Old 12-09-2010, 07:47 PM
bijna's Avatar
bijna bijna is offline
Is there a good smog/emissions removal guide somewhere?
I've searched the forums numerous times trying to piece together how to do this myself, but most threads are about the pros and cons. Well, I'm tired of constantly having to deal with vacuum leaks and I don't need to pass emissions in my state, so I want it gone.
I have an 83 wag limited 360 with np229(vacuum controlled), I want to have all nice things like power steering, brakes and heat, but I want gone the smog pump, ctos, and blah blah canisters. Can someone point me in the right direction? If not, I think I may venture forward with what I've got and do a write up myself.
I like to Party.
Old 12-09-2010, 08:01 PM
try this...
http://www.google.com/search?client=...b106dc5a2374ad
Old 12-09-2010, 09:11 PM
Tripwire's Avatar
Tripwire Tripwire is offline
In my opinion - - which wont count for much...
You can remove off alot of stuff - especially if you convert to fuel injection - which i did.
I think that one should keep the EGR system and Cat converter...yea it may cost a tiny bit of horsepower and possibly a tiny bit of fuel economy ....but we all have to breathe - and so will your kids
FOR SURE keep the entire PCV and fresh air to air cleaner to oil fill tube system intact...it sucks out blowby and water vapor to be reburned and significantly reduces the build up of gunk inside the engine - and possibly reducing blown seals ( not the joke about the penguin and the blown seal )
Charcol canister system should also be intact IMHO as it reduces the unburned gas vapor leaching out of your rig and into the atmosphere- and it uses zero horsepower
But im only a shade tree mechanic and many folks will disagree im sure
"You think you hate it now - Just wait till you drive it " ( family vacation - car salesman)
Tripwire. 86 Grand. Howell fuel Injected 360. MSD Ignition + Dizzy. 727/228 BJ's 2" Lift and 31's
88 Wrangler Howell TBI and MSD - Borla Headers w/ Cat-back + winch and 31's AND a M416 trailer (-:
Old 12-10-2010, 06:43 AM
710 Burner's Avatar
Your'e right, I disagree. Your title says Master Mechanic.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
Old 12-10-2010, 03:43 PM
Tigger4X's Avatar
Tigger4X Tigger4X is offline
says the man with no title
Hi my name is Keith; I have Obsessive–Jeep Disorder (OJD) : a mental disorder characterized by intrusive thoughts that produce anxiety, by repetitive behaviors (buying parts and more Jeeps) aimed at reducing anxiety, or by combinations of such thoughts & behaviors such as but not limited to working on said Jeeps for extended hours.
Old 12-10-2010, 04:21 PM
Bill Moore's Avatar
Bill Moore Bill Moore is offline
I useually get a replacement carb without emissions if I cant get the stock carb to run right by plugging everything and removing it. that generation of emissions technology doesnt work properly long anyway, the charcol gets saturated and stops working, vaccuum leaks develop as youve noted, hoses rot, c converters get posined and rot out eventually, so you would have alot of work to do to keep the emissions working properly. I would hate to think what a new c converter costs with the price of precious metals now a days.
DDs
78 J20 Chevy 305 nv4500 np205
67 KJ715 4bt AA OD 465 np205 j20 axles
Projects
73 J2000 4bt NV4500 np205 Dana 60/70 Tow Rig/tremors truck
Starting Sons Build, 1980 short bed J10, to get j20 axles, 4bt, nv4500, np205, M715 bed and fenders
Freedom is not Free, it is paid for with Blood
Old 12-10-2010, 04:24 PM
Bill Moore's Avatar
on second thought, keep the emissions and burn more gas, we need addition carbon in the atmosphere, our temps are way below normal here!
DDs
Projects
Old 12-10-2010, 04:40 PM
SNO*MAN's Avatar
SNO*MAN SNO*MAN is offline
Get a new ch/ canister( posted in another thread) as the old one is probably not working correctly anyways and is needed for gas tank vapors recovery.
Keep the air cleaner to oil fill tube intact as mentioned below. Get rid of the pump etc... but do your self a favor and buy a new cat converter. They are really efficient and way better with little back pressure. They are expensive so keep that last on your list. I have seen older cars pass emissions test with that alone as they are way better than the ones that were first put on the jeeps. It may not ever pass the under hood visual though.
1989 "KRONK"
Detroit front/rear 4.27 gears
Ramsey 9000 modified bronco winch bumper
Built 360/ 700r w/ 241c Lokar floor shifter
Hydro-boosted brakes
20" wheels w/ 35" Toyos
15" Welds w/35" Uncut mud boggers
Dual Ram Air /MSD TFI Ignition /Dakota Dash
www.fastfinishor.com
www.fastfinishor.blogspot.com
www.facebook.com/fastfinishor
Old 12-10-2010, 05:10 PM
palexand palexand is offline
...yeah, see the EPA's web site. Everything you need is there.
Old 12-10-2010, 05:44 PM
Thumper168's Avatar
Thumper168 Thumper168 is offline
All of mine was recently removed, Its a lot easier to work on and no need to worry about vacuum leaks after replacing the few I kept. I just removed my canister completely and vented the tank through the cap, the lines on the exhaust manifold were crimped for the time being untill I install headers and I removed the cat. Id just rip all the vacuum lines off and start from scratch with the items you want to keep.
Saw a good 86 J20 go to the crusher. Chrome General FSJ Discussion 8 01-15-2010 02:13 PM
factory cb radio, any good? FSJsteveo General FSJ Tech 14 03-16-2005 11:57 AM
good Trans rebuild shop in maryland? Wagoneerlover General FSJ Tech 1 06-11-2004 12:31 AM
Where is a good place to wheel around S Ok? BIG BAD JON Events 4 05-11-2002 12:46 PM
How to stop pinging for good.. Joker's '88 GW General FSJ Tech 18 12-06-2001 04:56 AM
