View Poll Results: How modified is YOUR FSJ? Can vote more than once for people have more than one FSJ
Restored to like it rolled off the line
9 |
1.95% |
Unrestored original
102 |
22.08% |
Mildly modified - mostly stock
149 |
32.25% |
Moderately modified
151 |
32.68% |
Radically modified
68 |
14.72% |
07-19-2010, 10:55 PM
Mine is bone stock for now. Given a few more years and no major disasters, it'll be far from stock.
Originally Posted by Locked and Loaded
Jeeps don't get stuck. People do.
Let the good times roll! '83 Wagoneer «◘► ‼» 401/TF727/3:31 AMC20
07-19-2010, 11:25 PM
It'll be very modified for me, eventually. My truck was almost completely stripped inside when I bought it and needs some underhood work, so all I see is blank canvas....
Brian
86 GW, stock 360/trans "Frank"
Edelbrock carb on Offy intake
Some kind of spring lift (BJs 6 maybe)
Desert faded paint/body work courtesy AZ trails
USAF: Dropping Bombs and Hauling Grunts Since 1947
07-20-2010, 12:55 AM
Ours is a stocker '91 GW with a highly modified Roof Rack when including the Yakima Clamshell...glad to have her in the driveway with the other Jeeps representing!
07-20-2010, 03:26 AM
Guards cut, 37's, HPD60 rear, twin detriots, engine work, bar work, dual fuel, endless air, spring lift, body lift...... just as the factory REALLY intended.....
07-20-2010, 12:02 PM
Well, I have an SOA lift, 14bolt one ton rear, 8 lug conversion front, Hi-Steer, and TFI ignition. Where does that classify?
1988 Grand Wagoneer currently in pieces across the shop.
07-20-2010, 12:15 PM
Originally Posted by SEdmonds
How about modified by human hands, not by an act of nature?
Soon, soon. Hacking off the nature/man made "mods" this week.
~Craig
1979 Cherokee Chief
1973 VW Squareback
07-20-2010, 01:30 PM
If rust repair counts as modded I'm all over it. otherwise mostly stock..
07-20-2010, 01:34 PM
I went with mildly since it is an extended cab truck now, but it is to subjective, 1 persons mild may be another radical, even "restoration" is iffy, seen people say they have a "restored" 57 cheby and it has a FI 454 in it and coild springs.....
07-20-2010, 03:42 PM
Very true - and I thought (for about 2 seconds), about listing the various mods that would come under each category - BUT I am not really conversant in those things, so left it the way it was.
07-20-2010, 10:45 PM
Axles swapped, tranfser case swapped and suspension pretty much all reworked. Not to mention new driveshafts, hydroboost, tires and wheels, electric fan, etc. I put moderate...
88 Waggy
Resting in peace... Um... In piece... Er... IN PIECES
Current Status: Under construction. Phase 2.
86 Pathfinder Conversions "K-Van"
Current Status: Broke
Volkswagen rail buggy
Current status: Broke
95 Jeep ZJ V8
Current status: DDing
07-21-2010, 12:25 PM
What if your Jeep resembles a tractor more than a Jeep?
-Jon Barstow
1979 Cherokee Golden Eagle
360/TH400/D20
5" lift/33x12.5R15
07-21-2010, 06:19 PM
I went with moderate:
Golen Engines LT1
Headers, true dual exhaust (need to add a H or X in there..)
4L60E
4.10 gears, LDS in front, Aussie in rear (thinking that LSD needs to a change)
Rear disc brakes
BDS 4" lift with 32" Duelers
F150 fuel tank
Floor shifter (out of a blazer)
Seats - TBD...but NOT the stock ones!
Stuff stacked up in the garage waiting for me to find the time..
More to go.
One day I will wake up and realize that my jeep is complete...one day, I just know it.
88Wag, LT1/4L60E/NP229, Dual 2.5", F150 fuel cell, Rear discs, Aussie rear, LDS front, 4.10 gears
97 Orvis ZJ - DD
95 YJ - D44's, SOA on OME leafs, ARB's, 4.56s, Blisteins, 35" KM2's
http://s552.photobucket.com/albums/j...wapmohn/Jeeps/
07-22-2010, 08:58 PM
Burbaneer?
Right now I'd say it's mildly modified. List of current mods on my '71 Waggy includes:
- Rhino grill
- Chevy (not Buick) 350
- GM TH400
- BJ's 4-inch springs (now sold)
- BJ's 2-inch body lift
- Hummer H3 Mirrors
- '96 Ramcharger Radiator ($40)
- $5 Radiator overflow from Suzuki Samarai
- Tinted Windows
In-progress mods include:
- Frame swap - soon to be shortened 1987 3/4-ton 4X4 Suburban frame
- 1965 front fenders
- offroad lights mounted in pie-pan openings
Future Mods:
- Bushwacker pocket-style fender flares
- TH700R4, 4L80, 5-speed or 6-speed manual tranny
- wider space between rear wheel wells
- Dodge Durango 3-row seats (camel/brown)
- Air Conditioning!
- Massive square tube bumpers
- swing-out tire carrier
- custom cattle pusher
- safari-style roof rack
- custom-built rear hatch ala pre-78 Bronco or pre-73 Blazer instead of glass in tailgate
- forest green paint inside and out
- rhino-lined floor
- custom interior panels (tan/beige leather)
- custom wire harness
It would probably be classified as radically modified when I'm done.
07-24-2010, 06:02 AM
1 of each
I'm lucky enough to have one of each,A stock waggy & a modified cherokee.I plan on leaving the wagoneer stock just doing the repairs needed to keep it going & patch up the body.  The cherokee will always be a project in motion getting whatever makes it a better on/off road &/or makes it more apealing(to me)
Heres the list on the cherokee;
-455 buick(my favorite mod)
-dana 20 t-case
-cut down caddy radiator
-red top optima in relocated box
-daul solonoid on starter
-wide trac axles
-wide trac flares
-panel doors(most atention getting mod.)
-welded rear diff(was detroit still waitin' parts to repair!)
-classic cyclone wheels&33" tires
-gladitator front clip
-'02 chevy "work van" seats
-rear disc brakes(2nd fave mod!)
-3:07 to 3:54 gears
-after market gauges in place of ash trays
-flow master"50"& single exhaust tucked up tite
-single hoop 6 point roll bar
-satin black rattle can paint(renewable after each trail ride!)
-custom front bumper&winch mount(with 8000#china winch!)
-custom rear bumper with 1/4 panel protection&reciver hitch
-grand cherokee plastic tank& cut down f550 skid plate(gas gauge works!)
-inside snorkel(through fire wall behind dash)
-4" lift with double shackles on front
Future plans include;
-GM throttle body EFI
-center consel & floor shifter
-rebuilt ramsey winch
-wet proof inteior panels
-limited slip in front diff
-louvers punched into hood or steel cowlinduction hood
-2nd battery& HO alt
07-27-2010, 03:35 PM
How about Crom is EXTREMELY modified
The frame, most of the front clip, and motor are 1976 Cherokee. The cab is from a 1975 J-20, The front fenders are M-715, the rears are 1940s Allis Chalmers tractor. The hood has been modified with a home made scoop made from a chevy truck transmission tunnel, and hood vents from a turbo La Baron. Tranny is a 727 backed up to a 203/205 doubler. Front diff is a Dana 60 out of a 78 F250, rear is a 14 bolt with disc brakes. He uses propane for fuel and rolls on Hummv 37X12.50X16.5 tires
07-27-2010, 11:00 PM
Originally Posted by framus
If you counted rust as a modification, it would kick me into the highly modified category.
 Well said! Me too...
1981 Jeep Wagoneer
2007 Jeep Commander
1973 AMC Javelin AMX
2007 Pontiac Solstice GXP
2001 Buick Century
“I never wonder to see men wicked, but I often wonder to see them not ashamed.”
-Jonathan Swift
07-28-2010, 08:44 AM
My 1991 Grand Wagoneer is bone stock, other than keeping it running I have done no mods at all.
The Junkyard Dog is a different story, always making some sort of mod to keep it going and make it a better trail truck.
91G-Dub = Bill Houston
1979/1980 J-10 Junkyard Dog 258 4 speed D44 front AMC 20 rear 3.31 Lincoln Locker Status Running
1991 Grand Wagoneer Gray Ghost (bone stock) STATUS Gone but not forgotten
"The tree of liberty must be refreshed from time to time, with the blood of patriots and tyrants.
It is its natural manure."
Thomas Jefferson
07-28-2010, 11:04 AM
3 of the 4 doors, some of the remaining body and the frame are still original.
07-28-2010, 01:51 PM
At the moment; unrestored original. But it will be modified, oh yes, it will be modified..
07-28-2010, 01:52 PM
If I'd seen this poll yesterday I would have chosen "mild". After all, it's still mostly Jeep, and even looks like a Jeep. But I was working under my neighbor's stock Wag today and looked around thinking, "Dang, there's nothing under here but the frame rails that's like mine". I guess we sometimes forget over the years just how much blood, sweat & beers we've poured into these things. So, "moderate" for me.
S.J.
"Carpe Mañana".
'83 Wagoneer
