11-07-2010, 04:54 PM
Engine question
Got a question and hope its not a dumb one. Is the AMC 360 the same as the Ford 360? The guys I work with say their the same I say their different. Any way the tell me any ford 360 part will switch over to the amc Just needing to settle the argument.
J- Just
E- Empty
E- Every
P- Pocket
77 J10 honcho with levis interior
AMC 360
4 speed
Warn 8274 winch (8,000 pounds)
11-07-2010, 04:57 PM
Nope, two different beasties. The oil fill tube on the AMC 360 doesn't exist on the Ford... a dizzy cap sits there instead, if I remember right.
But since they know so much, put some money on it.
However... the 360 does carry over a lot of Ford's electronics under the hood.
Originally Posted by Locked and Loaded
Jeeps don't get stuck. People do.
Let the good times roll! '83 Wagoneer «◘► ‼» 401/TF727/3:31 AMC20
11-07-2010, 05:00 PM
Thanks I'll print screen this and take it to work after the wager of course.
J- Just
E- Empty
E- Every
P- Pocket
AMC 360
4 speed
11-07-2010, 05:01 PM
How certain are these coworkers about this? See...if they are confident that the AMC 360 is the same as a Ford 360, put a little wager on it...a beer...a sawbuck - whatever you like....then have the engine specs ready.
If you want, you can ask them about the Rambler 327...see if they think it's a small block Chevy....get another beer.
11-07-2010, 06:16 PM
Hell no, not even close. The Chrysler 360 isnt even the same. They are all different motors, just happen to have the same CID.
Baltimore
1991 Grand Wagoneer, Rebuilt 360, Eddy Perf Manifold, Razor Grill
1970 Plymouth 'Cuda (my baby)
11-07-2010, 08:37 PM
Also ask them about the AMC 304, 390 and 401, they'd probably think they're the same as the International, Ford and Buick engines.
1989 Jeep Grand Wagoneer, "Agnes": Stock 360, TC727, NP229 Selec-Trac, D44 F&R, 124,000 miles
Non-FSJ:
1980 Ford Ranger F100 Lariat "Big Black": Tired 302, C4, 2WD, 165,000 miles
_______________________________________________
Current Jeep Status:
Starting reconditioning
11-07-2010, 08:43 PM
My friends are correct and it seems the AMC engineers tried to take the best of all the engines and combine to a very leaky weak motor for us to power up.
Jenny SOLD
1982 Cherokee Chief Wide Track
4 inch lift
360 ci Edelbrock carb and intake
115K
Daisy
1970 Wagoneer by Kaiser
350 Buick/Turbo 400
3.73:1 Limited slip
41K original miles
Lilly
SOLD your a good girl LILLY!
1973 Commando by Jeep
304 2V 3:73 Limited Slip
3 Speed
93K original miles
11-08-2010, 06:50 AM
If you are not paying real close attention and you look at one that has a Duraspark ignition, you might think its a Ford, but the Ford style starter will not work on any Ford because it has a different throw lenght to the drive. The Duraspark, York compressor, and maybe the carb are the only things that will change over.
Mark B. Jones
'76 401 Wagoneer
'79 Chief "Junaluska"
11-08-2010, 08:02 AM
There are no dumb questions
I had a very knowledgable mechanic insist that a Studebaker 289 was the same as a Ford 289. Aside from the completly different design of the two engines and the fact that Studebaker never outsourced engines for US made vehicles He was correct.
'63 wagoneer '87 360 running gear exept T case (207), warn hubs, 3.56 diffs and EFI My own creation, mostly ford CFI Temporary Holley 350 cfm 2 barrel and delco window dist.
'67 Scout 152cid w/EFI and turbo also My own a little help from Chrysler.I am a fabricator, I make stuff up!
11-08-2010, 08:19 AM
Um...have to disagree with you here - at least as far as my 327 and my son's 360 go. Both are very strong, solid engines. The 360's never been out of the Wag and doesn't leak now that the seals etc. have been replaced (130,000 miles). The 327 is leaking a bit - but it was just rebuilt and there's a freeze plug that is still leaking - which gets taken care of on Wed. It doesn't leak a drop of oil.
I feel the AMC engines (sixes and eights) were some of the best of their generation - but that's just me.
