15 03-07-2007 11:47 PM
Feel Good Story JeepSker General FSJ Discussion 0 02-14-2007 10:52 PM
Good timing light? rreed General FSJ Tech 20 12-26-2006 10:57 PM
