Old 07-17-2010, 08:25 AM
Tripwire's Avatar
Tripwire Tripwire is offline
Low oil pressure on new 4.2 engine? what style pump
I have low pressure on a newly rebuilt 4.2 engine
at idle its about 5 PSI and at speed its only about 15.... if you run for a long time it drops even lower
the old engine had much higher
I swapped out the mechanical gauge with another one for testing purposes with same results
It dosnt seem to build up/drop when reving the engine like the old motor..
I am running Nappa gold filters and have changed them twice
Im going to try another new oil pump and pickup tube....I only want to do this once ( ok twice) should i go for a high volume or high pressure Any brand recomendations - im thinking the pump that came with the new motor was a cheap POS
help me obi Wan
"You think you hate it now - Just wait till you drive it " ( family vacation - car salesman)
Tripwire. 86 Grand. Howell fuel Injected 360. MSD Ignition + Dizzy. 727/228 BJ's 2" Lift and 31's
88 Wrangler Howell TBI and MSD - Borla Headers w/ Cat-back + winch and 31's AND a M416 trailer (-:
Old 07-17-2010, 08:28 AM
high volume.
you may have left a plug out in the oil system in the motor.
Old 07-17-2010, 08:32 AM
Tripwire's Avatar
Yep ...i was thinking that also - i read on the internet there is one behind the timing gears that often gets overlooked... can anyone clue me in to its location? i dont wanna block off something thats supposed to be open
I just picked up the rebuilt and installed.....did not look for missing stuff
Thanks
Trip
Old 07-17-2010, 01:58 PM
Tripwire's Avatar
Ok ordered a melling oil pump - high volume and a new pickup tube....also a gasket kit in case i need to remove the timing cover to look for missing galley plugs
Any tips on installing the pump?
I have always used kork gaskets and lots of goo to seal them - the felpro has a rubber gasket - do i need goo for this as well?
Thanks !
Old 07-17-2010, 02:19 PM
Wayne's Avatar
Wayne Wayne is offline
Just install the gasket dry.
78 Wagoneer 401/T400/bw/44F&R DD 4in lift
Old 07-17-2010, 03:23 PM
TooRisky's Avatar
TooRisky TooRisky is offline
yup install it dry...any little leak will swell the cork for a better seal...
1977 Jeep Cherokee Wagoneer, 401CID, th400, D44's, 37"MTR, 7"lift, locked F/R, York OBA,12K Warn, Lotta Love
2002 Chrystler Sebring LX DD
Old 07-19-2010, 08:45 PM
jeepjerry's Avatar
A friend of mine had low oil pressure in his 230k mile 4.0. It got down around 5 psi hot at idle but the motor still runs pretty good so i suggested doing a high volume pump. He put the melling into it and now it gets down to 15psi at hot idle which is much better. Its around 35 psi cruising which is plenty unless you are beating on it a lot.
1977 J-20, 4bbl 360/t-18, 33"s.
1976 CJ-5 mild 360/t-18, 6" lift, 35"s.
1972 Javelin SST, full roller Indy head AMC 360. Under cunstruction.
AMC ya!!
Alfano Performance
Kenosha, WI 53142
Pump vs. Steady Pressure orangecherokee General FSJ Discussion 32 01-02-2011 08:35 PM
Diagnose engine problems using starter Perfex General FSJ Tech 0 04-14-2010 03:51 AM
termostat help Poley General FSJ Tech 4 05-11-2004 04:54 PM
Am I too cool? waggin'ear General FSJ Tech 15 07-13-2003 05:22 PM
No oil pressure - Engine still runs TN Bigdog General FSJ Tech 1 05-05-2002 01:37 PM
