View Poll Results: What Viscosity Motor Oil Do You Use?
5W20 3 0.69%
5W30 17 3.92%
10W30 146 33.64%
10W40 134 30.88%
20W50 74 17.05%
SAE 30 Wt 9 2.07%
What ever's on sale 8 1.84%
Not listed 43 9.91%
Voters: 434. You may not vote on this poll
  #101
Old 01-11-2012, 08:15 AM
Jeepguyp's Avatar
Jeepguyp Jeepguyp is offline
STP
I couldnt get my Dad to stop putting blue-bottle STP in our old 77 Olds(R.I.P. , now in China in a smelt).... but STP has paraffin(wax)... accumulative
AMC V-8 FOREVER
1976 Cherokee Chief 360\4-spd(soon to be auto\ Q-trac)
1977 CJ5 "Lulu"
360\5-SPEED GRANNY\DANA300\ DANA 44s
DETROIT \POWERLOCK 4.10
37" tires, and LOTS other stuff
77 J-10 401\Q trac "Thadeus"
64 Stude Avanti 289 R2---ALIVE!
91 Dodge W350 5.9 Cummins
64 Avanti#2(R1)...Under construction
Old 01-11-2012, 12:42 PM
rreed's Avatar
rreed rreed is offline
Super Moderator
I've seen what happens when paraffin builds up in engines. NOT pretty, and engine rebuilders throw a screaming fit when they find it. Didn't know STP engine treatment had it in it.
I'm not driving a Mercedes, I'm driving a '76 360 and '81 258 (not at the same time, of course) both AMC. I would like to make sure I'm running the proper oil to help them live a long and healthy life. The 360 leaks too much to pour out expensive synthetic on the ground. The 258 will get freshened up w/ all new seals and gaskets but just because it's "synthetic" does it mean it will have everything the engine needs?
Last I recall was that Dupont threw a screaming fit over people putting Teflon in their motors via those oil filters that came out w/ it in there about 15 or so years back. They said something about "do not put Teflon in an internal combustion engine, it does not belong there." I try to be wary of snake oil, myself.
I'm also curious about the oil filter magnets, though for the price tag I'll just bust up an old speaker magnet and stick the chunks to the side of the oil filter one of these days. Figure surely it couldn't hurt...
47 Willys
75 CJ-5
81 Scrambler
96 ZJ
Old 01-11-2012, 01:26 PM
95steel 95steel is offline
Rick,
Your in Tejas now, run rotella and you and your engine will be happy. If it gets cold long enough (Dec-Feb/March) run rotella synth 5w40 for colder months.
Most oils are a parifin based oil, people blamed crapy pvc designs and bad maintenance on oil. Yes some oils are better than others, not going to start that arguement... Our engines will require oil changes more often if used for short trips because the engine won't be able to get warm enough to boil out condensation (what causes most sludge build ups). I am not a big believer in oil additives, I'd rather buy better oil.
Adam
What we do in life echoes throughout eternity
Old 01-16-2012, 03:18 PM
codyyy codyyy is offline
I haven't ran my old engine long enough to know the effects of what oil to use, but I put in 10-30 as that is basically what it says to use in the Haynes manual I have. I might decide to put STP or Lucas Oil Break-In for the zinc content but I'll hold off for now, I'm keeping it simple.
Looking for one
Old 01-17-2012, 10:55 AM
Herk's Avatar
Herk Herk is offline
Rotella T6 5w40 synthetic in EVERYTHING.
I don't worry too much about oil pressure, I have the relief valve set at only 45 PSI on my Gladiator. I am more concerned about how fast I get pressure (circulation) on cold starts, how soon it drops to the regulated pressure when warm, and how well it maintains regulated pressure.
Viscosity is RESISTANCE TO FLOW, more is not better. Also since the oil pressure tap on our engines is typically upstream of any bearings, that high pressure may be indicating that oil isn't getting to where it's needed.
Old 01-19-2012, 10:21 AM
Jeepguyp's Avatar
AMC V-8 FOREVER
1977 CJ5 "Lulu"
Old 02-11-2012, 07:29 AM
Jeepguyp's Avatar
Glitch
weird.... I posted above WEEKS AGO and it says (on the forum header) I did it TODAY..... glitch in the machine
AMC V-8 FOREVER
1977 CJ5 "Lulu"
Old 02-15-2012, 02:28 AM
18cherokee's Avatar
18cherokee 18cherokee is offline
just switched to 10w50 semi synthetic (also an lpg/propane special blend) on my rebuilt engine. also use a valve saver system.
Black Cherry 1989 Grand Wagoneer
S&J rebuilt AMC360
IMPCO Propane
Old 02-15-2012, 07:43 AM
Jeepguyp's Avatar
valve saver
Valve saver for the LPG? whats the system? and what kinda oil has 10-50?
AMC V-8 FOREVER
1977 CJ5 "Lulu"
Old 02-15-2012, 03:13 PM
SD_RED's Avatar
SD_RED SD_RED is offline
Z-Rod
Amsoil Z-Rod 10W30 in a 81 waggy 360 daily driver, central Texas. Very high zinc content.
Here's the link:
http://www.amsoil.com/storefront/zrt.aspx
Old 02-15-2012, 03:19 PM
CJ5 CJ5 is offline
I use Valvoline SAE30, always have. Ihave used it in all my motors, old and new and never had any problems.
Chief Laredo Build Album:http://www.fototime.com/inv/BB4AF31A10748CC
'72CJ - Complete Restore
'81SJ - Loredo Resto Project
'91YJ - Rock Crawler
Old 02-15-2012, 06:06 PM
Great Pharoah's Avatar
Great Pharoah Great Pharoah is offline
NAPA 15-50 Synthetic
I changed from motorcraft 10w 30 to NAPA 15w50 full synthetic. Seems to work good I don't see any leaks. I Don't know who the vendor is but it's not one I'm familar with. but as long as it works, who cares.
American Jobs should be for Americans.
Some Cheros run at 75, and some do 69,
But if I can get mine to start and run at all, I think I'm doing fine.
Big Mike
"Whoopi" 80 Cherokee Golden Hawk. 360/727/208
Horseshoe Bay, Texas
Old 02-15-2012, 07:12 PM
svining's Avatar
svining svining is offline
Wink In the shop manual
It says that our Northern friends should use 20 w Oil in 0 degree temps. So I was musing about using 5-20 Mobil 1, for better milage. Now I know at 0 degrees you need the Oil thin. But after your motor is warm you still got 20 weight oil in there. So I don't see why some are so worried about thin oil.
Gets where it needs to, fast and improves milage. I haven't heard, but I'm no expert, that motors in the Northern tier, wear out fast because they use thin Oil. Anybody in Minot ND got their ears on today. Do your motors wear out fast in Canada, if your not out shoveling snow give a chime!
Flashlight
"I started with nothing, I still got most of it left"
1982 GW,Stock, No Emissions Equip.
Mallory HEI, AMC 360, Motorcraft 2150
Old 02-15-2012, 07:18 PM
18cherokee's Avatar
Valve Saver
10w50 oil
S&J rebuilt AMC360
IMPCO Propane
Old 03-25-2012, 07:37 PM
svining's Avatar
Talking I saw it today!!
Walmart has Mobil 1, 0-30 weight, improved milage formulation, I hoping to get 20 mpg after the next Oil change
Originally Posted by 18cherokee
Flashlight
Old 03-25-2012, 08:10 PM
247pia's Avatar
247pia 247pia is offline
79 Cherokee 360, T-18, Dana 20, Locked tons. I give up.
08 Liberty, 97 Z71
Old 03-26-2012, 06:29 PM
Rich88's Avatar
Rich88 Rich88 is offline
There's a conspiracy: They're hiding the 0 friction, lifetime oil. (Along with the 100 mpg carbs)
Old 03-26-2012, 09:00 PM
KJ Ryu's Avatar
KJ Ryu KJ Ryu is offline
Mobile1 5w-30 in everything I own, except my Ski-doo. It gets XPS Syn blend. That may change when the warranty is up.
My Liberty gets 21.5mpg on the highway with a 3" lift and 31" tires (stock is about 28.9") and no gear change. I attribute most of that to the Mobile1. I kept track, using several oils through a few changes before trying another. Have yet to try Amsoil, though. Oh, Royal Purple syn diff oil makes a lot of difference, too!
Ron
2005 KJ, Hit-n-Run, 2am 6-17-2012, Totaled.
1977 J10, 2v304, T18, D20, 37x14s, SOA & SF on tons, still ugly Occasional driving!
1978 SJ Wagoneer, 360, QT, 33x12.5s, lift by Sawzall NOT Running
1977 J10 4v401, TH400, BW1339, mostly stock DD
Originally Posted by Mars
One man's trans leak is another's penetrating oil
Old 03-26-2012, 09:42 PM
svining's Avatar
Wink As usual Rich!!
I guess you didn't get the memo on the special chip that doubles horsepower and triples milage for $29.95
Flashlight
Old 03-26-2012, 10:03 PM
KJ Ryu's Avatar
I did but it went to File 13. I base my results on my own research. YMMV!!!
HP doesn't seem to have gone up much but, I've never dyno'd it or anything. It will git when you gun it, tho!
Ron
Fluid viscosity spcecs. for early fsj mtjeep General FSJ Tech 3 07-31-2010 04:57 PM
Oil suggestions (viscosity)? 1x1_Speed_Craig General FSJ Tech 3 06-08-2004 04:26 AM
