09-04-2010, 09:40 AM
Rabble Rouser
Tick TICK!
Recently developed a definite tick in the front drivers side head. Sound like the very front one. What should I look for, or care about?
mid 70'sish-(unknown..figure a 75+) AMC 360.
1968 327 J3000 1978 J10SWB
Hunter S. Thompson .
09-04-2010, 10:19 AM
valve?
Exhaust leak?
Baltimore
1991 Grand Wagoneer, Rebuilt 360, Eddy Perf Manifold, Razor Grill
1970 Plymouth 'Cuda (my baby)
09-04-2010, 11:06 AM
Rabble Rouser
Leaning towards valve..might try a cure in a can
I have no particular affinity for this particular engine..if it blows, it's getting a 401 like it rolled off the factory floor with.
09-04-2010, 01:33 PM
 401  . . . Low compression pooch
 Put some ported n polished 72'-76' AMC-401 heads on a 68'-70' AMC-390
 Caution can cause poor rear tire wear
Mike
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX-390 Resto.
1977 Ford F350.
1982 AMC Eagle project SX/290.
1982 AMC/Jeep project J5500.
1988 AMC/Jeep project MJ/343.
1992 GTA Trans AM.
A M C Means jeep to me
09-04-2010, 03:32 PM
I HAVE FOUND THE TICK
Hey guys i had discoverd a tick as well, so i pulled of the valve cover and pulled the rocker arm off and rocker bridge. What i have found is that the rocker pivot ball and bridge are one piece. The pivots had worn and created burrs on the piviot witch created the ticking so i orderd new rocker arms, piviot, and bridge. The parts i orderd bridge and pivot were seprate pieces wich look like a better design. Here the part # from oriellys
Rocker Arm #R-875A about 3 bucks apiece
Rocker pivot #MR-1839 about 1 buck
Rocker Bridge#MR-1840 about 1 buck
These parts are made by SEALED POWER and look like a better design.
BY the way if this helps please let me know.
Theirs my piece
09-04-2010, 03:42 PM
Here was my tick...
CJ
-1987 Grand Wagoneer "Nodoka" - 360/727/NP208 (SOA/ft Lincoln Locker/rr Lincoln Locker)
-1985 Ford LTD Country Squire "Rarity" - Con car/DD
-2008 Saturn Astra XR "Mighty Mouse" - Daily driver
09-04-2010, 03:49 PM
Originally Posted by CJ the noisemaker
That wasn't a tick...
Lifters make a distinctive sound, rods, pistons, mains are a whole different set of noises.
Diagnosing a noise over the net is pretty much impossible.
09-04-2010, 04:08 PM
But it was since it went away once the wrist pin snapped.
CJ
09-04-2010, 06:07 PM
Fool-Injected
LOL lots of bad juju in this thread. I'm hanging up some charms on the roof rack first thing tomorrow!
Gambler, if it sounds like it's coming from the top you may be in luck. A slightly longer pushrod might be a temporary fix if things are just out of spec, though usually any sort of valve tick means a lifter is going. I say junk the thing and go 401 (or 390, if you can even find one, Mike!)
09-04-2010, 06:11 PM
Rabble Rouser
Theirs my piece
winner winner chicken dinner...I hope. I'll scope it out soon. It's been a progressive tick over the past year. Sounds wear related vs frakking Armageddon like CJ's 'tick'
09-04-2010, 07:05 PM
Hey Ryan!
TICK TICK TICK!!!
Funny thing was, it still ran smooth, just sounded like a diesel and was completely gutless like a 6.5
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
09-04-2010, 07:17 PM
 6.5  oh crap you know an AMC is sick when i gets that SLOW
390 has was in production 66'-70' it was used in more then AMX's & Javelins ya know, them big ol'Family trucksters had them to with a 9 or 9.5:1 C/R even
Mike
1962 GMC 4500.
1977 Ford F350.
1992 GTA Trans AM.
09-04-2010, 08:36 PM
Hey cj that could not have been a tick most likely a knock. any case after what i had found last week that is likely to be 75% of the ticking noise people hear but mine was a substained tick, if tick is intermediat it would be a totally diffrent prob. Guys not trying to cause probs just trying to HELP
79 Cherokee
07 Chrystler 300
07 suzuki SV1000S (bike)
66 Mustang conv 289 50K
09-04-2010, 08:43 PM
Hey gambler just pull one rocker and bridge and simulate same movement in your hand with rocker and bridge. Everything should be smooth and fluid with no roughness if seems ok pull another one the whole proceses shouldent take more than 45 min. shure hope thats the problem any case let me know
79 Cherokee
07 Chrystler 300
09-05-2010, 02:12 AM
TICK TICK TICK!!!
Hi my name is Keith; I have Obsessive–Jeep Disorder (OJD) : a mental disorder characterized by intrusive thoughts that produce anxiety, by repetitive behaviors (buying parts and more Jeeps) aimed at reducing anxiety, or by combinations of such thoughts & behaviors such as but not limited to working on said Jeeps for extended hours.
09-05-2010, 11:46 AM
TICK TICK TICK!!!
 Wow, I find it hard to believe she still ran smooth! I don't think even an sbc could stand up to that kind of punishment...
74 J10 401/th400/dana 20 Status: Tear down phase
08 Dodge Ram 4.7/545RFE/NV246: Daily Driver/Parts hauler
79 J10 "EPIC" Status: Resting in pieces
