Old 09-29-2010, 08:37 PM
silvercert silvercert is offline
is this trailer too big?
Is this too big to pull behind a Wagoneer for camping gear and such?
http://www.govliquidation.com/auctio...&convertTo=USD
Old 09-29-2010, 08:48 PM
j20brett's Avatar
j20brett j20brett is offline
actually they are perfect. pick it up
"Kaiser" - 1981 J20 113" WB - 360 w/ hei/727/208-spooled hp60/detroit 14blt w/5.13's - 42's/CS144/Taurus fan/flatbed and roll bar
Future mods - 6.0l chevy
Build Thread
Fight Crime...Shoot Back.
Texas FSJA!
ΜΟΛΩΝ ΛΑΒΕ
Old 09-29-2010, 08:50 PM
kwai's Avatar
kwai kwai is offline
That trailer will work fine behind the wagoneer. It will sit a little high unless you have a lifted wagoneer and flip the lunette so that it sits lower. The A2 version has the 16" 8 lug wheels. Originally designed to tow behind the M1008 CUCV truck.
1976 Cherokee Chief
1968 Kaiser M715
1981 Scrambler Laredo
Old 09-29-2010, 09:17 PM
Daddio's Avatar
Daddio Daddio is offline
I had one until recently and I felt like it was a little too big for a stock height and tire size wagoneer. Even more so if your rear springs are sagging. You can change the axle on the trailer and use matching tires and wheels on both, which would lower it quite a bit. Matching tires between the trailer and tow vehicle was the original plan from the military. Those tires and wheels are smaller than the ones on my old trailer so maybe your axle has already been changed.
It's not too heavy but you will know it's back there. The other things you probably know about are the pintle hitch and NATO 12 pin light plug. The trailer lights are 24v if original and easy to switch out. They also weren't designed for maximum visibility. You might need this as an adapter:
http://saturnsurplus.com/electrical/23321.htm You can find the wire info online fairly easy.
One last thing to check is if you will get a title or is it already licensed. Sometimes it's complicated to register former military equipment.
'88 Grand Wagoneer, towing package, 360 .030, Holley Street Dominator intake, Holley Projection, rv cam, double roller timing chain, HEI, CS144, oil pump mid plate, Thorley Headers, BJ's 3" exhaust, and more...
http://www.youtube.com/watch?v=xWWCj...layer_embedded
Old 09-29-2010, 09:31 PM
Daddio's Avatar
Here is the one I had:
http://www.govliquidation.com/auctio...tegoryId=e5434
M101A1 not a M101A2
Old 09-30-2010, 06:44 AM
Newjeeper22's Avatar
Newjeeper22 Newjeeper22 is offline
id get it, cool trialer
77 J10
basketcase
Old 09-30-2010, 07:41 AM
Lindel's Avatar
Lindel Lindel is offline
Perfesser of Jeepology
Just keep in mind, it'll have a pintle tow setup, you'll need to get the proper hitch for the tow vehicle, or change the trailer.
Other than that, it'll be fine. Change the 24V bulbs for 12V and you'll be golden.
Jeep Grounds
RRV Homepage
1987 Grand Wagoneer
AMC 360/TF727/NP229
1999 Wrangler Sport
4.0L/AX-15/NV231
Old 09-30-2010, 08:44 AM
M101A1 not a M101A2
How much did you end up paying for it? I can't believe the price would stay at 150
Old 09-30-2010, 09:46 AM
Gambler68's Avatar
Rabble Rouser
You can get pintel hitches from Northern Tool..no idea if they are road legal.
Cool trailer!
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
Old 09-30-2010, 10:09 AM
CutterN55's Avatar
Silvercert- stay on top of the bidding and no the price probably won't stay at 150. usually they go for at least a couple hundred bucks. I've been looking for one for a while and may have found one I can snag up cheap.
Gambler-the pintle hitches are good to go as far as I know, I had one on my car hauler.
ROMANS 12:1-2
'89 GW deceased
Ford 4spd swap Np435/205
Old 09-30-2010, 10:17 AM
CutterN55's Avatar
FWIW the M101's are sit higher and are heavy and would not be good for trail use. If using as a utility trailer they'd be okay.
The M416's are the really cool ones that go well behind a trail jeep. they are the shorter 1/2 ton version and you can do some cool stuff to them.
ROMANS 12:1-2
'89 GW deceased
Old 09-30-2010, 08:56 PM
Daddio's Avatar
Here is a picture of the the trailer I had. I paid 400 and sold it for 400. I'm sure I could have gotten more, but I wasn't trying to make money off the deal. The previous owner is the one who repainted and he did a great job.
FSJ TRAILER QUESTION FSJ-Earl General FSJ Discussion 23 07-14-2008 04:00 PM
Trailer wiring short Wagonforever General FSJ Tech 1 06-19-2008 07:23 PM
Trailer Light Pigtail Question? RAMBLINFSJ General FSJ Tech 8 05-03-2008 02:16 AM
Car Trailer to haul J4000 aerocorey General FSJ Discussion 7 07-01-2007 06:50 PM
