Go Back   International Full Size Jeep Association > Events > Las Cruces
Old 09-30-2010, 01:56 PM
Tad - the plates are still attached to sway bar. I was afraid to snap off the studs. You can have it all if it is a 7/8" if you like. Was thinking of using it on the SOA Waggy but the shackle reversal kind of throws off all the angles.
80s plates? I thought they were all the same 74-91?
Old 09-30-2010, 03:12 PM
Sambo's Avatar
Sambo Sambo is offline
i have an 87 sway bar with links i'll have to unbolt the pads tho!
77Chero,360,t400,231/d300,d60,c14bolt 5.13's 42"PBR's
84wag,360,tf727,208 stock for now! possiblities are d300 flipped and a ford d44 hp with coils
Old 09-30-2010, 03:30 PM
He needs it his mom's waggy Maxine
Old 09-30-2010, 03:52 PM
Start soaking them they'll come off eventually.
'80s are different but can be made to keep the sway bar in an SOA.
http://www.ifsja.org/forums/vb/showp...8&postcount=11
BB,
I found a 1" bar in the yard and 2 of the upper bolts, as I thought no good bushings of any type. I'll get it in the trailer either way.
See link above for modifying the plates.
Old 09-30-2010, 04:51 PM
BlackBart's Avatar
BlackBart BlackBart is offline
Excellent. If there is something you wanna swap for it let me know.
Civilized men are more discourteous than savages because they know they can be impolite without having their skulls split, as a general thing.
Conan the Cimmerian
The proper response to a complex problem is to grab a sword and brutally hack away until the problem stops moving.
Old 09-30-2010, 05:01 PM
Sambo's Avatar
how amazing to find another jeep just like the one i built for my buddy jeff.who sold it a while back!
Old 09-30-2010, 06:24 PM
Heimeken's Avatar
Heimeken Heimeken is offline
That is true. When I did my SOA on the CAT, I used some 79 (or older) spring plates and that puts the sway bar mount in the right location without having to do anything. Same goes for Vise-Versa, when doing an SOA for and older rig, use the 80 or newer plates.....
'85 Grand Wagoneer "Caterpillar" now w/401!
'79 Cherokee Chop-Top "Nom" the Sandgorgon
D60, 14Bolt, SOA,T18 on 40's
78 J10 360 TH400 Stocker "Imoteb"
Old 09-30-2010, 06:47 PM
I find it simply amazing that one could find a FSJ with 2 people looking under it to see what broke
See you all in about a month.
I hope I can get the D60 under there by then.
Ignorance is bliss.
Slacking is slacking.
I am a slacker on this one.
Old 09-30-2010, 10:59 PM
oh man... multi threading parts here... likes parts...
got home late tonight - looked at my junk - ok the 88 GWs have 1" sway bar. Never knew that. The 76 is a 7/8" bar. Soaking... What about the smaller plates that stack in there shown in the middle, need that?
Old 10-01-2010, 04:44 AM
Flint,
Not really, I just need 80's style.
Like Jaime said above, no work needed to make the 70's stuff work, they can just be relocated.
The '80's spring plates have the sway bar built into the spring plates.
That's why they need to be cut and flipped to work.
I'll bring you a set, it's easier to visualize when you have a set in you hand.
Old 10-01-2010, 06:37 AM
The one in the picture is off a 76 Cherokee. The 88s are still intact. So I can use the stuff already on my GW? Trying not to be cornfused before java. Jaime's comment threw me. Or am I hearing I should keep these for the soa on my GW?
Old 10-01-2010, 08:34 AM
...Or am I hearing I should keep these for the soa on my GW?
Bring the '80's ones to 'Cruces and I'll bring you a set already cut and flipped. I use them as cores for folks that can't get the welding done themselves (which has always confused me, how did they get the perches on?).
Old 10-01-2010, 09:44 AM
OK. So the 76 sway bar parts are not needed or wanted Tad?
I don't have 80's style removed from a rig but would be glad to give/send you the ones off Wally when the SOA HD44 from Jaime goes on. So please bring a 80s set if you have 'em.
- multithreading -
Jaime - I have a QT for you. Can you bring the axle to Cruces? I have a 60 for the back now.
Old 10-01-2010, 09:50 AM
It's all good Flint.
I'll bring you a set and you get me the cores when you can.
Old 10-01-2010, 11:08 AM
It's all good. If anyone wants the 7/8" sway bar from a 76 Cherokee pictured in my post above, speak up.
Old 10-01-2010, 11:21 AM
BlackBart's Avatar
Sambo, you must be my evil twin.
First your jeep and my piranha truck is painted alike...
Then you built a waggy just like I built for my mom.
You don't have a thing for Scottish women, rum and vicks...
uhh... never mind
I guess I'm the evil one.
Conan the Cimmerian
Old 10-02-2010, 08:09 AM
Sambo's Avatar
lol bart.
i married a czeck and drink lots of budlight,and only use vicks when i cant breath
been known to stalk people! lol not really
Old 10-02-2010, 05:39 PM
ki4alb's Avatar
ki4alb ki4alb is offline
Hi all the new guy (me) has a front bumper off my 77 J10 I need a couple of front turn signal housings and lenses
Old 10-02-2010, 08:01 PM
You are going to bring the bumper to Las Cruces next month from TN?
This is an on site parts trade/swap.
Old 10-03-2010, 10:37 PM
Howdy folks,
I'm looking for tailgate side straps. They are missing from my '76 J-20.
TIA
George
'74 Cherokee, 401
'76 J-20, 401
M725, future project
muscle to rhino swap miscellaneous parts brubakes General FSJ Tech 7 10-25-2009 11:36 AM
78 Waggy to J10 parts swap jimbos83j10 General FSJ Tech 10 10-13-2009 03:33 PM
Parts Swap Gambler68 Moab 3 02-15-2008 08:08 AM
82 waggy to 71 J body parts swap? cabz General FSJ Tech 3 06-24-2006 06:57 PM
J10- what parts can I swap from KYJ10 General FSJ Tech 13 05-16-2002 07:02 AM
