Old 08-28-2010, 04:27 PM
holley2346 holley2346 is offline
Chevy or a dodge axle?
I have already read the dana 60 bible, and know that I have a dana 60. I just need to know what to tell the parts house when I need replacement parts...
(1) The axle has 30 spline outers 35 spline inners.
(2) The axle has 2.75" Spring pads.... which makes it confusing since dodges have 2.5" and chevy's have 3".
(4) The axle is ~31" Spring pad to spring pad
(5) The spindle is held on with 6 nuts
(6) The axle is of course a passenger side drop
(7) The axle has no BOM numbers..... actually, no number on the long axle tube period
(8) The spindle nuts are 4 prong, not 6
(9) On the pumpkin there are d60 impressions and on the top right part of the pumpkin facing forward are the numbers C40386.
Please help
1974 Jeep j10 / AMC 360
Performer Intake / Edelbrock 650
Mallory HEI ignition / Comp Cams low end cam
6" Lift Spring / SOA / 1" Shackle Front
Shackle Flip / 4" Block / 3" AAL Rear
3" Body Lift
38.5x15 Super Swamper TSL Boggers
Corporate 14 Bolt Rear / D60 Front (4.88)
Build Log
http://www.ifsja.org/forums/vb/showthread.php?t=114629
Old 08-28-2010, 07:10 PM
I got the Willys....
What is the wheel mounting surface measurement?
Dodge is 67" GM is 69".
IH also used an open knuckle D60 front for one year. 75 I think.
1971 Gladiator J2000 Platform-Stake Dump 350/T18
1968 Gladiator J3000 3406Z 160" wheel base DRW 350/T18
Old 08-28-2010, 10:06 PM
The axle is currently completely apart, is there any other way to tell? I need to order the new parts to re assemble it.
I hate I didn't measure it before I took it all apart.
3" Body Lift
Build Log
Old 08-29-2010, 07:21 AM
Pretty sure the Dodge front D60 spring pads are 32.5" on center and the GM's are 32".
I was able track down the year of mine from the BOM number that was under a lot of paint, yours is there someplace I'm sure.
http://www.pirate4x4.com/tech/billav...%20Shafts.html
1/2 Chevy axle swap anyone? Turbobu General FSJ Tech 14 11-06-2009 08:38 PM
chevy hd44 axle swap question (shock related) malodin Off-Road FSJ Tech 4 08-21-2007 07:11 PM
Chevy axle swap on to WT Cherokee Eugene 1 Off-Road FSJ Tech 25 08-10-2007 09:07 PM
chevy dana44 axle swap questions and general axle swap questions malodin Off-Road FSJ Tech 8 08-10-2007 07:12 PM
Going SOA with the '28... with a (gasp) Chevy 10 bolt... DrChop General FSJ Tech 2 03-08-2002 06:04 AM
