11-10-2010, 08:18 AM
7.5 x 16LT
The tires are flat spotted after years of storage. Rides like a Fred Flintstone Truck. Looking for a replacement.
Thinking about 265/75R16 D she has 7.5 x 16LT on now (someone know a source for the same??).
Anyone have the specs on the stock 16' wheel? Offset, width?
Sorry for the questions. I search before I ask I just didn't find much info on the 7.5 x16 LT.
Tom
'66 J-3000, 327 Vigilante & '66 Alaskan Camper pic
'02 WJ LTD, 4x4, 4.7, 2" OME, 255/75/17 BFG MT
11-10-2010, 09:33 AM
There were 2 options with the 16 inch rims.
Standard rim is 5 inches wide, optional HD rim is 6 inches wide.
Personally, I would opt for new rims, as they would be designed for radial tires.
I have no idea as to offset.
11-10-2010, 01:00 PM
235/85-16 is the radial replacement size, and will fit on factory 5.5 or 6 inch rims (will also fit the early 5 inch but you lose carrying capacity). This size basically replaced the old 7.50-16 bias ply as the standard 3/4 ton pickup truck tire. Common to just about everything from the late 70's through mid 90's. The 265/75-16 is now pretty much the standard pickup truck tire. Both are 32 inches tall. You want a 16x8 rim with the 265.
11-10-2010, 01:07 PM
I'm sure many of us don't mind answering any questions that will help preserve your special truck (and camper).
I blow my horn before it happens, not after.
A good mechanic can fix their own mistakes.
Waste not war not.
Ignorant is blist.
When you're in a hurry... slow down.
Measure once... cut twice.
11-10-2010, 04:47 PM
7.50-16's can be had in both highway tread and drive tread from universal vintage tire.
Highway:
http://www.universaltire.com/truck-a...transport.html
Drive:
http://www.universaltire.com/truck-a...r-traxion.html
Want a modern radial everybody stocks including Wal-Mart TLE, go to a 235/85R16 and yes the 265/75R16 will mount on a 16x6 rim just fine
 If you got 8 lug wheels i would recommend switching to 225/70R19.5's and never have to change tires again
Mike
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX-390 Resto.
1977 Ford F350.
1982 AMC Eagle project SX/290.
1982 AMC/Jeep project J5500.
1988 AMC/Jeep project MJ/343.
1992 GTA Trans AM.
A M C Means jeep to me
11-11-2010, 09:32 AM
Sweet..Thanks Guys. To keep it stock~ish those 235/85/16 look like the ticket.
Tom
11-11-2010, 09:26 PM
You can still buy 7.50-16 bias tires new. A lot of companies have stopped making them, but most tire shops can still get them for you.
I bought a new set maybe 4 years ago for my 71. They look much better then 235/85R-16's. They sit taller and skinnier.
Take a look at universal vintage tire and cocker tire.
1971 Gladiator J2000 Custom-Cab Platform-Stake Dump
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| '66 J 3000 |
F3X |
General FSJ Discussion |
70 |
06-02-2012 09:45 AM |
