Old 10-09-2010, 08:36 PM
Coryd55's Avatar
Coryd55 Coryd55 is offline
Quick Engine Question
I feel like my engine is sitting and to extreme of an angle.
Both bolts of the engine mounts went into the slots furthest from the transmission. Is this correct?
It is hard to tell, but this is the best picture of the angle.
1976 Cherokee Chief Build - Update 12/10/12
Originally Posted by sportsidedan
beautiful!!! stunning...
Status: Painted, Running, Driving, and Stopping!
Chief for sale!!
http://www.ifsja.org/forums/vb/showthread.php?t=162051
Old 10-10-2010, 07:40 AM
Do you have the tranny mounted to the crossmember in that pic?
1979 Cherokee Chief<br />4\" BDS Lift and shocks<br />Superlift Brake Lines and Stabilizer<br />Custom Bumper w/ Tow Hooks and Hi-Lift<br />Poly Gas Tank<br />32\" x 11.5\" x 15\" BFG All-Terrains<br />15\" x 8\" American Racing \"Pythons\"<br /> T.H. 400 Borg Warner 1339 Quadra Trac <br />Mile marker 16% overdrive part time kit<br />360c.i. Edelbrock carb, cam, intake, muffler<br />MSD ignition and Blaster2 coil <br />Taylor spiro pro wires<br />Random Technologies catalytic converter<br />Bored .030 over<br />Doug Thorley headers<br />stainless steel exhaust<br />Flow Kooler water pump<br />TFI upgrade<br />Flo-Fit seats<br />Herculined floor under ACC carpet
Old 10-10-2010, 12:41 PM
Coryd55's Avatar
No. Tranny and t case are out right now.
Chief for sale!!
Old 10-10-2010, 01:32 PM
The Colonel's Avatar
Once you install the trans and cross member it will put the engine in position.
Old 10-10-2010, 03:27 PM
talntar's Avatar
talntar talntar is offline
support the rear untill trans is in.your putting a huge strain on your new mounts now
85 gw 215k and still going
89 gw,free,almost legal
Old 10-10-2010, 04:37 PM
Coryd55's Avatar
Did that earlier. I figured it was putting some unnecessary strain on something somewhere.
Thanks. I will be getting tranny and t case in as soon as I can.
Chief for sale!!
Old 10-10-2010, 08:00 PM
caionneach's Avatar
caionneach caionneach is offline
Did this vehicle originally have a V8 or 6 cylinder?
There are two sets of holes on FSJ frames, and IIRC the ones "furthest" from the tranny are for the 258 cid engines since the block is longer than V8s and require the frame horns to be in a different location to be center mounted. The V8 frame horns are closer to the tranny, so it sounds like you have the mounts in the 258 set of holes.
I would measure the tranny/transfer case, then put the tape on the driveshaft and measure back to the engine. I think you'll see that there's going to be a gap that corresponds to the difference in the two frame horn positions referenced above.
1982 Cherokee
258 cid/T-5 $15 Sunpro Voltmeter gauge
replacement; Quadratec Trailmax Thermal Pro
Seats! 4 inch SKYJACKER suspension lift, 33X12.5 in
BFG Mud Terrain Tires on 15X10 in ProComp Rims.
New BJ's chrome-moly rear axle shafts, 3.73:1 diffs and ARB Air Locker!
Old 10-10-2010, 08:18 PM
Coryd55's Avatar
It had a 360 off the assembly line. I put it in the two furthest from the tranny/closest to the front bumper because that was the position of the 360 in the 88 GW parts Jeep we have.
I will try to measure it tomorrow.
Chief for sale!!
Old 10-10-2010, 11:02 PM
caionneach's Avatar
Then I stand corrected.
If you had a 360 stock, and mounted it the way it was, then that's the way it should be.
1982 Cherokee
HDC CTO (???) Gil General FSJ Tech 46 03-31-2010 10:23 PM
Securing an Engine for Transport Question Jay-ten General FSJ Tech 10 01-31-2009 11:57 PM
J3000 engine replacement question. Jeff in north Texas General FSJ Tech 11 10-26-2008 03:09 PM
Quick question c_cort General FSJ Discussion 19 08-16-2007 12:11 PM
quick engine install question gwinn General FSJ Tech 2 10-04-2002 09:51 PM
