Old 04-12-2004, 01:06 AM
Ferrets's Avatar
Ferrets Ferrets is offline
I did a search on plastic gas tank repair & did not find a sure fire way to repair the cracked tank I have. Its got 1" crack up by the top side where the mounting strap meets the frame. ( caused by the DS government repair team hanging the tank by only two bolts)
Has anyone made a lasting repair with JB Weld? Or tried melting (welding) the plastic with a soldering iron set to 350 degrees or less ?
I'd rather just replace the tank at this point - but all the listings I see are for '79 & older - does anyone know the difference? It seems most photos I saw had the sending unit hole on top and the fill/vent out the side. My '81 has the fill/vent out the front side corner towards the fill plate and the sending unit out the front of the tank.
Thanks
Mark
Old 04-12-2004, 02:34 AM
imported_Carl Rasmussen imported_Carl Rasmussen is offline
I think they will all work I have a 84 and the sending unit goes in the top front corner.
They should all fit but mabe the fill hose is different
pic of my 1984 J10 <br />powered by a 93 chev 350 TBI with a 4L60E 4sp automatic trans. 4\" lift with 35X12.5 Tires 4.56 Detroit locker in the rear(AMC 20) and a 4.56 power lock(dana 44) in the front
Old 04-12-2004, 06:57 AM
Ferrets's Avatar
Maybe I'll try some marinetex first
Old 04-12-2004, 03:16 PM
TexasJ10's Avatar
TexasJ10 TexasJ10 is offline
The think the difference in the pre 1980 tanks and your tank is the width. The earlier tanks were a little wider and did not have driveshaft interference because the rear axle pinion is offset a little to the passenger side. The 1980 and later driveshafts are centered. You have already seen the other differences. I have been trying to find a replacement tank that would fit in the limited space that is provided for the stock tank with no luck. Thes later tanks show up in the for sale section occasionally. I don't think you will get a permanat repair with trying to melt the tank back together since the plastic is a cross link polymer
Old 04-12-2004, 04:59 PM
Ferrets's Avatar
Thanks for the info. I knew there must be some reason the tanks are not listed '80 & up. I roughed up the area till it was real rough. I then MarineTex'd a big patch over the roughed up area. I hope it holds for a while - I'll be on the look out for a replacement tank though.
Old 04-13-2004, 01:24 AM
The Anti-Chrysler The Anti-Chrysler is offline
Disciple of A.M.C.
Here's junkyard listings:
Email me for details on yards I've dealt with that are reliable.
1984
Fuel Tank
Jeep J Series 96906PK $100 Adobe Off-Road, Inc USA-NM(Albuquerque) E-mail 1-888-875-5337
1983
Fuel Tank
Jeep J Series 47313J10 $100 Adobe Off-Road, Inc USA-NM(Albuquerque) E-mail 1-888-875-5337
1980
Fuel Tank
Jeep Truck 2316B $75 B and K Auto Salvage USA-OR(La-Grande) E-mail 1-800-233-9640
1984
Fuel Tank
Jeep J Series 000095022 $75 Brass Ring Inc. USA-WY(Superior) E-mail 1-877-221-5141
1980
Fuel Tank
Jeep Truck NOF $75 Knik Towing & Wrecking USA-AK(Wasilla) E-mail 1-907-376-2584
1980
Fuel Tank
Jeep Truck 2B,258 099011 $75 Knik Towing & Wrecking USA-AK(Wasilla) E-mail 1-907-376-2584
1983
Fuel Tank
Jeep Truck 980765 $65 Lumbert Salvage USA-KS(Winfield) E-mail 1-800-649-6515
1980
Fuel Tank
Jeep J Series - U 2D01 $60 McNeilus Auto & Truck Parts USA-MN(Dodge-Center) Quote 1-800-722-9318 Insurance-Quote
1980
Fuel Tank
Jeep J Series Tr- USED 1181 US$55.56
CAN$75.01 Flesherton Auto Recyclers Can-ON(Proton-Station) E-mail 1-800-463-6002
1986
Fuel Tank
Jeep J Series IN TRUCK 420016016 $50 Estes Auto and Truck Parts USA-VA(Pilot) E-mail 1-877-616-4900
1982
Fuel Tank
Jeep Truck MD78903 OK PLASTIC F224 US$44.44
CAN$59.99 Snyder's Auto Wreckers, Ltd. Can-AB(Brooks) E-mail 1-800-661-1489
1984
Fuel Tank
Jeep Truck J10/J20 PTCCARB,258, 0I2305 $Call #1 Morgan Highway Auto Parts USA-PA(Scranton) E-mail 1-800-648-1441
1981
Fuel Tank
Jeep Truck NOF $Call Patterson Auto Wrecking, Inc. USA-PA(Cochranton) E-mail 814-425-7415
1981
Fuel Tank
Jeep Truck 360 OB0156 $Call Patterson Auto Wrecking, Inc. USA-PA(Cochranton) E-mail 814-425-7415
1981
Fuel Tank
Jeep Truck PLASTIC TANK 8185 $Call Forest Lawn Parts Depot Can-AB(Calgary) E-mail 1-800-463-0562
1982
Fuel Tank
Jeep Truck J10/J20 PU- W DUAL TANKS,LH REAR 82825 $Call Parts N Cars, Inc. USA-NE(Omaha) E-mail 1-800-433-3091
Jason Davis
'82 J-10 Laredo, 360, T-177, 4" Rusty's
'85 J-10 (parts)
'09 Pontiac G8 GT Sport, '97 Sierra (Vortec 454), '98 Silverado Z71 (5.7 Vortec)
Old 04-13-2004, 07:16 AM
crispyboy's Avatar
crispyboy crispyboy is offline
I don't know if you can fix them but only 79's and before can be purchased new. I believe that 80 and newer had the fuel sending device mounted on the front side of the tank and this has been outlawed by the Fed's. I found one in a junk yard for my dads truck as his tank cracked in the same place.
Steve<br />1986 J-20 360 cid/auto, trac-loc, custom efis tbi, flowkooler, aluminum cross flow radiator, rhino-liner, working AC. <br />1990 GW trac-loc, Engle cam and aluminum cross flow radiator.
<br /><br />\"The best Jeeps came from the past when gay meant you were happy and Aids was an appetite suppressant"
Old 04-13-2004, 12:20 PM
Cecil14's Avatar
Cecil14 Cecil14 is offline
I had a crack in mine on the top that was leaking and I used JB weld about 2 years ago. Still holding so far. Just roughed it up real good with some sand paper then cleaned it up and went to town.
Anthony
Anthony
1983 J-10 - 4.6L(MPFI)/CS144/NV3550/D300/44/44/3.54/32
1983 Honda CB1100F
1983 Honda CB1000C
Old 04-13-2004, 07:04 PM
j10jim's Avatar
j10jim j10jim is offline
So, can one just install a 79 or earlier fuel tank into say a 1980 J10 with a 78 J20 D60 rear end (offset slightly to the pass side)? That is my setup and I would like to get a bigger tank (Aero tanks has them). Also what about the sending unit/hoses?
Thanks,
Jim
1980 J-10<br />Rusty\'s 4 inch lift<br />2 inch body lift,<br />35 in Xterrains on J20 axles<br />4:30 gears<br />Detroits<br />In-Cab cage thru the dash
Old 04-14-2004, 02:51 AM
Cecil14's Avatar
That should work, you'll need the filler neck from the older truck I would imagine but you should be able to extend/shorten the wiring and fuel lines to the sending unit pretty easy. The fuel lines to the tank are rubber anyway and should probably be replaced by now regardless.
Anthony
Anthony
1983 Honda CB1100F
1983 Honda CB1000C
