Old 08-21-2010, 06:01 PM
tazzerzz's Avatar
tazzerzz tazzerzz is offline
Reverse clutch Chatter
1980 j10 258/4 speed
Ever since I have been driving this truck it has been having clutch chatter and shake in reverse only, And only when driven a while.
All forward gears engage perfectly and the clutch is smooth and chatter free.
When cold , reverse is also chatter free
Never adjusted the clutch as the free play has always been fine, even after over two years
Just wanted some input on what may cause this. Also had a stock tire and rim on it for a couple of weeks and the chatter was a lot worse. Back to the normal reverse chatter with the 31s,
1980 j10 w/Brow and a nice fresh dent on the bed
Old 08-21-2010, 06:21 PM
Wayne's Avatar
Wayne Wayne is offline
Loose mounting bolts, could be the throwout bearing.
Maybe motor or trans. mount.
78 Wagoneer 401/T400/bw/44F&R DD 4in lift
Clutch rod Issue Blue & Gray General FSJ Tech 0 03-26-2010 09:47 PM
Replacement clutch linkage []V[]AXX General FSJ Tech 0 01-27-2010 06:48 PM
Im completley lost on my clutch shackwrrr General FSJ Tech 4 05-28-2009 08:33 PM
Replacing a cable clutch in a 1972 Pickup J4600 with mechanical Bill Moore General FSJ Tech 0 01-25-2009 05:12 PM
clutch, clutch pedal, and tranny... please advice. sportsidedan General FSJ Tech 4 06-30-2007 06:00 AM
